Question about Nokia 6015i
Phone works but display screen is blank...so I cannot retrieve or see numbers saved on my 6015i nokia phone. All my speed dial numbers are not retrievable if I can't see them. I can dial out (if I know the number) but I can't see the number I'm dialing. I can receive calls, but don't see the number being received. Is there a little bulb or something inside the phone that can be replaced?
The caller id doesn't store all calls; HELP
sadly you have to save them ,it is not automatically saved
Nov 23, 2015 | Mitel Lands Phones
Need nokia 6015i unlocking code
Do you need to Unlock it from service provider lock...You can visit the site
Prounlocking.com/nokia-6015i/rs8wp9/ get the unlock code and unlock NOKIA 6015I easily...
Oct 14, 2012 | Nokia 6015i
How do I set my speed dial numbers?
Which ones? System speed is programmed from station 10 or 11 and goes in the 6xx's, depending on your version of software. The start is FEATURE 00 FEAT 6xx and dial the number You can continue programming more numbers by pressing FEAT 6xx or Feat 00 to exit.
Personal speed dial numbers are programmed similarly, except they are in locations 80-99 on each phone and can be programmed from the phone if it's a system phone.
Auto Dial buttons use blank buttons on your set. Feature 00 pressing the button and dialing the outside number store those. Again, Feature another button will let you program another button, or Feature 00 ends programming.
Carl
Jul 12, 2011 | Lucent PARTNER18 Corded Phone
Nokia n96 broken blank screen
I have a nokia n96 and i dropped it and the flip screen came away from the phone and ripped the strip connecting phone to flip sceen. how do i repair so i can retrieve my contact numbers
Sep 11, 2009 | Cell Phones
Can I take the plate cover off my Nokia 6015i mobile to dust the display screen?
This is very easy. Take the back off the phone. Then turn the phone upside down and with the key pad facing you, grasp the bottom of the faceplate with your right thumb and pull outward, while at the same time wiggling. Do not worry about the snapping or cracking sounds, that is normal.
Be very careful on cleaning the LCD. They are sensitive and use a lint free rag.
Apr 15, 2009 | Nokia 6015i
Nokia 6030 display gone.....
Try to connect to computer then try to get the contacts ..
Jan 11, 2009 | Nokia 5200 Cellular Phone
Sony Ericsson Z525A-COPY PHONE NUMBERS TO SIM CARD -BLANK SCREEN
to retrieve your numbers you would need to follow these key strokes...
center, toggle down (1 time), center, toggle up (2 times), center, toggle down (5 times), center, toggle down (5 times), center (3 times)
then wait for quite some time...it takes a while to copy all of the contacts...I would say anywhere from 5 to 10 mins...
this should work to save your contacts.
To save your pictures (and any other data you might want to retrieve) you could buy Sony's data cable2.gif for the z525a. I haven't tried this but it should work since that is what the cable is for.
Its called a DCU-60 USB data cable, and is listed as being compatible with the z525a.
Dec 26, 2007 | Sony Ericsson Z525a Cellular Phone
Slightly damp
Yes your LCD is damaged by liquid, replace it look in the net where to get parts for it. Try trademe.
Jun 12, 2006 | Nokia 6015i
Nokia 6015i Logo
89 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
