Question about Dell Inspiron 1525 Notebook
The USB connections all stopped workin... The device manager confirms they are all installed well?
  • Techy12 May 11, 2010
    have you tried rebooting the pc
  • 380 Answers
Well, check BIOS to ensure they are enabled. Reinstall the drivers. If that should fail, then you have a USB controller failure and you will need to replace the board. If your machine is under warranty, call Dell to have the board swapped. It usually can be done next day, and takes about an hour.
Posted on Nov 19, 2009
My computer is saying it is not connected to my Lexmark x2670 printer but I have everything connected. I need my printer! Help please.
Cannot Communicate; install USB; Install cable; installation USB; Installation cable; Cannot continue installation; Unable to press Continue; Unavailable Continue button; Continue button not active; Opaque Continue button; Gray Continue button; Continue button grayed out; USB connection not recognized
Solution
What you will see The Continue button is gray (i.e. Continue), preventing further driver stallation. connect the Installation Cable; using the supplied installation cable, connect to any USB port on this computer. Back Quit Continue There are several possible reasons for an inactive Continue button. Try the following suggestions in the order provided to resolve this issue: Action
1 Make sure the printer is turned on:
2 Confirm a solid connection of the USB installation cable on both printer and computer. HINT: The USB port is identified by this symbol:
3 Keeping Step 2 in mind, disconnect the USB cable from both printer and computer and then reconnect the USB cable at both ends.
HINT: Listen for audio alerts or notification icons or balloons in the Windows notification area. For example, or or .
4 If your computer has multiple USB ports, try connecting the USB installation cable to a different USB port.
NOTE: Passive or self-powered USB hubs may cause a problem.
5 If one is available, try connecting another USB device to the same USB port to see if it is recognized by the operating system.
6 If one is available, try a different USB cable that is under 10 feet.
NOTE: Some port replicators or docking stations for laptops or notebooks may cause a problem.
7 Confirm that you are installing the correct software driver for your printer model. For example, a 7600 Series driver works with the X7650 and X7675 All-In-One.
8 Turn off the printer, and disconnect and reinsert the power supply and power cord. Click here for image.
9 Click Quit to exit the installation. Remove the CD from the CD or DVD drive. Then reinsert the CD and try to perform the installation again.
To save time you can skip or close the hardware setup wizard if you have already completed these tasks. 10 Confirm that Device Manager recognizes the device. To open Windows Device Manager: Click on Start and then Run.In the Run dialog, type devmgmt.msc. Click OK.11 Next, disconnect the USB cable from the printer and reconnect it. Watch the Device Manager indow while you do so. The appearance of the items in the screen should change as Device Manager tries to recognize the device. Click here for image.Macintosh users: System Profiler is the Device Manager equivalent. Click here for instructions on accessing System Profiler, and look under Hardware > USB for the printer.12 Does Device Manager show a change in appearance?-If Yes, contact Lexmark Technical Support for additional assistance. -If No, there may be a problem with your computer and its USB support. The computer must recognize the USB cable in order for installation to work. 13 Reboot your PC and try these steps again.
Oct 02, 2011 | Lexmark X2670 All-In-One Printer
It does not recognize USB
Make sure that the driver for the USB is installed f your USB ports are installed correctly and enabled in BIOS, you will see Universal Bus Controller list in the the Device Manager. Double-click your USB in the Device Manager and a dialog box will appear. Click on the driver tab and update the driver. To get to Device Manager right-click on My Computer>click on Hardware>Device Manager. If your computer has a built-in USB device and does not detect the device through the Device Manager, confirm that the USB is enabled in the computers BIOS and that the BIOS supprts USB devices
Sep 01, 2011 | HP Compaq nc6000 Notebook
HP s7700n - all USB ports have stopped working. Device Manager shows drivers are okay. I'm thinking the bridge chip on the motherboard has failed. Any other ideas?
Try to to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 19, 2011 | HP Pavilion s7700n (5584788) PC Desktop
Acer orbicam stop workin i have an acer 5610 i download a new version but still not working, i need help
Hi there follow the instruction below.
1**. Double click my computer then double click USB Video Device. You can see your self then. If the USB Video Device not showing there then you have to install the cam first.
