What will happen when these exceptions are added to the main method in java public static void main(String[] args) throws NoSuchAlgorithmException, NoSuchPaddingException, InvalidKeyException, IllegalBlockSizeException, BadPaddingException {
  • sumitnxt Nov 18, 2009
    thanks a lot
  • 3,741 Answers
Click this link directly
http://ws.apache.org/juddi/apidocs/org/apache/juddi/cryptor/DefaultCryptor.html
also reload the java software and recheck.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 18, 2009
Codes for if else if statement in java script
if (condition) {
//conditional true code here
} else {
//conditional false code here
Mar 23, 2011 | Computers & Internet
Wirte a pogram in java using for loop,that will print out the first 1 numbers of a fibonacii series that is:1 1 2 3 5 13 21 34 55
package com.gpt;
import javax.swing.JOptionPane;
This program computes Fibonacci numbers using a recursive
method.
public class Fibonacci
String input = JOptionPane.showInputDialog("Enter n: ");
int n = Integer.parseInt(input);
for (int i = 1; i {
int f = fib(i);
System.out.println("fib(" + i + ") = " + f);
System.exit(0);
Computes a Fibonacci number.
@param n an integer
@return the nth Fibonacci number
public static int fib(int n)
if (n return 1;
else
return fib(n - 1) + fib(n - 2);
Feb 24, 2011 | Sun Java Programming Language (cdj-275)
A java code for anagram
import java.io.IOException;
public class AnagramApp {
static int size;
static int count;
static char[] charArray;
public static void main(String[] args) throws IOException {
String input = "Java Source and Support";
size = input.length();
count = 0;
charArray = new char[size];
for (int j = 0; j < size; j++)
charArray[j] = input.charAt(j);
doAnagram(size);
public static void doAnagram(int newSize) {
int limit;
if (newSize == 1) // if too small, return;
return;
// for each position,
for (int i = 0; i < newSize; i++) {
doAnagram(newSize - 1); // anagram remaining
if (newSize == 2) // if innermost,
display();
rotate(newSize); // rotate word
// rotate left all chars from position to end
public static void rotate(int newSize) {
int i;
int position = size - newSize;
// save first letter
char temp = charArray[position];
//shift others left
for (i = position + 1; i < size; i++)
charArray[i - 1] = charArray[i];
//put first on right
charArray[i - 1] = temp;
public static void display() {
System.out.print(++count + " ");
for (int i = 0; i < size; i++)
System.out.print(charArray[i]);
System.out.println();
Nov 22, 2010 | Computers & Internet
How to get no. Of pixels from given image through java
try this code
import java.awt.image.PixelGrabber;
import java.awt.Toolkit;
import java.awt.Image;
class getpixel2
public static void main(String args[]) throws Exception
Image image = Toolkit.getDefaultToolkit().getImage("D:\\one.jpg");
if(image==null)
System.out.println("NO FIle");
PixelGrabber grabber = new PixelGrabber(image, 0, 0, -1, -1, false);
if (grabber.grabPixels())
int width = grabber.getWidth();
int height = grabber.getHeight();
if (isGreyscaleImage(grabber))
byte[] data = (byte[]) grabber.getPixels();
else
int[] data = (int[]) grabber.getPixels();
for(int i=0;i<data.length;i++)
int r = (data[i] >> 16) & 0xff;
int g = (data[i] >> 8) & 0xff;
int b = (data[i] >> 0) & 0xff;
System.out.println("(R,G,B)=("r","g","b")");
public static final boolean isGreyscaleImage(PixelGrabber pg)
return pg.getPixels() instanceof byte[];
} import java.awt.image.PixelGrabber;
class getpixel2
if(image==null)
else
May 15, 2010 | Computers & Internet
How to convert infix to postfix using stacks in java programming?
u can try the follwing coding
import java.io.*;
import java.util.*;
//begin coding for the stack interface
interface Stack<E>
public boolean isEmpty();//tests is current stack is empty. Returns true if so, and false if not.
public E top() throws StackException;//retrieves value at the top of the stack. Stack cannot be empty.
public void push(E value) throws StackException;//pushes a value on the top of the stack.
public void pop() throws StackException;//removes a value from the top of the stack. Stack cannot be empty.
