My 8 yr old Amana heat pump, model RHE48A2D with Honeywell progammable thermostat in heat mode has the blower running constantly. When there is a 6 to 8 degree differnce between room temp and thermostat setting compressor runs as it should, the closer it gets to thermostat setting, it will run about 30 seconds, blower continues to run until getting just cool air, about 5 minutes, compressor kicks back on for 30 sec., continues to do this, thermostat shows it has reached set temperature, but blower never shuts off. Control board replaced last winter, compressor replaced 4 months ago.
  • 1 more comment
  • leapinl369 Nov 18, 2009
    Lowering thermostat setting does shut off blower, relay and thermostat must be working.
    Guess my biggest concern is why the compressor would run such a short amount of time, by the time it comes back on all tubing and coils are cool. Appreciate any help you can provide.
  • leapinl369 Nov 20, 2009
    Fan setting is on auto. Disconnected thermostat wires at control board, outside unit and thermostat,
    no sign of any wires shorted together. Also checked for continuity on each wire, looks good.
    Put it all back together, set thermostat to 74, display showed room temp at 72. Compressor continued
    to short cycle, but room temp reached 74, listened for faint click in thermostat, never heard it, set temp
    to 72, couple of minutes later, heard click and everything shut off as it should. Make any sense that
    thermostat is not sensing set point as temp rises, but does when temp drops? Can't check fan relay
    control voltage as it is mounted on control board and I don't know which wires from thermostat to the
    board carry that signal. Terminal markings on thermostat and control board are pretty much the same,
    R,W2,E,Y1,B/O,G, and C. Wire colors match markings, except E is brown, and C is blue.
    Really appreciate any further help.
  • leapinl369 Nov 23, 2009
    Tried new thermostat, same results. Pretty much
    leaves the control board. Thanks for your help.
    President:
  • 1,515 Answers
Hi, It sounds to me like what you are describing is, that when it is 6 to 8 or so degree difference then the stat says, unit operates as it is supposed to but then before it satisfies the t-stat, it shuts the compressor down long enough to start cooling home back down, and then it will begin this short cycling of compressor until it reaches room temp. Backing up, you say the fan continues to run cooling the home down as the compressor is off and then starts the short cycling, and blower never shuts off, correct? OK, With the years I have spent repairing heat pumps, even though the compressor is new and still good, and I am sure the T-stat is not at fault her, but you say the Control or defrost board, (same board) Is at fault again! The symptoms you have described to me point to the board. I have seen them go bad in only a couple of days. If you would like you can pick up a new heat-pump stat and replace it to see what happens, and take it back if the problem persists, but I am sure since the fan runs as you say with the short cycling of compressor, board is at fault again. Maybe, just maybe they will give you a discount or a warranty of some kind. I wish you the best of Luck, and keep me informed on this, Sincerely,
Shastalaker7
Posted on Nov 21, 2009
  • Robert Horton
    Robert Horton Dec 17, 2009
    Hi, I wanted to thank you for the generous rating, and to thank you for using FixYa.com. I want to wish you and you're family happy holidays and if you ever need help again, please contact us here at FixYa.
    Sincerely, Shastalaker7
  • 612 Answers
First of all, check the fan setting on the thermostat. Make sure it's set on Auto rather than On. If it's set to the Auto position, you will either have a bad fan control, fan relay or the green wire is touching the red wire somewhere. The most common places this happens is at the condenser outside and inside the thermostat. I have found that sometimes when trimming grass around the condenser, a weed trimmer will hit the thermostat wire and strip the insulation off causing the wires to cross. Also inside the thermostat, the tech will sometimes leave a tail on the wires and they end up touching inside the thermostat. If they are not crossed, you have either a bad fan control or fan relay. This sounds like it's also making your unit short cycle which will end up costing you a large power bill. If you have a meter and would like me to try and walk you though checking the problem, respond back and I'll do my best although it's very hard to do this in this form. It would be easyer to try this by using the live help offered by this site. Good luck.
