Question about Dryers
Kenmore upright freezer coil leak find fix?
Kenmore upright freezer coil leak. model # 253.29082992.
R134A leaks out faster than repair man can put in. he says no way too find a leak in freezers???
How is this possible?! I bought quality KENMORE things to be more confident!
Can it be fixed???
    President:
  • 1,922 Answers
Yes,have him put in some tracer dye in the r134a refrigerant and you will find it quickly if its leaking as bad as you say
Posted on Nov 19, 2009
My kenmore upright freezer is running but not freezing is there a reset button
**Freezing gas may have leaked out at some point. Compressor works but freezer not freezing.
**Thermostat setting not suitable for freezing to occur; check and adjust
**Check whether evaporator at the back of your freezer is hot/slightly warm to touch. If it's not; call your freezer service/repair man asap
Oct 14, 2017 | Kenmore Computers & Internet
Need manual for kenmore model 28462---water on floor
Contact Whirlpool to see if a manual is available. Whirlpool makes Sears Kenmore.
Aug 15, 2015 | Kenmore Freezers
Kenmore upright freezer 255.29502010 temp wont go below 37 degrees while running. Inside tubing on back wall freezer but tubing on shelves is not working.
This freezer has a refrigerant leak, and will only get worse. I am looking at the identical Kenmore model and the refrigerant is so low that a little frost forms on the capillary tube. I doubt that it is worth repairing. I can do my own repairs, but finding the leak is going to be near to impossible...
Aug 24, 2013 | managemylife.com
Freon leak in housing? Can it be fixed
replacing leaking evaporator coil in this video on GE side by side
Jul 22, 2012 | GE FUF17SVRWW Upright Freezer
Kenmore upright freezer. continually runs. Temp. is 10 degrees f. I cleaned the dust off the compresser. Checked for leaks on the door seals no leaks. I have just now set the temp control from 4 to 3 and...
Power outages would not make a difference, but dust on the compressor coils would. The best way is to vacuum the coils and then spray with soapy liquid making sure not to spray anything electrical.
Dec 15, 2017 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer seems to be leaking freon. repair person told me that if there is a leak then it is up in the walls of the freezer and cannot be repaired. Is this true?
Yes, if the condenser coils are not on the back of the freezer or underneath they put them in the walls of the freezer where they are not accessable with out destroying the box to get to them. So if that is where the leak is then no it is not repairable.......if the leak is in the evaporator and if the evaporator is Alumium then it is also not repairable.
Apr 17, 2011 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmore leaking oil
Hi!!
You have a Refrigerant Gas (Freon) leak. Oil travels with the Refrigerant Gas thru the system, that's why you see the oil on the drip pans, if you look closely you should be able to know where is coming from.
For what you are telling me, it seems that the leak is of considerable size, I recommend to ASAP take freezer to a Kenmore authorized service station for a repair estimate, then you can decide to fix it or get a new one. If you call a repair tech, he will charge for the house call regardles.
Good Luck
Don't forget to rate this post.
Jun 04, 2010 | Woods Upright Freezer V1613RW3
Freezer will not freeze
replacing leaking evaporator on GE side by side. Watch this video to understand why its so expensive to fix freon leak issues.
Sep 25, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
Chest Freezer not cooling
Please don't rate this solution, as anything but FixYa brings my rating down, but here's what you've got:
You have a refrigerant leak (commonly referred to a Freon, but these days usually R134A refrigerant). Some refrigerant has leaked, so you are still getting some cooling, but there is not enough refrigerant left to cool throughout the entire evaporator coils. This is NOT a repairable condition, as the coils are foamed in place and not accessable for leak repair. If this unit is under 5 years old (typical sealed system warranty) the manufacturer will most likely replace your freezer with a new one. If over 5 years, you are out of luck. Buy a replacement freezer.
Oct 12, 2008 | Whirlpool 10 cu. ft. / 283 liter Chest...
Dryers Logo
197 people viewed this question
Top Dryers Experts
