Question about HP LaserJet 2820 Printer
Scanner error 5 - HP LaserJet 2820 Printer
    President:
  • 787 Answers
The problem is in the scanner section.There is too mush ash on the mirrors and scanner lamp.You can fix it just like disassembly the printer and pull out the scanner section.Open it cover and inside you'll see the mirrors.Clean the ash from mirrors using cloth which leaves no hairs.
WARNING! If you don't have a technical skills don't try to do anything.
If this not help you need to replace the scanner section.
Posted on Nov 19, 2009
Hp laserjet m1522f error 5 turn off and on
Hi, Error 5 is a Scanner error. When turning the printer on, have the lid up so you can watch the scanner movement. Does it move smoothly? It should go through a warm up and you should be able to watch the scanner movement. If there is a problem with the scanner, there isn't a lot you could do except. The service manual says the scanner assembly should be replaced. If it was my printer, I would try to take a closer look at the scanner assembly and check to see if the scanner unit is bound up somewhere, or maybe a drop of 3 in 1 oil on the scanner rails. Let us know what happens.
thanks
Oct 02, 2013 | Office Equipment & Supplies
HP Laserjet M2727nf Mfp Printer Scanner Error 8
The HP M2727 has a known issue with the scanner error 8 and bad formatters. HP has extended the warranties on this product. I suggest you contact them directly and they will most likely exchange the unit.
Nov 08, 2011 | HP Laserjet M2727nf Multifunction Printer
Scanner error 5
Scanner error 5 is caused by a bad formatter that in turn destroys the scan axis motor in the scanner itself. The formatter is covered under a warranty extension by HP but last time I checked they were no longer covering the scanner motor. Contact HP at 1-800-invent
Oct 13, 2011 | HP Laserjet M2727nf Multifunction Printer
Its showing scanner error 8 and 5
Hello, this indicates aproblem with the copier scanner assembly.
For more information follow the posted link.
Scanner Error 5 CLICKHERE
Feb 15, 2011 | HP LaserJet M1522nf Multifunction Printer...
Scanner error 5
Based on the service manual the Error: Scanner Error 5 doesn't exist. However 52 Scanner Error exists. If the scanner doesn't function anymore the recommended solution is to replace the scanner assembly.
Oct 20, 2010 | HP LaserJet 2840 All-In-One Printer
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
HP Laserjet 3052
i am getting scanner error 5 in my hp laserjet 3052, pls giv me the solution for the same
Jan 29, 2008 | HP LaserJet 3052 All-In-One Printer
Error 5
I can't seem to find a error code 5. What software are you using to scan? Did the error start right after your first? Had the scanner been working?
Jul 12, 2007 | Kodak i40 Path-Through Scanner
HP LaserJet 2820 Printer Logo
715 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
