Question about Soyo DYLM1788 Monitor
I need the driver for monitor Soyo model VT17N71. Thanks for your help
    Sniper:
  • 50 Answers
Just go to this link for the same.
http://drivers.soft5000.com/subcat_4.html
Thanks
Abhay Singh
Posted on Nov 24, 2009
2 Suggested Answers
  • 12 Answers
SOURCE: I need drivers for my Soyo MONITOR, DYLM017B
I've spent a bit of time researching this problem for you and have come up with the following, hope it helps.
SOYO has quoted "All SOYO monitors are Plug and Play monitors. They do not require drivers to work". Recently SOYO went bankrupt so their website is now unavailable for any form of support.
What i would recommend to you would be to temporarily connect a CRT monitor (one of those big bulky monitors) to your computer, as these have a larger resolution and refresh rate capability.
Once you can see Windows 7, change the display settings to the minimum settings for your monitor (as a safe bet i'd set them to 800x600, 60Hz until you connect the LCD). Then connect your flat panel monitor again and set the display settings to an optimal level for you.
Again, i very much doubt that you will need a driver for this brand of monitor, and will be hard pressed to find one.
All the best, and i wish you luck :)
Posted on May 10, 2010
Need a driver for soyo monitor
It should be plug and play in MS Windows at least. Cnet claims to have some here
http://www.cnet.com/topic-software/soyo-group-inc.html
Sep 18, 2013 | Soyo Computers & Internet
I need drivers for my Soyo MONITOR, DYLM017B Model:VT17n71.. Windows 7 is tellin me its out of range
May 10, 2010 | Soyo DYLM1788 Monitor
When I try to use my 17'' Soyo monitor with Windows 7 program the screen turns black and then ''out of range'' wording is all I get on the monitor. I have tried booting in safe mode, set the resolution to...
When you power up the compute press F8 key then enter in :"Enable vga mode" then go to display property and set screen resolution to 1024*768.
Then check .
If still same then enter in safe mode and uninstall graphic driver then start computer normal mode then install graphic driver.
Also in safe mode go to start->run type in run "chkdsk /r" then press ok then press "y" then restart computer then it fix and recovers error on harddrive.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 23, 2010 | Soyo Dymond DYLM017A 17" LCD Monitor
I need a new driver for my soyo monitor
Your soyo monitor doesn't require a driver. Make sure you download and install the latest driver for your video card and during the install of that, your monitor should have its drivers installed as well. At that point you'll be able to use your monitor properly. There isn't any drivers available on the net that I could find. Only other option is if your monitor came with a cd, that might have drivers on it.
Jan 14, 2010 | Soyo DYLM24D6 LCD Monitor
MONITOR VT17N71, SN C0542C0739 I CANNOT GET THE RESOLUTION THAT I THINK THE SCREEN SHOULD HAVE. I'VE TRIED ADJUSTING THE BRIGHTNESS...BUT IT'S ALWAYS TOO BRIGHT. I'VE TRIED ADJUSTING THE CONTRAST,...
Hi.
Just a general suggestion.
Are the graphics drivers loaded.
(Assuming you are using Windows) what happens when you rightclick on the desktop screen and you click on the Settings Tab
Jan 06, 2010 | Soyo Computers & Internet
Anyone have a url for the drivers for winxp? for the soyo dylm1
I have this monitor and it does not need drivers.
If your graphics card supports it use the DVI connection as this gives a better display and the card will normally suggest your best resolution for you.
If you are using the VGA connection you may have to play around a little to find the best resolution that suits you.
If you get an OUT OF RANGE message you are trying to run the monitor at a resolution that it cannot handle and should drop it back down a little.
Normally 1280 x 1024 is pretty good for most people.
Hope this was of use.
Oct 04, 2009 | Soyo DYLM1986 Monitor
Soyo 17'' Monitor (DYLM017A)(VT17N71), identity of fuse.
Orange color of the ring means number 3. Part of marking also contains "3A" so I'm pretty much sure it is 3 Amps rated fuse. But before replacing it measure the resistance on the PCB where that fuse was blown, between common mask (usually metalized mounting holes are connected to it) and the second pad of that fuse. How much is there? If you measure less than 12/3=4 Ohm the new fuse will blow again and you need to find what is shorting the power supply.
Sep 12, 2009 | Computers & Internet
VGA Compatible
this is the download link for the drivers
http://www.soyo.com/product/Intel_Pentium_4/27/SY-P4X400_DRAGON_Lite/148
Jan 07, 2009 | PC Chips Computers & Internet
Auto-tune isse
you could try adjusting the screen resolution in My Computer/Control Panel/Display this may help.
Also have a look to see if the Adaptor, is set for optimal refresh rate.
Mike @ Compurepair.
Sep 16, 2008 | Computers & Internet
Soyo monitors
your monitor doesnt have drivers for it.. and doesnt need drivers for that matter. It sounds like you dont have the right drivers installed for your graphics card. here is a link to the drivers you need.
http://www.nvidia.com/object/winxp_169.21_whql.html
hop this helps, good luck.
Jan 22, 2008 | Soyo Dymond DYLM017A 17" LCD Monitor
Soyo DYLM1788 Monitor Logo
804 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