}//terminates coding of Stack interface
//begin coding for the objArrayStack class
class objArrayStack<E> implements Stack<E>
//constructor
public objArrayStack()
topValue=-1;
}//terminates constructor
public void push(E value)throws StackException
if(topValue<ArraySize-1)//currrent stack is not full
++topValue;
Info[topValue]=value;
}//terminates if
else //current stack is full
throw new StackException("Error: Overflow");
}//terminates push method
if(!isEmpty())//current stack is not empty
--topValue;
else //stack is empty
throw new StackException("Error: Underflow");
}//terminates pop method
return topValue==-1;
}//terminates isEmpty method
if(!isEmpty())//stack is not empty
return (E)Info[topValue];
}//terminates top method
//declare instance variables
final int ArraySize=10;
private Object Info[]=new Object[ArraySize];
private int topValue;
//begins coding for the StackException class
class StackException extends RuntimeException
//constructor
public StackException(String str)
super(str);
}//terminates text of constructor
}//terminates text of StackException class
//method to convert from infix to postfix notation
public static String InToPost(String infixString)
//operator stack initialized
objArrayStack<Character> operatorStack = new objArrayStack<Character>();
//postfix string initialized as empty
String postfixString = " ";
//scan infix string and take appropriate action
for(int index = 0; index < infixString.length(); ++index)
char chValue = infixString.charAt(index);
if(chValue == '(')
operatorStack.push('(');
else if(chValue == ')')
Character oper = operatorStack.top();
while(!(oper.equals('(')) && !(operatorStack.isEmpty()))
postfixString += oper.charValue();
operatorStack.pop();
}//end while loop
}//end else if
else if(chValue == '+' || chValue == '-')
if(operatorStack.isEmpty()) //operatorStack is empty
operatorStack.push(chValue);
else //current operatorStack is not empty
while(!(operatorStack.isEmpty() || oper.equals(new Character('(')) || oper.equals(new Character(')'))))
}//ends while loop
}//end else
}//end else if
else if(chValue == '*' || chValue == '/')
else
while(!oper.equals(new Character('+')) && !oper.equals(new Character('-')) && !operatorStack.isEmpty())
}//end while loop
}//end else
}//end else if
else
postfixString += chValue;
}//end for loop
while(!operatorStack.isEmpty())
if(!oper.equals(new Character('(')))
}//end if
}//end while
return postfixString ;
}//terminates text of InToPost method
public static void main(String[]args)
objArrayStack mystack = new objArrayStack();
System.out.println("Enter a string");
Scanner scan = new Scanner(System.in);
scan.nextLine();
String str = scan.nextLine();
InToPost(str);
}//terminates text of main method
}//terminates text of objArrayStack class
Mar 16, 2010 | Sun Java Programming Language (cdj-275)
I need a complete workingsource code written in
This is a simple source code for Simple calculator in Java using RMI
//mathServer//
import java.rmi.*;
import java.rmi.Naming.*;
import java.rmi.server.*;
import java.rmi.registry.*;
import java.net.*;
import java.util.*;
interface mathInterface extends Remote
public int add(int a,int b) throws RemoteException;
public int subt(int a,int b) throws RemoteException;
public int mult(int a,int b) throws RemoteException;
public int div(int a,int b) throws RemoteException;
public class mathServer extends UnicastRemoteObject implements
mathInterface
public mathServer() throws RemoteException
System.out.println("Initializing Server");
return(a+b);
return(a-b);
return(a*b);
return(a/b);
try
mathServer ms=new mathServer();
java.rmi.Naming.rebind("MathServ",ms);
System.out.println("Server Ready");
catch(RemoteException RE)
System.out.println("Remote Server Error:"+ RE.getMessage());
System.exit(0);
catch(MalformedURLException ME)
System.out.println("Invalid URL!!");
//mathClient//
import java.rmi.*;
import java.awt.*;
import java.awt.event.*;
public class mathClient extends Frame implements ActionListener
Button B1=new Button("Sum");
Button B2=new Button("Subtract");
Button B3=new Button("Multiply");
Button B4=new Button("Divide");
Label l1=new Label("Number 1");
Label l2=new Label("Number 2");
Label l3=new Label("Result");
TextField t1=new TextField(20);
TextField t2=new TextField(20);
TextField t3=new TextField(20);
public mathClient()
super("Calculator");
setLayout(null);
l1.setBounds(20,50,55,25);
add(l1);
l2.setBounds(20,100,55,25);
add(l2);
l3.setBounds(20,150,55,25);
add(l3);
t1.setBounds(150,50,100,25);
add(t1);
t2.setBounds(150,100,100,25);
add(t2);
t3.setBounds(150,150,100,25);
add(t3);
B1.setBounds(20,200,80,25);
add(B1);
B2.setBounds(100,200,80,25);
add(B2);
B3.setBounds(180,200,80,25);
add(B3);
B4.setBounds(260,200,80,25);
add(B4);
B1.addActionListener(this);
B2.addActionListener(this);
B3.addActionListener(this);
B4.addActionListener(this);
addWindowListener(
new WindowAdapter()
public void windowClosing(WindowEvent e)
System.exit(0);
public void actionPerformed(ActionEvent AE)
if(AE.getSource()==B1)
sum();
else if(AE.getSource()==B2)
subt();
else if(AE.getSource()==B3)
mult();
else if(AE.getSource()==B4)
div();
public void sum()
int i=Integer.parseInt(t1.getText());
int j=Integer.parseInt(t2.getText());
int val;
try
String ServerURL="MathServ";
mathInterface MI=(mathInterface)Naming.lookup(ServerURL);
val=MI.add(i,j);
t3.setText(""+val);
catch(Exception ex)
System.out.println("Exception:"+ex);
public void subt()
int val;
try
val=MI.subt(i,j);
t3.setText(""+val);
catch(Exception ex)
public void mult()
int val;
try
val=MI.mult(i,j);
t3.setText(""+val);
catch(Exception ex)
public void div()
int val;
try
val=MI.div(i,j);
t3.setText(""+val);
catch(Exception ex)
mathClient MC=new mathClient();
MC.setVisible(true);
MC.setSize(600,500);
Jul 03, 2009 | Microsoft Computers & Internet
I want to read text file which is located in c drive using java code can anybody help me out
import java.io.*;
import java.util.Scanner;
public final class ReadWithScanner { public static void main(String... aArgs) throws FileNotFoundException {
ReadWithScanner parser = new ReadWithScanner("C:\\Temp\\test.txt");
parser.processLineByLine();
log("Done.");
* @param aFileName full name of an existing, readable file.
