Question about Saniflo & Saniplus& Macerator Pump
The lid (not the motor compartment) appears to be pressed over plastic lugs. These seem hard to overcome. i am worried about breaking them
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
The bag lid seems very hard to close, I'm worried that I might break something if I force it. Mod RO 592183
Something is causing it to not align properly or it has dirt or debris causing it to not fit properly. Inspect and clean all areas to attempt to locate the problem.
Mar 05, 2017 | Vacuums
On a 207 G6 GT Pontiac retractable hardtop where is the sensor that gives the message top not secure. Top goes up and down seem secure will not allow the trunk to open with the key or door button
The retractable hard top is controlled by the folding top control (FTC) module.
Power Folding Top System Components
The power folding top system consists of the following components:
The folding top control (FTC) module
Hydraulic pump assembly; valve 1, valve 2 and motor
The hydraulic lines and the cylinders
GMLAN communication to the Body Control Module (BCM)
Open/Close request circuit to the driver and passenger window motors
Power and Grounds
Folding Top Main Power Fuse 30A
Folding Top Logic Power Fuse 20A
Ground G301 for the FTC module and G305
Folding Top Open/Close Switch (S15 and S16)
Rear Compartment Limit Switches
Rear Compartment Lid Release Switch (S3 and S4)
Rear Compartment Lid Release Switch-Front Hinge-Left (S11 and S12)
Rear Compartment Lid Release Switch-Front Hinge-Right (S9 and S10)
Folding Top Front Location Pin Guide-Left (S17 and S18)
Rear Compartment Lid Release Switch-Left (S19A)
Rear Compartment Lid Release Switch-Right (S19B)
Rear Compartment Partition Position Switch (S20)
Folding Top Front Location Pin Position Switch (S13)
Folding Top Front Latch Actuator Position Switch (S14)
Hall Effect Sensors
Folding Top Header Latch Cylinder Sensor (S1)
Rear Compartment Cylinder Extended Sensor (S2)
Your best bet is have the system checked for DTC'S - diagnostic trouble codes ! If it showed a message top not secured there is a DTC stored in the control module ! there are 24 possible DTC'S
May 29, 2015 | 2007 Pontiac G6 GT
1994 JaguarXJ6 Heat/AC Vent Troubleshooting
theres a small narrow plastic line from engine compartment going through fire wall witch supplies the actuators it gets hard over time and breaks or cracks when that happens the defrost vent will stay on . when this happens not enough air vauum getting to vent units.
Oct 03, 2012 | 1994 Jaguar XJ6
Need to replace hubs on a 2002 hyandai elantra gls, i an looking for a break down do i need a press?
No you do not need a press, you can take a flat head screwdriver and put it between the the rim and hub and prie it off or your hub might have plastic lugs holding it on is this cause you need to take them off, remember this saying lefty losie righty tidie.
Jan 30, 2010 | Hyundai Motor 2002 Elantra
Plastic piece came loose inside printer
The parking mechanism front spring has a tendency to come off in the C4x family of printers. Re-attaching it is a fiddly task not covered in the service manual. The pictures show: a general shot of the parking mechanism from the front; a shot of the actuation lever, illustrating where the front spring attaches to it; a view into the empty parking mechanism compartment showing where the lug is to which the bottom end of the front sprint attaches; a suggested tool for re-attaching the front spring, made from a large paper clip.
Proceed as follows, using a torch where necessary: lift the parking mechanism out its holder; be careful not to detach the drain pipe. Using the tool, attach one end of50f32be.gif54a9806.gif88c5669.gif9145528.gif the spring to the lug at the bottom of the parking mechanism compartment. Remove the tool and leave the spring laying at the bottom with one end attached to the lug. Replace the parking mechanism in its holder, with the actuation lever in place. Now for the fiddly bit! Peer into the compartment to locate the free end of the spring and get the tool on it. Pull the spring until you can put the free end over the lug on the actuation lever. Remove the tool.
Sep 15, 2008 | Epson Stylus C42UX InkJet Printer
How to disassemble acer aspire 3680 for memory ugrade?
Dear,
Generally you turn it over, unscrew the plastic compartments until you find the memory slot. Take out the old one and put in the new one.
Depending on the design, maybe only one slot is accessible. The other slot could be hiding behind the keyboard.. which would require further disassembly of the chassis.
When you take the plastic cover off to put in the memory be careful not to break the plastic lugs along the sides of the cover. As far as I can recall there are two lugs at the end of the cover and two on each side. They are fairly easy to break.
Cheerup and Be Happy always
Mar 17, 2008 | Computers & Internet
Washer is dead.
Check your washer plug carefully & the fuse in the plug..............may sound silly.
Jan 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Breaking Plastic Lugs
Do that
If it is under warranty it will be replaced
If it is not they will mention a price- which yoiu will not like and you will never but a Kodak again.
Or a reel of ducttape can come in useful.
Apr 24, 2007 | Kodak EasyShare CX4310 Digital Camera
Saniflo & Saniplus& Macerator Pump  Logo
67 people viewed this question
Top Saniflo Home Experts
Donni Steen
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
