Question about Car Audio & Video
My subwoofers are moving but no bass is coming out i can plug one in to amp and it pounds and bass comes out but two it doesnt. its weird
    Problem Solver:
  • 5 Answers
You have to change the channel on your amp and if you cant then you may have to bridge your amp or you may just need to tune your amp right
Posted on Nov 19, 2009
I have a set of subwoofers in my car powered by an amp with capacitor all 3 years old. A couple weeks ago I encountered a problem where my system will suddenly emit a weird loud humming noise (similar to...
try taking out the capacitor and wire the amp up with out it. it sounds like the cap is back feeding or discharging voltage when it should not be . if you reinstall the amp with out the cap and noise goes away buy a new cap or do away with it .
Oct 29, 2010 | Rockford Fosgate T600-2 Car Audio...
Logitech Z-2300 subwoofer/Bass volume cannot completely shutoff
Make sure the wired remote is connected completely and if that doesn't work try putting a pillow or a pile of blankets to cover both the subwoofer driver and the air port on it and that should reduce the sound coming from it. Also if it is in a corner or on a solid floor like wood or tile i would move it to a less enclosed space with carpet or a rug. Thats all I got I hope that helps.
Feb 05, 2010 | Logitech Z-2300 Computer Speakers
Amp is on, but sub wont produce any bass
Make sure the subwoofer is set to low frequency, make sure subwoofer and bass are enabled on the headdeck. Make sure the gain is turned up on the amp, make sure the rcas haven't come out of the back of the head deck.
Aug 04, 2009 | JBL GTO14001 Car Amp
Music is coming through my sub as well as bass
your amp might have a low pass filter and a high pass filter make sure it is switched to low pass and that should prevent music from coming out of the subs and just alow the bass too
Jun 11, 2009 | Car Audio & Video
Sound is coming out but no bass
Make sure that the rca cables that you have coming out of the deck to the amp arent switched to highpass(no bass) and check the amp and make sure that the crossover is set to lowpass(LP) see if that helps
May 30, 2009 | Alpine Type-R SWR-1042D Car Subwoofer
My car subwoofers work, but theres no bass
turn them off and carefully push in on the cone (gently) and listen for scratching or scraping- push strait in and they should flow freely in and out if they DO without feeling or hearing scraping the subs are probably ok, next its either the amp is not powerful enough or the box is not soundly built, by that i mean its too small for the subs- is the box ported or sealed? if ported try plugging off the vent temporarily and see if bass increases if it does i would permanently seal the box
Mar 13, 2009 | Kicker 06CVX122 12" COMPVX Subwoofer,...
I turned my 15" L7 kicker and smoke started to come out the box
As stated before, knowing the impedance of your subwoofer would really help the situation. Either way the link I have provided is to your subwoofers manual (Incase you dont have it)
But since you have said it has smoked, if it still works I recommend turning the bass boost down (Bass boost causes alot of heat within the subwoofers voice coil and even within the amp itself and should never be maxed out.)
Here is a link to your manual for the subwoofer.
http://www.kicker.com/sites/default/files/SoloBaricL7Series.pdf
So as a solution to your issue, keep your bass boost turned down. You should almost never need it if you have tuned your amp correctly (You have a very serious subwoofer there)
Consider yourself lucky if your subwoofer is still working without issues.
Feb 09, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Constant sound from subs
I Had the Same Problem I just unplugged my amplifier changed the fuse, also i had a fuse in the battery cable and changed that, unconnected the RCA wires and plugged them back in and then put new fuses in and plugged everything back into the amplifier and it worked again. If that doesnt work get back to me i will try to help you.
Jan 09, 2009 | MTX RT2200 Car Audio Amplifier
Bass sounds only
That is tricky one. Did you try adjusting the EQ on both the stereo and the amp? Is the Mute turned on because it will act like that? Is both rca jacks plugged in on stereo and amp?
Aug 20, 2008 | Alpine CDA-9856 CD Player
Car Audio System
Yo the main amp wire might not be thick enough so when drivin its not drawin enough power give me some more info i maybe able to help more
Mar 22, 2008 | Audio Players & Recorders
Car Audio & Video Logo
215 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
