Question about RCA Computers & Internet
I have an RCA Modem with an AC power input. 4 pin Can you tell me what voltage the input is and what frequency?
  • gphillips92 Nov 30, 2009
    I do not have the power supply.
    I asked about frequency because the transformer connected to the power input looks like a high frequency transformer. I thought there might be a converter in the power supply.
  • 603 Answers
It should be on the power adapter itself after output.
If your in the US it's 120V 60 Hz.
Why are you asking about frequency?
Posted on Nov 30, 2009
RCA dcm325 specs
The Installation and User's Manual [http://www.simplehelp.net/images/cable_modems/manuals/RCA_DCM325.pdf] says this modem can receive data at rates up to 30 MB/second in a DOCSIS-compliant cable network. It can connect directly to two computers simultaneously, one through the USB port and the other via Ethernet. The USB port software supports only Windows 98SE through XP, but may work with newer versions of Windows.
Operating temperature range is 0degreesC-30degrees C. For power input, the only thing I could find was a picture of the back showing "800 mA" under the AC adapter jack; the voltage input value is obscured by the plug in the picture. You should be able to read it on the modem itself, or the power adapter if you have the one supplied with the unit..
Jan 10, 2012 | RCA Televison & Video
Can you give me technical specs for LCD TV TH-L32E3A. Thanks
The proof copy of the Owner's manual includes the specs for the TH-L32EA and is available from: http://www.panasonic.com.au/Support/Customer+support/Downloads+and+documentation . Enter the model number under keywords and then click search (do not use the drop down menus).
Specifications
Power
Power rating AC 220 - 240 V, 50 / 60 Hz 0.33 A
Normal (Home) mode 42 W
Standby condition 0.2 W
Display
panel
Aspect Ratio 16:9
Visible screen size 80 cm (diagonal)
698 mm (W) × 393 mm (H)
Number of pixels 2,073,600 (1,920 (W) × 1,080 (H))
Sound
Speaker 160 mm × 42 mm × 2, 8 Ohms
Audio Output 20 W (10 W + 10 W )
Headphones M3 (3.5 mm) stereo mini Jack × 1
PC signals
VGA, SVGA, WVGA, XGA
SXGA, WXGA ······ (compressed)
Horizontal scanning frequency 31 - 69 kHz
Vertical scanning frequency 59 - 86 Hz
Receiving Systems /
Band name
PAL B/G Reception of Off air broadcasts
Digital TV 7 MHz VHF / UHF (Australia) free-to-air TV broadcast reception
PAL 60 Hz
M.NTSC
NTSC
Playback of NTSC tape from some PAL Video recorders (VCR)
Playback from M. NTSC Video recorders (VCR)
Playback from NTSC Video recorders (VCR)
Aerial - Rear Standard Belling & Lee connector
Operating Conditions Temperature : 0 °C - 35 °C
Humidity : 20 % - 80 % RH (non-condensing)
Connection Terminals
AV1
Input
AUDIO L - R RCA PIN Type × 2 0.5 V[rms]
VIDEO RCA PIN Type × 1 1.0 V[p-p] (75 Ohms)
COMPONENT Y 1.0 V[p-p] (including synchronisation)
PB/CB, PR/CR ±0.35 V[p-p]
AV2
Input
AV3
Input
Audio
Output AUDIO L - R RCA PIN Type × 2 0.5 V[rms] (high impedance)
Others
HDMI1 - 3
Input TYPE A Connectors • This TV supports "HDAVI control 5" function.
PC Input HIGH-DENSITY D-SUB 15PIN R / G / B: 0.7 V[p-p] (75 Ohms)
HD / VD: TTL Level 2.0 - 5.0 V[p-p] (high impedance)
DIGITAL
AUDIO OUT PCM / Dolby Digital, Fiber optic
Card slot SD Card slot × 1
USB 1/2 USB 2.0 TYPE A Connectors DC 5 V, Max. 500 mA
ETHERNET 10BASE-T / 100BASE-TX
Dimensions (W × H × D) 769 mm × 514 mm × 207 mm (With Pedestal)
769 mm × 480 mm × 75 mm (TV only)
Mass 11.0 k Net (With Pedestal)
9.5 k Net (TV only)
(See page 73 of the manual for the specs as a table - I used Proof 2)
I hope this helps.
Apr 20, 2011 | Panasonic Kitchen Appliances - Others
I accidentally knocked the AC adapter to my RCA DCM425 Cable Modem AC out of the wall outlet while at my computer desk. After plugging it back in, the lights on the modem flashed on momentarily, then shut...
You could have only a damaged power supply, please look in an Eectronics parts store another with the same characteristics (input and output voltage,current, plug type) and retest, maybe your actual AC adaptor is broken inside and that's why it doesn't power up your modem correctly.
Feb 19, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
What is the power supply for the hp 845c printer ? Thanks,
Electrical specifications NOTE: The HP Deskjet automatically accommodates the worldwide range of AC line voltages and frequencies. There is no on/off switch on the power adapter. Category Specification Input voltage 100 to 240 volt ac (VAC) (+/- 10%) Input frequency 50 to 60 Hertz (Hz) (+/- 3 Hz) Power consumption (maximum) 4 watts maximum when off
4 watts minimum when idle
45 watts maximum average printing (Printer carries the ENERGY STAR emblem)
Jul 16, 2010 | HP DeskJet 845c Printer
I lost the power supply and would like to know what voltage and amps in need in a power supply to operate the maxtor
Power Requirements
AC Input Voltage: 100–240 VAC
Input Frequency: 47–63 Hz AC
here is a link to the manual : http://www.seagate.com/staticfiles/maxtor/en_us/documentation/data_sheets/onetouch_data_sheet.pdf
Oct 30, 2009 | Maxtor OneTouch A01B080 80 GB Hard Drive
Input voltage for Boca 56K tidalwave external modem
There should be a input voltage and polarity (pin) diagram next to the power input socket. Normally 12 volt, but don't quote me on that as I just replaced my modem, like for like and the old one was 12v. and the new one 25v. so if you can eliminate your power adapters one by one by the manufacturers names on each, then thats your best bet.
Jun 05, 2009 | Boca Tidalwave 56K USB (MD56EUSB) Modem
My tram 2512 is stuck in waiting for AC mode, ac is clearly reaching the unit, both by shore power and genset. What could the problem be?
If you are referring to a Trace 2412 inverter, which series is it? An SW or a DR series? In either case, if it won't accept generator power, but the AC input indicator is flashing, the problem is most likely the generator output power is off frequency or voltage. Trace inverters will only connect when the AC input is within certain limits. I'd suggest checking the frequency and voltage output of the generator. If it won't connect to shore power, check the voltage from that source. Make the voltage checks at the inverter input terminals.
May 11, 2009 | Xantrex Technology Trace Series Inverter /...
Ac power adapter requirements
From the users guide:
Power specifications
. Power consumption: 50W maximum
. Source (Input) Voltage: 100 to 240 VAC*, grounded
. Input Frequency: 50 to 60 Hz
. Current: 1A maximum
* Figures are based on using the AC adapter that came with your unit (HP part number 0950-2880)
Her's a link to the user guide:
http://h10032.www1.hp.com/ctg/Manual/bpu03123.pdf
Oct 15, 2008 | HP OfficeJet G55 All-In-One InkJet Printer
Cable modem 315
Have a look at the link below for basic troubleshooting techniques for RCA modem
Troubleshooting DCM 315
Oct 13, 2008 | Computers & Internet
Computers & Internet Logo
146 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
george  peters
george peters
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
