Question about Hotpoint Aquarius WMA42 Front Load Washer
Where can i find the moter brushes? - Hotpoint Aquarius WMA42 Front Load Washer
    Scholar:
  • 62 Answers
Hi.
They are located on the motor underneath the appliance.
you sometimes (depending on what motor is fitted) by tipping the appliance backwards about 45 degrees. Easier if there are two of you. One holding the appliance steady while the other crawls underneath. The brushes are fitted either side of the motor, usually 2inches long and secured by two screws each. Unscrew these and the brushes should come away from the motor. disconnect the wire connected to them and remove.
replacement is the reverse procedure
Good luck
aardvark Repairs
Posted on Nov 18, 2009
Where is belt located on Hoover wind tunnel vacum. And how to replace it. My brushes are not spinning.
Its usually located underneath the body of the unit, turn it upside down and you should see the beater brush. You need to open the bottom cover to get at the brush and drive belt.
Mar 25, 2015 | Hoover U8126-900 Wind Tunnel Dual V...
Sparking moter and smell of burning
will be a good idea to go the repair shop for testing and repair.
you must test the Motor for bearing,brushes, winding faulty, etc.
Of course and clean hoses, and any parts from any debris.
God bless you. Use the common sense.
Sep 19, 2012 | Vacuums
Starter motor solenoid wont engage
There is condenser shaped part attched to the starter moter this is the part which makes the starter moter to spin and when it is stuck the moter does not spin you can check it by one person sitting in the car holding the key to start position and another one hit it softly with some spanner or something The starter moter will move there is a small gear in it which requires replace ment Or the other possible reason can be the carbon brushes in the starter moter are worn out or the place where these brushes touch on armature the place is worn out that Y ou will only come to know when you will take the moter away from the engine Lastly I hope you might have checked your battery that it is giving sufficient current to the moter
Aug 16, 2012 | 2003 Volkswagen Jetta TDI
Hi. Moter not working brushes ok how to test moter.
If you are certain the motor brushes are o/k, and making proper contact with the armature, then it is not possible to properly test the motor out of circuit, as it is electronically controlled.
Check all connections and leads going to and from the motor, particularly the leads at the motor block.
If all o/k, then it is going to be a faulty motor, or possibly a faulty timer.
You can find these listed on E-Bay.
Jan 05, 2011 | Hotpoint WD62 Front Load Washer / Dryer
Moter engaging wheels not turning
Hi Jimmy. Does your machine display and flashing lights, if it does, count the flashes between the pauses. This is a fault code. If you let us know how many flashes, we can help you.
It might be a stuck motor brush. Undo the caps and see if either brush is stuck. A light file with a fine file might help. Careful tightening the brush caps as they can crack if done up to tight.
Good luck. Neil.
Aug 02, 2010 | Electric Mobility Mobility Electric Power...
Spin wont work and machine wont spin cloths
The machine mite not be draing if so cheak the drain pipe to see if it is bloked or not installed properly. if the water drains out and you hear the moter running the belt might of gone. but if the machine if not making a nosie the moter might be gone and there is two things to cheak before getting a new moter 1 cheak the cables a blugged in sucurly 2 make sure the carbon brushes are ok if it seams all ok the moter might be broken or the control panel.hope this helps
Sep 02, 2009 | Bosch Classixx WFL 2066 Front Load Washer
My washer will not do the spin cycle
check the brushes on the moter and for brakes in the wiring if all fine the moter has gone get a replacement from ebay
Jul 28, 2009 | Washing Machines
I need to replace brushes on a hotpoint aquarius wm32
pull machine out and make sure u remover the plug completley it is still live with the plug in and switched off throught the netural feed
at the back take off the botom white pannel made of plastic look in side pull the belt off the moter
there should be 2 10mm bolts remove these and tap the moter and it should slide out
remove the earth wire and the moter harness plug and pull the moter out it will go you might have to turn it this way and that once out there is two screws holding each brush remove and put in the new breushes replace the moter
to put the belt on there is two screws on the lid one each side behind a oval blanking cover these are hex head screws
once off put the belt on the moter pully first then on the drum pully and gide it on by hand turn the drum and the belt will spring on open the door and spin the drum by hand to make sure the belt is on correctley replace lid and back turn on power an try if this does not work the moter has gone try ebay i did for my hotpoint cheaper than trade on there
Jun 28, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
It starts to spins slowly but never gets going
it is the moter or it can be the module
the moter has three windings
1 distrabute
2 slow spin
3 fast final spin
check brushes first if ok get expert in
Jun 27, 2009 | Washing Machines
Walkera 37 remote heli
Swap over the two wires that go from the motor to the speed controller. NB. don't swap over the wires at the battery this will destroy the speed controller.
Feb 25, 2009 | Walkera Dragonfly #68 7 Channel 3D...
Hotpoint Aquarius WMA42 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
