Question about Kenmore 24712 Top Load Washer
Washer wont agitate or stop filling on any setting
Hello, well i got my washer back together from it not draining, it now drains. But now the water will not stop when filling on any setting and it wont agitate. Any help would be much appreciated, I have a kenmore 70 series 24712300 washer. Thanks =O )
  • 97 Answers
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Posted on Dec 31, 2009
My washer wont drain or turn on
Check the lid switch. If not activated or broken the washer will fill with water but won't agitate or spin.
Aug 30, 2014 | Washing Machines
I have a Kenmore 80 series washer it will not stop filling with water so it wont go into agitate cycle, help
Has your drain for your washer backed up recently? Or is the drain hose from the washer sealed into the drain pipe, meaning that you can't just lift the hose out anymore? There needs to be air around the drain hose or it will cause the washer to allow water to be siphened threw the drain by not closing the filling valve. This can also happen if your drain is backed up. Rooter the drain out and make sure that the drain hose is not sealed up to the drain pipe and see if that fixes your problem.
Feb 12, 2012 | Kenmore Washing Machines
I have a GE washer that won't drain!
The pump is clogged. Remove the tub to pump hose and you will find debris in it not letting the pump work. Do this and you will be good to go. Thanks, Rick
Mar 04, 2010 | Washing Machines
Washer will not fill up!
The water is siphoning out as it fills. Your drain hose is too low or has a air block. Remove the drain hose from the drain. Set the washer to fill. Hold the drain hose up higher than the washer. If it fills correctly and starts agitating,correct the drain hose problem.
Sep 23, 2009 | Admiral AW22 Top Load Washer
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Hotpoint washer fills begins to agitate then refills continously.
Very likely your drain hose is set too low. You can solve this with a standpipe or a kit called a siphon break.
Dec 31, 2008 | Hotpoint VBSR3100GWW Top Load Washer
Washer wont agitate.
Hose must fit tight on switch and tub connection-make sure it has no defects in it. If machine fully drained then did not get to correct water level when restarted then water level switch is bad. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | GE WSM2700W Unitized Spacemaker Washer and...
Washer agitates but doesn't spin or drain
something in your pump lean it back take hose off drain pump and clean it out
Dec 31, 2007 | Kenmore 49722
Maytag washer
Check to make sure your drain hose has a loop at least as high as washer top.  If the drain hose is not looped higher than tub water will continue to drain and it won't stop filling.  If it doesn'y reach the correct fill level it won't agitate.
Oct 29, 2007 | Maytag PAV2300 Top Load Washer
Kenmore 24712 Top Load Washer Logo
333 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
