Question about Whirlpool Inglis IP4400 Washer
Estate Model #ETW4300TQ0 Will not spin - Whirlpool Inglis IP4400 Washer
Estate by Whirlpool washing machine Model:etw4400sq0 not spinning.
In my experience, a failed coupling is a likely cause
Dec 26, 2012 | Estate Washing Machines
Agitates and spins with clanking noise at the same time
The brakes are not engaged and the brake assembly will need to be replaced. Here is the part to order.
Below is a video to show you how to make the repair.
Nov 13, 2012 | Washing Machines
I have an Estate model TAWX700JQ1 washer and it won't drain the water out or spin.
Had the same issue. I replaced the timer part no 3953146 and that solved my problem.
Sep 10, 2010 | Estate Washing Machines
ESTATE TOPLOAD WASHER MODEL#TAWX700JQ3, DOES NOT SPIN FAST ENOUGH TO EXTRACT SUFFICIENT WATER FROM CLOTHE
Check if the belt is good and tight enough. If that washer uses a spring tensioner on the belt, make sure it travels freely and applies sufficient tension.
Jan 01, 2010 | Estate TAWS800JQ Top Load Washer
My etw4300tq0 washer will fill up with water, then stops.
etw4300tq0
Same problem... any help out there I see this post is over a yr old... it is now dec 29, 2010 and I have the same problem.
Mar 23, 2009 | Estate ETW4400VQ Top Load Washer
My washer doesn't spin
if it will pump out in spin cycle then the motor coupler is most likely bad / larryyb
Dec 07, 2008 | Washing Machines
Estate washer won't spin
If it still agitates and fills, this is most likely due to a faulty lid switch.
Oct 12, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
ESTATE TAWS800JQ1 WILL NOT SPIN
both of your problems are the clutch assembly if you are handy you can do this repair
Dec 04, 2007 | Estate TAWS800JQ Top Load Washer
Whirlpool Inglis IP4400 Washer Logo
160 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
