My Maytag dryer will not spin when I turn it on, although it starts to heat up. I checked the fuse box and nothing seems to be wrong there.
    President:
  • 1,922 Answers
Check the drum belt,to do this remove the lower front cover kick plate screws and then the cover will open up like a car hood,remove this then the top cover and see if the belt is broken or the belt tensioner is weak or broken and replace whats bad to get belt tension back to turn drum again
Posted on Nov 19, 2009
What is wrong with my dryer?
Check the vent line (when it is working) for for good air flow...residual heat may be tripping the overheat safety.
May 10, 2014 | Whirlpool GEW9868K Electric Dryer
Electrical on but dryer does not start
Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
Jul 28, 2013 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
Maytag Neptune Electric Clothe Dryer Model MDE6700AZW Problem: Drum will not turn, no heat produced. When I start the cycle, there is one audible *click* sound and then nothing: no heat and no tumble....
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 09, 2011 | Maytag Neptune MDG9700A Gas Dryer
My dryer just quit heating in the middle of of a heat cycle. checked for vent system lint clogging but air flow seems good. the whole gas valve system doesn't seem to operate now. is there a thermal fuse...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 12, 2011 | Maytag SDG2606A Gas Dryer
I have a may tag performa gas dryer. When I start it, it spins and heats but it spins very slow. I opened the top and checked the belt and it was tight and does not appear to be slipping. Is the motor...
  • There are a number of different problems which can occur with models of Maytag dryers resulting in them not heating and drying clothes properly. A variety of parts could have broken or been worn out over the course of the time you have been using your dryer or something could just malfunction, as appliances tend to do from time to time. Check warranty information before trying to repair the Maytag dryer yourself.
  • Bad Heating Element
  • Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
  • Broken Motor
  • Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itself.
  • Bad Switch
  • When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch.
  • please stay how helpful it
    Dec 21, 2010 | Dryers
    I have a MAYTAG MDE5500AYW drier that spins but doesn't heat up. Any recomendations?
    Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
    Jul 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
    Dryer does not heat up
    First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.  If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
    May 29, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
    Dryer too hot...no cool down
    no the thermal fuse has nothing to do with that,although it will open again if too hot and that may be why it opened in the first place.most high heat ,long dry times are the house ducting.try this experiment.remove your dryer from the house ducting and dry a load[it wont hurt a thing]if not as hot,then get that ducting cleaned.if still hot then make sure the inner dryer air ways are clean.your blower is spinning fine[not broken on the shaft]and also check with ohm meter,or visually that your heating element is not shorted to ground[then it by passes the cycling thermostat.if all those things good and still getting high heat i may replace the cycling thermo.but as a repairman i did not have to do that very often.most of the time it was the other possibles. i hope this helps abit God bless ,tom
    Feb 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
    Spins but no heat
    WHAT IS WRONG WITH YOUR DRYER?
    small_8_19.jpg For a detailed Dryer illustration, click below.
    Gas Whirlpool Style Version 1
    redarrow.gif Gas Whirlpool Style Version 2
    redarrow.gif Gas Maytag Style
    redarrow.gif Gas GE Style
    redarrow.gif Electric Whirlpool Style Version 1
    redarrow.gif Electric Whirlpool Style Version 2
    redarrow.gif Electric Maytag Style
    redarrow.gif Electric GE Style
    Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
    Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
    There's an error code on the digital display
    It doesn't work at all
    There's no heat
    It won't tumble
    Drying is too slow
    It overheats
    It seems to run forever
    It's noisy
    It won't start
    The light doesn't work
    My clothes smell bad!
    My clothes are marked or torn
    DON'T FORGET TO RATE;
    Apr 11, 2008 | Whirlpool LGR7646E Dryer
     Grubhead
    Grubhead