Posted on Nov 19, 2009
    Brigadier General:
  • 3,513 Answers
Hi
Replace the circiut board or the blower relay. It has probably a board.Turn the fan to the off position on the thermostat. You colud have a ilimit switch or a relay on the control board if it has one.
more elaborately....
blower auto shutting off and on is dependent to thermostat setting,if the thermostat acquired the temperature set it will shut of your blower,checking thermostat performance switch off unit, set this to a lower setting 1 or 0 switch on this should not runof course,if you set up this to 200 this will run until temperature reached to 200 it will stop.when you set up to 1 or 0 and the blower run thermostat is defective.
fan blower relay, if the 3 contactor is short or permanently engage while themostat reached acquired temperature your blower will still running,defenitely relay is defective.relay is dependent to thermostat switching,it supply holding coil terminal is to lock the 3 contactor to supply source to your blower.
so two common option while your blower run continously
1. shut off breaker, disconnect thermostat on two leads,its like a switch.then switch on breaker and run unit.
observe if run, your relay is defective,it was shorted on 3 contactor.
thermostat is the key to run your blower.
2. if the blower not run when you switchn onunit,then switch off again and try to short or connect the two lead using alligator clip on both side,or have it clip the terminals,then switch on again if the blower run,your themostat is defective,the high volatile of filler bulb was leak it always switch on,no play at all to off and on.
However the above will guide you and help you,if you understant flow of current in circuit.
Thanks for contacting fixya.com
Posted on Nov 18, 2009
Amana model gmh95070
Don't need the blue wire is common for the ac condsor unit what t-stat is it honeywell 4000 6000 8000 or one of rth models there is many t-stats as far as you saying fan stayes on check the auto / on section of the t-stst main wirers are RH/R-power W-heating Y-coolin G-fan
Mar 14, 2014 | Goodman Heating & Cooling
Dear Sir,I have an Amana Distinction 2.0 Ton heat pump, SEER 14 installed in my department about 4 months ago. I've noticed that the AC has a regular pattern running in the on/off cycle and that i
You need a tech. All 14 seer units have an X13 motor which speeds up and down on start up. A tech will adjust your tstat programing. Fan stays on after unit is done cooling to help drain water in cooling and cool off heat strips in heating,
Jun 15, 2013 | Heating & Cooling
Heat pump fan will not stop running
could be a heat sequencer. if the stat was bad it would run constantly in both modes.
Nov 12, 2012 | Heating & Cooling
My old thermostat has only yellow and red wires...no green and white like my new Honeywell thermostat installation instructions mention. Is this a problem?
The green wire is used to turn on the blower if you want constant air circulation. For heat only, the red and yellow wire will work as long as they are connected to R and W terminals on heating unit (or TH and TW on some models).
Nov 20, 2010 | Honeywell Programmable Thermostat Heater
New thermostat not cooling. Blowing heat instead.
Hello You have only 5 wires? multi stage if so ,is run by something else.Check that RH/RC is jumped out on new stat.Also check that O is not on the B terminal.If there is an A/B select switch set it to O.Emergency heat button dont matter as there is no wire to run it with only 5 wires.
Apr 17, 2010 | Honeywell Programmable Thermostat Heater
No Auxiliaty heat with new thermostat
The Vision Pro is a great t-stat and I have installed many of them with great results. I am wondering though if it is set up correctly. Did you go in and make sure that it is set for heat pump and for 2 stage heating? Look on the instructions how to get into the advance installer options. Go through that meanu and make sure that everything ig set correctly for your type of heating system and that it is set for 2 stage heating. From what you have here and I can tell the wiring should be okay that is why I think that it is in the t-stat programming.
Nov 15, 2009 | Honeywell Electronic Programmable...
I am renting a house which has a Trane heat pump
If it is a heat pump it may not have enough oomph.
Oct 20, 2009 | Amana PTH123B25AJ Heat Pump Air...
Honeywell YTH9421C1002, heat pump puts out cool air in heat mode
You have the stat programmed incorrectly or wired incorrectly there are alot of settings for installers in that stat and all of them have to be set correctly
Apr 05, 2009 | Honeywell Programmable Thermostat Heater
Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Nov 24, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
