Question about Garmin 12CX GPS Receiver
A garmin nuvi 200 was given to me but the battery dies out very fast..within 5 minutes after fully charged. I found an replacement battery on Amazon, but I can figure out how to open the GPS to replace the battery.
    Problem Solver:
  • 7 Answers
On the back of the unit under the model/serial # tag there are 2 screws, if you press your finger along the tag you can fill the indentations.
You will need a #5 star screw driver.
Using a plastic tool (I use a plastic cake knife) or you can buy a proper opening tool, carefully begin sliding it along the seam starting at the card slot. Keep in mind that the back cover overlaps the front cover. The front cover has small buttons every so often to secure it closed so a little pressure is needed, don't pry. Be gentle around the switch.
There are 2 wires that you need to unplug after it is separated, With the back up, open it slightly and use tweezers and unplug the speaker terminal, don't pull on the wire. To get to the battery wire you need to remove 4 screws that hold the circuit board to the back cover. Just remember the LCD connection ribbon wire is very fragile and Static can damage the board so always touch yourself to ground before working inside. good luck.
Posted on Dec 03, 2009
My gaRMIN NUVI 200 lost it's maps information. How do I recover the information. thanks
You can try contacting Garmin and seeing if they will allow you to download the map again. The file that you are looking for on the Nuvi's flash drive is "gmapprom.img". It should be within the Garmin directory on your Nuvi (using PC to Nuvi USB cable). The file will be very large, around 1GB. More information on missing maps can be found here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
Apr 19, 2014 | Garmin nuvi® 200 Car GPS Receiver
How do you download a map to the Nuvi 200
Here is what you need to do to update the map your Garmin nuvi 200; first make sure the unit is fully charged, then go to the Garmin web site and register your product. Next download Garmin Updater and connect your nuvi with a USB cable directly to your computer and not thru a USB hub. Let the update go directly to the GPS and not a folder. It will take a few hours even with a fast internet connection. When done follow the instructions on your screen. I have attached a link to the Garmin site. Thanks for using FixYa
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
May 16, 2011 | Garmin nuvi 200 Car GPS Receiver
How do I get free map updates?
If the unit is new you get a free map update within the first few months after that they will charge a fee, but you can still update the unit for software and fixes.
Here is what you need to do to update the map your Garmi nuvi 200; first make sure the unit is fully charged, then go to the Garmin web site and register your product. Next download Garmin Updater and connect your nuvi with a USB cable directly to your computer and not thru a USB hub. Let the update go directly to the GPS and not a folder. It will take a few hours even with a fast internet connection. When done follow the instructions on your screen. I have attached a link to the Garmin site. Thanks for using FixYa
May 16, 2011 | Garmin nuvi® 200 Car GPS Receiver
My Garmin nuvi 205w turns itself off. I switch it on, fully charged, and go through steps, first screen loading maps, press "agree" on next screen, picked address (recently found), map comes up with...
Sounds like your battery is getting weak.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility probably at Garmin.com. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Nov 17, 2009 | Garmin nuvi 205W GPS Receiver
My Garmin Nuvi 200 won't turn on/fully charged
If it is not charged it will not turn on. If you have a bad battery (which is the case if it won't fully charge) your only choice is to return to Garmin.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device. Go here for repair:
http://www8.garmin.com/support/outofwarranty.html
Aug 12, 2009 | Garmin nuvi 200W GPS Receiver
Nuvi 200 when charging never says charging complete .
HI, I have the same NUVI. Mine does the same. I haven't had any issues with it. It still charges fully when I unplug it.
Jul 25, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 765 lithium battery will not hold a charge more than 15 minutes!
This is kind of a late response, but this post may help other people. I had the same issue and was ready to have Garmin exchange my battery until I called them today and spoke to Tech support. They helped me upgrade the firmware on the unit (didnt take long) and so far the problem has been resolved. I have had it on for two hours without fully charging it, which is better than before when it only stayed on for about 20 minutes. I recommend that people with this issue call them first since it appears to be a common issue with this model nuvi.
Mar 27, 2009 | Garmin BATTERY PACK, LITHIUM-ION, DC 20
Without plugged in my garmin nuvi 200 will not work
That means that you have to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Jan 21, 2009 | Garmin nuvi 200W GPS Receiver
Nuvi 200 -- won't power up after plugging into USB & Computer
Found out from Garmin Tech services how to reset the NUVI. Good to go.
Thanks.
Aug 05, 2008 | Garmin StreetPilot 2720 GPS Receiver
Garmin 12CX GPS Receiver Logo
161 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
