Question about Cell Phones
My phone tells me.....cannot charge, you must use
My phone tells me..... ''cannot charge, you must use a sony ericsson battery''. i have purchased a new battery, the phone boots up with the new battery, but when i try to charge it, i get the same message.
I have Xperia X 10 mini from Sony Ericsson. I left it charging overnight as I do every night since I've got it. And today when I woke up, I took the phone and instead of it being fully charged and
Chances are your phone got too hot during the night and overcharged the Lithium Ion battery. If those batteries are exposed to too much heat then they won't have the battery life they used to have. You need to purchase a replacement battery or contact your wireless carrier to see about getting another one.
Jan 24, 2012 | Sony Ericsson XPERIA X10 Cell Phone
Hi sir this is Anbarasu from Dubai. i purchased Sony Ericsson w995 last year October.its working good condition up to last month. Feb 2011 i had one problem with that mobile when i plug the...
Hi There,
Sorry to hear about your problem but I'm here to help!
It is fine to charge through your laptop.
If the problem persists then call Sony Ericsson.
Yours Sincerely
Lewis
Mar 28, 2011 | Sony Ericsson Walkman® W995 Cell Phone
My sony ericsson w810i phone is not charging through charger but is charging with data cable. The charging jack has been recently replaced. What is the solution for this?
sony ericsson phones have their own two-prong charger/data plug. You will need to purchase another AC charger, or you can purchase a plug that has a female USB and use that. Good luck!
Nov 06, 2010 | Sony Ericsson Walkman W810i Cellular Phone
My Sony Ericsson K810i Mobile have a problem. It shows the charge indicator nearby 99 % and if i speak a cll it goes very low and says 'attention Battery Low' and if i leave the phone to standby it shows...
Hi, problem can be solved. When a phone battery indicates 99 % of battery life and runs down so quickly, it is caused by damaged battery.
When a battery cell is damaged, it will display charging full but itwill empty. You will need to replace the battery for a better battery performance.
When a new battery is been purchase, make sure it is charge it is charge up to 4 to 5 hours before use.
Oct 13, 2010 | Sony Ericsson Cell Phones
In my sony ericsson P990i cellphone when i charge it it will not be charged.the charger and battery is ok .so please tell me what should be the problem and the way to solve the problem. thank you
check the pins on your charger and the connector on the phone. if they are in order, then u have a problem with your charging port which is on the phone. and if that is the case, you may have to replace the charging port. alternatively, you can get an external charger and use it to charge the battery. meaning you will get an extra battery to swap with the other when one is on charge. but if this problem deteriorates, it will be running down your battery,making it to discharge faster. Cheers!
May 20, 2009 | Sony Ericsson P990i Cellular Phone
My phone doesn't charge any way
How long have you had this phone? If you had this phone 1 year or more it might be the battery. I suggest that you go to your local cell phone carrier. Ask them if they have the similar phone. Tell them that your phone doesn't charge. Then ask them if you can borrow a battery for that phone and see if it charges at that store.
Jan 23, 2009 | Sony Ericsson K300i Cellular Phone
Battery charging problem
You can get a battery for the sony ericsson P990i mobile phone here - sony ericsson p990i battery
Dec 06, 2008 | Sony Ericsson P990i Cellular Phone
Sony ericsson w580i pink won't turn on
take back the phone to where it was purchased and get a new one or have it serviced
Aug 16, 2008 | AT&T Sony Ericsson W580i Cell Phone -...
Cell Phones Logo
53 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
