Document sorter for Toshiba 3550
I have a used Toshiba 3550. The copier is asking me to connect the document sorter. How do I make the the copier recognize the sorter?
Thanks,
Jeff
  • jltesq Jan 11, 2008
    I do have a sorter.
    But how do I reset the machine?
    Thanks,
    Jeff
    I do have a sorter.
    thanks,
    Jeff
  • 77 Answers
While holding down the 0&8 keys turn the copier on.Key in19,check to make sure it is on 2.Then go to 37 and make sure it is on 0 for normal.Make sure that the wiring harness is plugged into the board.
Posted on Jan 11, 2008
Do you have sorter ?
İf not you should reset the machine
  • hasan kacan Jan 12, 2008
    Check the wire harness and check the fuse in the sorter .
    Open the sorter side cover.You can see fuser
Toshiba;Can't make a copy
C54, lost communication with the sorter, Check the sorter/ finisher, make sure the connections are firmly seated, even try unplugging the sorter from the machine and replug it in.(Power Off first).
Restart machine
Hope this is of some help.
Ed
May 19, 2009 | Toshiba e-Studio 350 Copier
Tip
ERROR codes Canon 6650
Canon 6650 E000 Thermistor E001 SSR E002 Thermistor, ht. Lamp thermal fuse or SSR E003 Thermistor, ht. Lamp thermal fuse or SSR E005 Fuser cleaning belt E010 Main drive problem E020 Toner motor, toner level sensor, toner hopper sensor E030 Counter E050 Duplex problem E203 Scan home problem E210 Lens home sensor E401 Document feeder paper pickup motor E402 Document feeder belt clock pulse problem E403 Document feeder main motor clock pulse problem E411 Document feeder sensor problem E500 Sorter/copier interface problem E500 An error is identified in the communication between the sorter and the copier E510 The clock signal from the motor is absent for 250ms or more E510 Sorter motor drive E513 The clock signal from the motor is absent for 250 ms or more E530 Sorter home sensor E530 The home position sensor (P17) fails to go OFF when an equivalent of 2560 pulses of the motor drive command has been generated E531 The stapler unit swing sensor (MS9) fails to go ON within 500 ms after the motor drive command has been generated. MS9 fails to go back OFF within 1000 ms after it has gone on E531 Stapler swing sensor E540 The lead cam home position sensor (P12) fails to go OFF within 2000 ms after the motor drive command has been generated. P12 fails to go back ON within 2000 ms after it has gone OFF E540 Sorter lead cam home sensor E541 Sorter lead cam home sensor E710 DC controller board E711 DC controller board E712 Document feeder problem
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 6150
Canon 6150 E000 Thermistor E001 SSR E002 Thermistor, ht. Lamp thermal fuse or SSR E003 Thermistor, ht. Lamp thermal fuse or SSR E005 Fuser cleaning belt E010 Main drive problem E020 Toner motor, toner level sensor, toner hopper sensor E030 Counter E050 Duplex problem E203 Scan home problem E210 Lens home sensor E401 Document feeder paper pickup motor E402 Document feeder belt clock pulse problem E403 Document feeder main motor clock pulse problem E411 Document feeder sensor problem E500 Sorter/copier interface problem E510 Sorter motor drive E530 Sorter home sensor E531 Stapler swing sensor E540 Sorter lead cam home sensor E541 Sorter lead cam home sensor E710 DC controller board E711 DC controller board E712 Document feeder problem
Screen showing sorter not ready. we have no manual
If it has a sorter, then there are 2 AC power cords that need to be plugged in. One for the copier and a seperate one for the sorter. Can you describe the sorter to me, please...does it hang from the left side of copier? Does it set on the floor and roll up to copier? I can think of 4 different models available for Toshiba 3550 copier.
May 09, 2009 | Office Equipment & Supplies
Need help disabling Toshiba 3550 sorter
I don't have operational sorter, but I can locate one for you if you are interested. Now, the solution to you copier is for you to go into the service mode and change the setting from sort to non-sort. This is the step you need to take. Go to the Service mode by doing the following.
1. Turn of copier
2. Push on 08 then Power on copier
3. enter 4 then
4. Push Print
5. Change the current value from 1or 2 to become 0
6. Push or press Interupt to reprogram the copier.
7. Then enter 09 to get out of the service mode.
Good luck.
Mar 23, 2009 | Toshiba Office Equipment & Supplies
Tip
ERROR codes Canon 3825
Canon 3825 E000 Low fuser temperature. Heat lamp, thermoswitch, thermofuse, thermistor, SSR E001 High fuser temperature. Thermistor, SSR, pinched wire E002 Low fuser temperature. Same as E002 E003 Same as E000/E001 E010 Same as E002 E022 Motor drive problem E030 Counter E202 Scan motor, sensor E204 Scan motor, sensor E210 Lens motor, sensor E220 Exposure lamp E240 DC controller (main board) E401 Pickup drive problem (might be Doc. Feeder) E402 Document belt drive problem E404 Exit motor (document feeder) E411 Document sensor (document feeder) E500 Sorter/machine communication problem E510 Sorter drive problem E530 Sorter home sensor E531 Stapler unit swing sensor E540 Sorter cam sensor E541 Sorter cam sensor E710 DC controller (main board) E712 DC controller or document feeder board
on Jan 18, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 3325
Canon 3325 E000 Low fuser temperature. Heat lamp, thermoswitch, thermofuse, thermistor, SSR E001 High fuser temperature. Thermistor, SSR, pinched wire E002 Low fuser temperature. Same as E002 E003 Same as E000/E001 E010 Same as E002 E022 Motor drive problem E030 Counter E202 Scan motor, sensor E204 Scan motor, sensor E210 Lens motor, sensor E220 Exposure lamp E240 DC controller (main board) E401 Pickup drive problem (might be Doc. Feeder) E402 Document belt drive problem E404 Exit motor (document feeder) E411 Document sensor (document feeder) E500 Sorter/machine communication problem E510 Sorter drive problem E530 Sorter home sensor E531 Stapler unit swing sensor E540 Sorter cam sensor E541 Sorter cam sensor E710 DC controller (main board) E712 DC controller or document feeder board
Sharp sf 2540 code F1
The F1 error code -- lost communication with the sorter. Are there secondary numbers after the F1?
Check connector cables on sorter and machine, check power to sorter. If those are fine then you are looking at a board problem. Also make sure that all covers are close properly. *** check cover between the sorter and machine*** ( you may have to pull sorter away from machine).
Jan 24, 2009 | Toshiba e-Studio65 Copier
Toshiba e 350 "close finisher door"
Finisher door is the sorter. there is a switch or door in the sorter not closed (or triggered)
Aug 12, 2008 | Toshiba e-Studio 350 Copier
Toshiba 3550 Document Feeder
1- you've already established that the jamming is coming from the sorter, since you said they jam as they exit the copier into the sorter bin.
2- check to see if the sorter is aligned, is one side higher than the other? is it crooked? are the wheels of the sorter turning as the paper exits the copier, is it plugged into the copier? does it show "connect sorter" when detached from copier?
if not the sorter board may be bad.It may need to be aligned ( not easy if not used to doing.)
Nov 25, 2007 | Office Equipment & Supplies
106 people viewed this question
k24674
jasbo
jasbo