2. Power On the laptop/PC & after ready your OS for work just put your Webcam driver disk in DVD/CD RW/ROM. when its open, that time just select webcam driver and install it as per your operating
system(Vista or XP). So do it, and after finish installation ,restart the laptop. Your will see your cam is ready for use. Then follow again the first instruction.**
3. When you confirm after viewing your self in cam , then stop it. Now login on messenger & click to connect the cam from messenger. If any doubt then then ask me a again. Thanks & waiting for your feed back.
Thanks & waiting for your feedback
Mar 31, 2010 | Acer Aspire 5100 Notebook
I am having problems installing the printer drivers for the Epson 3880 on my PC. No USB 2.0 port will work. However, had no problem loading the drivers on the laptop.
Please make confirm that ur USB drivers are installed, you can check that through the device manager by following these steps:
Right click on My Computer then click on Properties then click on Hardware then click on Device Manager, here under Universal Serial Bus Controller check that all the drivers are installed properly...
Also make confirm that other device working properly on ur Laptop USB port.
If all these things working properly then there may be problem is with ur Printer.
Dec 03, 2009 | Computers & Internet
USB problems
Try this, Right Click on MY Computer and choose Properties on Context menu, When the properties windows open choose the HARDWARE tab, then click on Device Manager, You should see the yellow question mark on USB connection. Right click on it, and choose UNINSTALL, answer yes to confirm.
Now Click on My Computer in device manager scheme, then go to right top of device manager, As it mention as SCAN FOR HARDWARE CHANGES click on it. Your windows should detect the new hardware. Then if possible, install it as recommended by windows. If it doesn't work, insert your windows CD and direct the driver to your windows CD.
Good Luck!
Bionic23
Jul 13, 2009 | Toshiba Advanced Port Replicator III...
I have an inspiron laptop. the two USB on the side stopped working all of a sudden however when I checked the computer stated that they are working fine
may i know what device was connected to those ports?try connecting a mouse to the same ports and see whether it is detected.If it works well and fine.Other wise goto Control panel>>System>>Device manager>>Universal Serial Bus Controllers>>Here, delete all the USB Root hubs.If you are removing them using a mouse connected,then u might lose the mouse response after u delete the USB Root hubs.Please note this.Restart the system after deleting all the Root hubs and wait for a few seconds for them to get installed back.Restart again and confirm whether the issue is resolved
Mar 15, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
No usb
If your USB ports are installed correctly and enabled in BIOS, you will see Universal Bus Controller list in the the Device Manager. Double-click your USB in the Device Manager and a dialog box will appear. Click on the driver tab and update the driver. To get to Device Manager right-click on My Computer>click on Hardware>Device Manager. If your computer has a built-in USB device and does not detect the device through the Device Manager, confirm that the USB is enabled in the computers BIOS and that the BIOS supprts USB devices.
Dec 29, 2008 | HP Compaq nc6000 Notebook
USB
First of all, I recommend you to Uninstall the USB Devices from the Device Manager and reinstall the Chipset Drivers as per the instructions below :
Click on Start and then on Run.
Type devmgmt.msc in the Run Command box and click on OK.
This will open the Device Manager window.
In this, click on the + mark next to Universal Serial Bus Controllers which will display additional USB Entries.
Right click on each of the entry and select Uninstall.
Click on OK if you get any confirmation window. Repeate the same process untill there are no entries left under Universal Serial Bus Controllers in the Device Manager window.
We are done with uninstalling the USB Drivers from the Notebook.
Now, restart the Notebook and close any window which says 'Found new hardware'
Now, download and install the Chipset Driver in your Notebook from the link below :
http://downloadmirror.intel.com/8178/a08/infinst_autol.exe
Save the file in the Notebook and double click to install the Chipset Drivers.
However, if the issue with the USB Ports persists, I recommend you to check again with different devices to confirm if the issue is with the USB Ports of the Notebook itself.
If the Notebook doesnot recognize any of the USB Devices after installing the Chipset Drivers, you may need to get the USB Ports of the Notebook replaced or go with a PCMCIA USB Card.
Hope this helps....
Jul 09, 2008 | HP Pavilion dv4000 Notebook
Dell Inspiron 1525 Notebook Logo
37 people viewed this question
Alun Cox
