Question about Broan-NuTone Allure II QS230SS Kitchen Hood
Air blows thru the Front of the fixture
My husband installed this hood with much care.  Upon completion we notice that air blows through the cracks/seams on the front faceplate of the hood.  Why is that?  He took it out once to see if there was a problem, went back in the attic to check things out.  He says the air comes through strong, but can't find out why the air blows through the front.  It's not just a little air, it's enough that it blows you in the face.
So can you tell me what this excess air is.   There's a fan and a hole.  Why isn't all the air just going straight up and out?  Is this pretty much a design flaw?
Appreciate any help.
  • MarshaVal Jan 11, 2008
    DH says he did that.  What's happening is 'excess air' is coming out of the front.  DH says when he is in the attic, it's quite a hefty flow of air being blown up.  So it must be this excess air coming from -??-
    But thank you for the reply.
    Any other thoughts?
    Thanks again,
    Marsha
    President:
  • 1,314 Answers
On theese if your going to vent them out the top you have to turn the fan housing so the front is vent is blocked if i remember right
Posted on Jan 10, 2008
  • robert samples Jan 11, 2008
    seal it wth silicone
Cant get antifreeze to pump thru the faucets
Why would you want to pump antifreeze into a faucet?If you are winterizing entire house, use a compressor to blow out all the water thru a hose faucet. If all the hose faucets have a backflow in it, pump the air through the shower arm. Start by blowing out the water heater. Then start at the closest fixtures to the heater and work away from the heater closing each fixture as you go. You will want to pour antifreeze into any traps and your wash machine and dishwasher should have some run through them by setting dishwasher on cancel and the wash machine on the spin cycle.
Nov 17, 2017 | Plumbing
Heat but doesn't blow like it should n air seepage somewhere
Check for blockage..there is a screen somewhere the air comes thru there. Should be on firewall or on cowl below the windshield/under the hood
Mar 06, 2014 | 2000 Kia Sportage
Fan blows no heat
With engine warmed up, feel of heater hoses under hood to see if both are warm (careful don't burn yourself). If they both are warm, flapper door which directs airflow through heater is not working, probably because the actuator is bad or you have a vacuum leak. Check line under hood which goes to vacuum reservoir for vacuum, and check one way valve(check valve). Replace any old soft or cracked vacuum lines.
Feb 15, 2014 | 2003 GMC Yukon XL
I have 1994 Chevy Lumina 4dr 3.1 Multi Point, Front W/D, F1, 6cyl. My air conditioner was blowing warm air @ 2mos ago & my husband added freon & a/c began blowing cooler air but, not as cold as...
You have a Freon leak because all the fittings, seals, coils rubber, compressor seals and entire AC system will need to be checked out by someone that can find the problem and resolve them or you will never get this fixed. A/C in cars get hot in the summer and cold in winter and all the seals dry out. The system needs to have all the air and moisture pulled out before any Freon in charged into repaires A/C unit or the system will not cool properly.That is the only way to resolve this Tammy, Thanks Sea Breeze
Jun 15, 2013 | Heating & Cooling
03 buick century, ac control knob blows out on all vents regardless where I position it. David
This usually is related to the vacuum reservior tank/cannister or the hose leading to that chamber. Any other vacuum hose leak could cause a similar problem depending upon it's location.
The hose leading to the cannister is usually just a thin single hose/tube leading to the cannister. The system allows vacuum to build up in the vehicle and maintains vacuum on the A/C system under heavy acceleration where a loss of vacuum would cause the A/C to change operation (switching from defrost to other venting and vice-versa) due to the loss.
You could have a cracked vacuum hose, or a cracked cannister.
You can use regular carburetor cleaner in a spray can with a nozzle, and carefully spray the vacuum lines on your vehicle when idling, and should notice a change in RPMs if you spray near a leak. Only spray a small amount at a time and let the engine compartment air out between spraying/testing since this is a flammable product.
This should lead you to identify any leaks.
Mar 28, 2012 | Buick Century Cars & Trucks
1998 s10 pickup a/c only blows thru defrost vents. only wont blow thru vents
Check for cracked/leaking vacuum lines under the hood. I know that doesn't make sense but the mechanism for shifting the air flow is controlled by vacuum.
Mar 19, 2012 | Heating & Cooling
My A/C stops cooling and blows warm air when vehicle is idiling for an extended period of time such as sitting in traffic. Is there any other solution other than adding an auxiliary fan in front of the...
It appears you know why your ac starts to blow warm air...not enough airflow thru the condenser. A aux fan would definatly fix this but two things you can try. Take compressed air and blow out the condenser but not from the front side... blow from the engine side. Small dust particles will collect inside the condenser over the years and pack in restricting airflow. Hopefully this takes care of it.
The other thing is to have your fan clutch checked it may be acting up on you which will also not pull enough airflow thru the condenser. If all else fails say hello to a electric cooling fan. Good luck!
Feb 08, 2011 | 2002 GMC Yukon Denali
Broan-NuTone Allure II QS230SS Kitchen Hood Logo
633 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
