Question about Toshiba TheaterWide 62HM84 62" Rear Projection HDTV-Ready Television
Toshiba 62HM84 Starting Problem
Toshiba 62" DLP, about five years old. Already replaced bulb three times... Now TV cycles several times when starting. (Sound, no picture) When it does finally start, picture is very dim and it slowly brightens.
  • 81 Answers
You need a balist.
olso in the cust menu is a quick start mode . turn it off
Posted on Nov 18, 2009
I have a Toshiba 62HM84, The image shutdown and started a big noise on the back, like SHSHSIIISSHSSHSISIS, please what is this can I get the Tv replaced again or it ***** definitly?
Check the color wheel. It will be best to replace the light engine. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 22, 2015 | Toshiba TheaterWide 62HM84 62" Rear...
Toshiba 62hm84 dlp
Sounds as though the system may have overheated. Do you regularly check the filters and clean them? An airduster can also help to blow dust out of hard to reach places.
Apr 14, 2014 | Office Equipment & Supplies
Changed my bulb on my toshiba dlp 62hm84 andd it's still not working, no picture but have sound
Most likely you have a bad capacitor on the power supply board.
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV(warranty was expired ofcourse) and found four bulged capacitors. Many electronic companies were sold capacitors that failed in 2-5 yearsinstead of 10-20. The capacitors failprematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices. Bad capacitors can cause the problem you are having.
Here are some options . 1. 1.Have it fixed by a professional 2. 2.Dig into your TV, find PSB, Check for faultycaps. If you find some(bulged orleaking) bad caps replace the entire board 3. 3.Remove and then replace individual faultycaps. This takes some solderingskill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds.
Hope this helps
Dec 11, 2010 | Toshiba TheaterWide 62HM84 62" Rear...
My Toshiba 62HM95 62 in. HDTV DLP TV won't turn on...the green and red lights under the power button remain on and the red light flashes. How do I fix this?
Most likely, you need to replace your DLP bulb. The one that comes with your TV will last a few years max. The replacements seem to only last about a year. D:
Dec 08, 2010 | Toshiba 62HM95 62" DLP HDTV
My Toshiba 62HM84 won't start. I replaced the bulb and it still won't start. I replaced the ballast and the most I got was 1 second of light then off. The TV tries to start but still won't. Any...
I HAD THE PROBLEM OF BULB NOT TURNING ON. SOME PEOPLE SUGGESTED TO GET THE BULB CHECKED WHICH WAS ALRIGHT, SOME SUGGESTED TO CHANGE THE BALLAST WHICH WAS SMART BUT THERE WAS NO WAY TO CHECK IT OTHER THAN PUTTING A NEW ONE AND TESTING IT. I CALLED THE TECHNICIAN AND HE CHANGED IT BUT STILL NO PICTURE AND SAME CODE OF BULB NOT WORKING. THEN HE CHECKED FUSE ON POWER SUPPLY RIGHT NEXT TO WIRES BRINGING POWER SUPPLY TO BALLAST BUT IT SEEMED OK. HE DECIDED TO CHANGE IT TO SEE IF THIS FIXES THE PROBLEM AND WE CHANGED IT. WE TURNED ON THE TV AND WALLAH. SUGGESTION IS TO CHECK EVERYTHING BEFORE SPENDING MONEY ON NEW BALLAST OR BULB. 2 CENTS OF ADVICE, IT IS SOMETIMES WORTH TO BRING SOMEBODY WHO KNOWS WHAT HE/SHE IS DOING.
Aug 22, 2010 | Toshiba TheaterWide 62HM84 62" Rear...
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba TheaterWide 62HM84 62" Rear Projection HDTV-Ready Television Logo
1,009 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