public ReadWithScanner(String aFileName){
fFile = new File(aFileName);
/** Template method that calls {@link #processLine(String)}. */
public final void processLineByLine() throws FileNotFoundException {
Scanner scanner = new Scanner(fFile);
try {
//first use a Scanner to get each line
while ( scanner.hasNextLine() ){
processLine( scanner.nextLine() );
finally {
//ensure the underlying stream is always closed
scanner.close();
* Overridable method for processing lines in different ways.
* <P>This simple default implementation expects simple name-value pairs, separated by an
* '=' sign. Examples of valid input :
* <tt>height = 167cm</tt>
* <tt>mass = 65kg</tt>
* <tt>disposition = "grumpy"</tt>
* <tt>this is the name = this is the value</tt>
protected void processLine(String aLine){
//use a second Scanner to parse the content of each line
Scanner scanner = new Scanner(aLine);
scanner.useDelimiter("=");
if ( scanner.hasNext() ){
String name = scanner.next();
String value = scanner.next();
log("Name is : " + quote(name.trim()) + ", and Value is : " + quote(value.trim()) );
else {
log("Empty or invalid line. Unable to process.");
//(no need for finally here, since String is source)
scanner.close();
// PRIVATE //
private final File fFile;
private static void log(Object aObject){
System.out.println(String.valueOf(aObject));
private String quote(String aText){
String QUOTE = "'";
return QUOTE + aText + QUOTE;
Jun 22, 2009 | Sun Java Programming Language (cdj-275)
Code for method parseInt() in java
parseInt(java.lang.String, int)
This code takes two arguments, a string constructor from the Java language and an integer. Its purpose is to parse (meaning de-construct or disassemble into component parts) one data type into another.
Here is an example of a Java program to specify and print out the dimensions of a rectangle, taken from the page http://www.roseindia.net/java/beginners/entervaluesfromkeyboard.shtml:
class Rectangle{
int length, breadth;
void show(int x, int y){
length = x;
breadth = y;
int calculate(){
return(length * breadth);
public class EnterValuesFromKeyboard{
public static void main(String[] args) {
Rectangle rectangle = new Rectangle();
int a = Integer.parseInt(args[0]);
int b = Integer.parseInt(args[1]);
rectangle.show(a, b);
System.out.println(" you have entered these values : " + a + " and " + b);
int area = rectangle.calculate();
System.out.println(" area of a rectange is : " + area);
Apr 09, 2009 | Sun Java Programming Language (cdj-275)
I am developing one java related application.In this there are three places place1,place2 ,place3 ,,if i'm click the place 1 ,in text box the text should come ilike ''place1 text.After that, when i click...
public class MainWindow extends javax.swing.JFrame {
public MainWindow() {
initComponents();
textField1.setText("");
.....component initialization function
private void jButton1ActionPerformed(java.awt.event.ActionEvent evt) {
textField1.setText("Place1");
private void jButton2ActionPerformed(java.awt.event.ActionEvent evt) {
textField1.setText("Place2");
private void jButton3ActionPerformed(java.awt.event.ActionEvent evt) {
textField1.setText("Place3");
* @param args the command line arguments
public static void main(String args[]) {
java.awt.EventQueue.invokeLater(new Runnable() {
public void run() {
new MainWindow().setVisible(true);
Mar 24, 2009 | Computers & Internet
Student library record
Import java.awt;
Import java.applet;
class Book extends Applet
{ String book name="Handbook";
int Book no=50;
int d.o.s=” ”;}
Type ur required body content here.
/*<applet code=”book” height=500 width=500 ></applet>
this appears to go beyond the scope of troubleshooting
Sep 27, 2008 | ArcMedia JavaScript Source Code 3000 Pro...
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
