Question about Fujitsu Computers & Internet
Unable to detect or use my cd rom - Fujitsu Computers & Internet
    Novelist:
  • 138 Answers
Is this in a desktop or laptop? I will assume it is in a desktop
This could be caused by the jumper setting on the CD ROM is the same as another drive in the PC.
It could also be a loose or damaged IDE cable / power cable to the CD ROM.
Open the case of the PC and verify the IDE and power cable are securely in the back of the drive and the IDE cable is securely in the motherboard port.
If there is a 2nd device connected to the same IDE cable, verify one is set to MASTER and the other is set to SLAVE. Cable Select (CS) setting can fail - placing both devices as MASTER/SLAVE will eliminate a failed CS logic.
If this is in a laptop, turn the comptuer off and remove the battery and AC power. Remove the CD ROM (if the unit can be swapped) and re-insert the drive back in the laptop. Reboot the laptop with the drive in the laptop and test.
Posted on Nov 18, 2009
3 Suggested Answers
  • 124 Answers
SOURCE: unable to boot win xp cd. not detected by compaq
Drive requires cd drivers to run Boot CD.
Some versions came with floppy disk to start cdrom drives, This will also require a floppy drive.
You may also try hitting f10 to enter bios setup make sure cdrom is bootable.
Posted on Mar 08, 2009
rmoseng
  • 77 Answers
SOURCE: unable to detect or use cd rom
Possible solutions are:
1. A problem is CD is conflicting with a hard drive --- On the back of each of the older IDE hard drives and CD ROMS are jumpers. They denote if the unit is a "MASTER", "SLAVE" or "AUTOMATICLY CONFIGURED". If they are set wrong the CD-ROM will not appear. You would also notice the computer would boot slowly. A quick check of the bios would reveal the jumper settings.
2. The Bios could be set wrong
3. The CD-ROM could be bad.
4. The CD-ROM could have the power or data cable not seated right.
5. The power supply could be out on this leg. Try another leg of the octopus for power.
This data is assuming you have a IDE CD-ROM and Windows XP or Vista.
If you have a older version of Windows or a MAC than it could be other things wrong.
Good Luck
Posted on Dec 15, 2009
Lost cd driver so unable to update driver in device manager page.. where can found free download of that driver
cd driver ??? what OS u using ? what brand pc cd roms/dvd roms normaly install them self with windows drivers ?
Jan 27, 2010 | A4tech PK-635 Webcam
Unable to detect or use cd rom
Good Luck
Nov 18, 2009 | Fujitsu Computers & Internet
Getting problem in formatting the IBM PC
check if the cable from the cd rom connected to your ibm pc if its ok , also check the master, slave configuration pins into the back of your cdrom. make sure that theres no conflict between the hard disk and the cdrom. Your cd rom may probably cannot be detected. make sure that it is working first. then install the hard disk. The hard disk must be in primary master and the cd rom must be in primary slave. then try booting it to your cd rom. also, try checking if your windows xp setup disk is bootable, it means that it can boot from cd rom. PM me if you have other experiences after doing what i adviced. Thank You.. heres my email. jmizpahadonai777@gmail.com
Aug 07, 2009 | IBM Thinkcentre 8185 PC Desktop
To burn dvd-r on ASUS CB-5216A CD-RW/DVD-ROM.doest it supports the burninig of DVD-R
have the same same problem unsolved yet. it's not on the software actually, it's in the installation of the drive...
May 29, 2009 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
Dell c640 Latitude , CD ROM detected but no content displayed
please check it in different CD or DVD. then check it in a another cd drive attaching to ur laptop. otherwise format your laptop it may be infected with some virus
Mar 20, 2009 | Dell Latitude C640 Notebook
Unable to boot win xp cd. not detected by compaq presario 5000 series interneal cd rom LTN 403 DQ24
Mar 08, 2009 | Computers & Internet
DVD/CD-rom 52X cd-rom unable to recognize DVD
the lens inside the cd rom wil hav to be cleaned
then it wil detect
if the problem still remains then u have to replace the lens inside the cd rom
Mar 07, 2009 | Sony (CDU5212) Internal 52x CD-ROM Drive
Cannot Load Windows/Windows Setup Does Not Detect Hardrive
Harddrive is most likely bad get another and install windiws... if you found the right place they could "ghost" your information onto the new one!
Feb 01, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Does not read cd's
the cd you inserted was not compatible with your cd rom. inorder to read all cds you must use cd roms that supports up 60x speed your only have 24x speed thats y it cant read cds that has above 24x.
Jan 21, 2008 | NEC CD-2800D (cd2800d) 24x CD-ROM Drive
Cant play DVD on CD-RW/DVD-ROM Combo Drive
Assuming you have tried different makes of cd or dvd disks, it's a classic drive failure problem where the laser can no longer burn or read dvd's, but may still be able to read cd's only. You will have to replace the drive, they are quite inexpensive, and very easy to fit.
Aug 10, 2007 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Computers & Internet Logo
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
