Question about Microsoft IntelliMouse Explorer Bluetooth Wireless Optical Mouse, Retail Pack (MOMS60)
My Microsoft Bluetooth Mouse will not stay connected to my system
Problem
My Bluetooth Mouse will not stay connected to my system. I replaced the batteries after the system let me know they were low. When I reconnected the mouse, the system finds the mouse and tells me it is "connected" . . . then, a second later is says "not connected".
Background
I've had the same configuration for 2 years. The only recent system change was an update to Windows Media Play - from v10 to v11 immediately prior to replacing the batteries in the mouse. The keyboard continues to work just fine. It is recognized by Windows (Bluetooth Devices).
When I add the mouse (using the Bluetooth Device Wizard) it searches and finds the mouse (new device). I select "Don't use a passkey". The systems connects to the mouse and then I "Finish". The mouse now shows up in the Bluetooth Devices window. But, it does not show a status under the device - neither "connected" or "disconnected". If I close Bluetooth Devices and Reopen it, the mouse is no-longer listed as a device - only the keyboard shows up.
I've gone through the routine of adding the mouse about 5 times - changing batteries, rebooting, etc in between each attempt to get it to stick.
Any assistance in solving this issue will be greatly appreciated.
Device Hardware:
  • MS IntelliMouse Explorer for Bluetooth
  • MS Keyboard Elite for Bluetooth
  • MS Bluetooth USB transceiver
Environment:
  • HP Media Center PC
  • Pentium D, 2.80ghz
  • 3gb Ram
  • 1tb HD (300mb free)
  • WinXP, SP3
1. Go to Start->Run and type in "services.msc" and click OK
2. Find "Bluetooth Support Service" in the list of services and double click to open the properties window
3. Click on the "Log On" tab and select "Local System Account" for "Log on as:"
4. Click Apply and OK
5. Right click on "Bluetooth Support Service" and select stop then right click on "Bluetooth Support Service" again and select start
6. You may need to reconnect your bluetooth devices; everything should be working now.
Posted on Mar 09, 2010
My bluetooth Dell WM524 mouse does not stay connected
This may help you, although did not help me:
http://support.microsoft.com/kb/2758967
Jan 24, 2014 | Gear Head BT9500BLK Bluetooth Wireless...
How to connect Microsoft Bluetooth mouse 5000
Please refer to the below KB article, this will help you.
http://support.microsoft.com/kb/952818
Please rate if you like..Thanks
Aug 20, 2011 | Acer Aspire One AOD150-1920 Netbook
I put in new batteries but no luck. No lights go ...
Answer:
With the buttons toward the top:
The top LEFT slider button is for power. Slide toward the outside for ON. Light on top of mouse turns green after about 1 second, and stays green for about 10 seconds (assuming the batteries are okay). When the batteries are failing, it blinks red.
The top Right PUSH button sends a connection signal to the PC. When pressed, the indicator light on the top flashes green and red, indicating the special connection signal.
This is the mouse side of the equation (good batteries, slider turned on, connection button pressed and released.).
NOW: the PC must have a working receiver, with drivers installed, and Bluetooth software installed. it sould detect the mouse. If it asks for a passkey, say none (mouse doesn't need passkey).
You should not need Microsoft Intellipoint. it doesn't have a configuration for this particular mouse model anyway.
Good Luck!
May 21, 2010 | Microsoft Bluetooth 5000 Mouse
What is the pairng code for mouse 5000 ?
  1. Windows XP
  2. Click Start, and then click Run.
  3. Copy and then paste (or type) the following command in the Open box, and then press ENTER: services.msc
  4. Double-click the Bluetooth Support service.
  5. If the Bluetooth Support service is stopped, click Start.
  6. On the Startup type list, click Automatic.
  7. Click the Log On tab.
  8. Click Local System account.
  9. Click OK.
  10. If you prompted to restart the computer, click Yes.
How to connect the Bluetooth device to the computer loadTOCNode(3, 'moreinformation');
  1. Press and hold the Connect button on the bottom of the mouse. If your device has a battery indication light, it will blink and alternate between red and green to indicate that the device is discoverable.
  2. On the computer, open the Bluetooth software. The Bluetooth software is typically located in Control Panel. For more information about opening the Bluetooth software, see the "How to open the Bluetooth software" section.
  3. Click the Devices tab, and then click Add.
  4. Follow the instructions that appear on the screen.
    A Microsoft Bluetooth mouse does not require a passkey to connect to the computer. If you are prompted for a passkey, select No passkey. If you do not get the No Passkey option, try to enter 0000 as a passkey by using your keyboard.
Apr 20, 2010 | Microsoft Bluetooth 5000 Mouse
Blinking red and green
Oct 28, 2009 | Microsoft Bluetooth 5000 Mouse
Microsoft blue tooth 5000 mouse stopped working
Deleted the mouse from bluetooth and then added again.found info at
http://support.microsoft.com/kb/894035/#top
Jun 13, 2009 | Microsoft Wireless Laser Mouse 5000
Laser mouse 8000 won't connect to blue tooth
try to check whether the drivers are properly installed
Mar 11, 2009 | Microsoft Wireless Entertainment 8000...
Cant install bluetooth drivers on my hp compaq nx 7400 notebook
Which operating system do you have on your computer? Windows XP or Windows Vista?
Windows XP
A detailed troubleshooting page for Bluetooth devices on Windows XP can be found here.
Windows Vista
If you have Windows Vista or that doesn't solve your problem. You can try typing in the name of your Bluetooth device you're trying to connect followed by drivers into google
For example, if I were trying to connect a Microsoft Bluetooth Notebook Mouse 5000 to my computer, I would type the following into Google: Microsoft Bluetooth Notebook Mouse 5000 Drivers
Feb 16, 2009 | HP Computers & Internet
Bluetooth
usally laptops have bluetooth not desktops ,,,,bluetooth is not the same as wireless ,,i know they work similar bluetooth is for short distance...when u set a blue tooth mouse up u must have bluetooth usb plugged into ur computer ...that usb adapter will act as your mouse connection ......
Dec 09, 2007 | Microsoft Wireless Optical Mouse
Microsoft IntelliMouse Explorer Bluetooth Wireless Optical Mouse, Retail Pack (MOMS60) Logo
2,306 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
