Question about Frigidaire Kitchen Ranges
Just ran model # FEFL64DSA self cleaning electric range thru cleaning cycle. Now the bake and broil elements no longer heat up . Can you tell me why ?
  • 2 more comments
  • jpal10760 Nov 18, 2009
    Just flipped breaker for 2 minutes, did no good. Tested continuity in bake and broil element yesterday.they showed good. Had power coming out of switches on EOC board when switches were pushed. TEMP CENSOR ?
    Im about to pull back of stove and check temp censor. I'll let you know
    Hello, measured OHMS across temp probe. Meter did not move. That tells me that probe is bad. Is that what you think ?
    Solution was very helpful and very informative. Guru was very informed . Thanks
  • Frigidaire Master
  • 19,396 Answers
Hi.
The high temperature generated in self cleaning cycle may have damaged a part.
Parts that may get damaged are:
Temperature probe.
Control panel.
Wiring.
Control assembly.
In your case you may have blown the temperature probe. It must be tested reading impedance (Ohms) with a multimeter.
I will send you another message with testing procedures and diagrams. I had question locked and I am running out of time.
Start tripping the circuit breaker for two minutes. This can fix a jammed EOC (timer board).
Thanks.
Posted on Nov 18, 2009
  • Ginko
    Ginko Nov 18, 2009
    Hi.
    If you have no heating on both elements , then you may have blown the temperature probe, the wiring, or the control board wiring.
    The most common is the temperature probe.
    The probe is located inside the oven cavity, it is tested cutting the contacts and reading Ohms with multimeter set at Rx1 on its contacts.
    At room temperature a good probe will read about 1.1K Ohms .
    If the elements do not heat at all the probe will probably read no continuity, that is circuit open with Ohms infinity. On an analog meter the indicator will not move.
    Disconnect appliance first.
    Here the diagrams and parts for your range.
    Here the probe : PS977498 - Part 37 on diagram (click to enlarge).
    All repairs must be done by trained personal.
    If you need a quote on repair ring the number listed on the owner manual.
    Regards.
  • Ginko
    Ginko Nov 18, 2009
    Hi, thanks for feedback, I was offline.
    If it is analog meter and the indicator does not move (infinite Ohms), then the probe is bad. The probe must be at room temperature.
    Self cleaning blowing the temperature probe is not uncommon.
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
My oven will self clean and the top will come on when in Broil but oven will not preheat in bake mode.
self clean and broil will make same heat for self clean
if this is a gas range then change bake glow ignition
more info can be yours send us full model # of range for more exact info of your range.
electric range will be element bake or broken burned wire
Dec 06, 2014 | Hotpoint Kitchen Ranges
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Preheats very slowly. Also, steam cleaning option seems to not be effective due to low heat. Is there more than one lower oven heating element?
For the oven their is 2 elements 1 for bake and 1 for broil,are each glowing red hot on the respictive settings of bake and broil? their is no trird hidden element. Plus i know manufactures come out with new features all the time,i attend factory trainging sessions a couple times a year but i am confused as to what the "STEAM CLEAN OPTION" IS??
THE SELF CLEAN cycle utilizes both elements to clean the oven adding steam is a new one on me
Aug 21, 2011 | Maytag MER7775W Electric Range
Sears (Kenmore) drop-in unit, Model 911.4698815. Ran the self-cleaning cycle - now it's showing Error Code F3 and neither the bake element nor the broil element will work. Any help would be...
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^$#@
Sep 12, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
The elements will not heat up on bake.
The problem is the Bake heating element. This is easy to check and usually inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing. It may be a different model but the testing and replacement will be the same. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
May 02, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Jennaire broiler doesnt work on slidein range after using self clean oven. Its only 14 mo. old
if just your broil element does not work and the bake element does work after using a self clean cycle then your broil element must have went out , self clean is a torture proccess for any self clean oven and it runs both elements at 500 deg. F, it may be still under warranty , if not then replace the broil element for the fix.
Phil
Jun 10, 2009 | Jenn-Air JES9860 Electric Kitchen Range
No heat on the upper oven bake and broil elements
I gather you are measuring voltage with respect to the chassis ground?
http://www.appliancepartspros.com/07-wiring-information-parts-for-maytag-cwe5800acb.html
Shows the internal wiring for the unit. The parts are rather expensive and some are no longer available.
Mar 22, 2017 | Kitchen Ranges
Self Clean cycle
Is this range electric? if so then does it bake or broil ok? if the answer to both the questions is yes!.. I don't think you need a new range, Cleaning cycle is based on both elements working along with other componets , if you are an handy man there is a mini manual on the range somewhere it could be inside the back panel, that will give you some info, if you are able to read the wiring diagrams ect, or could be your digital control, if you donot feel good about this and most don't I would call a good service Tech...
Guest 2
Jul 12, 2008 | Hotpoint RB757 Electric Kitchen Range
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
Kitchen Ranges Logo
53 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
