Question about Philips Gemini CDX-601 Pro CD Player CD Player
Does the CDX-601 play mp3 cds - Philips Gemini CDX-601 Pro CD Player CD Player
CDX keeps ejecting CDs some seconds after insertion
Replace the drive!!! I have six and this is the ONLY problem I see with these units!
Oct 08, 2009 | Nu Mark Numark Cdx Table Top CD Player CD...
Skipping all CDs
Laser is duff uses the old sony kss family i believe,easy to change and get on ebay..
Jan 02, 2009 | Yamaha CDX-393 CD Player
I am having problems with my cd player
I am unable to understand your problem clearly. Does it play 2 CDs and then stops reading the CDs or does it play only 2 specific Cds?
If it plays some Cds and not others, then it is possible that the lens has to be replaced. But before that, try cleaning the lens.
Use a good quality CD lens Cleaner CD.
Jul 31, 2008 | Sony CDX-M610 CD Player
Cant play New MP3 CDs on CDX-FM687
have you tried using another computer to burn them as some of the latest updates will give u this problem if not there are probably some compatability issues
May 23, 2008 | Pioneer CDX-FM687 6-Disc CD Changer
Cannot play my portable audio device with Sony cdx c500x
It will only accept audio from the bus in conections when a multi changer is connected and selected.
This is how I connect my mp3 player to my sony.
Swap multichanger audio outputs at the rear of the stereo for my mp3 player, press source to select multichanger.
Remember as I said, if there is not a control cable connected to your multichanger it wont wotk!
Aug 17, 2007 | Sony CDX-C5000X
MP3 files start skipping/popping after few minutes of playback
Sony say in the manual that if you record high bit-rate mp3's the sound may be intermittent. I feel this is due to the decoder having to move ALOT of bits around to play, try some makeing a disk with mixed rate mp3's on. e.g.) some 64Kbps, some 128, some 192, and some as high as you can get and see if there is any differ Luck
Mar 02, 2007 | Sony CDX-MP40 CD Player
Philips Gemini CDX-601 Pro CD Player CD Player Logo
88 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
