Question about Tools & Hardware - Others
The pressure is at 0 and it should be around 0.7 to 0.9 for me to restart the boiler. how to proceed?
  • 10,865 Answers
Hello. If your pressure is at 0, you will have to add more water to the system. It is possible that the fresh water valve was turned off once the optimum pressure was reached before. Now you will have to turn the fresh water valve on until the optimum pressure is reached again.
Posted on Nov 18, 2009
Testimonial: "thanks Justaskjoe. I'll still have to find the right one to turn on the fresh water supply...still on the learning curve!"
My astra espresso mega 2 s boiler pressure is 0.
It is possible that the safety thermostat on the boiler has tripped. Reset safety thermostat and turn machine on. If reset is not tripped then it could be the element or the pressure stat are damaged.
Aug 01, 2014 | Astra Mega II Espresso Machine
Pressure on my boiler gone to 0 how do i get my pressure back up
Turn the burner back on & make sure you have correct water level in the boiler.
Dec 15, 2013 | Water Heaters
Boiler pressure (steamer pressure) is at 0. Usually, when it goes down it comes back up in few minutes but not today. Also, the water coming out for our espresso shots is not as hot as it should be and our...
Problem is either the element, the pressure stat or the reset thermostat on the boiler left side if the model is equipped with one, has tripped, possibly because the machine is low on water in the boiler or the contacts for the pressure stat are damaged or dirty. First I would check the water level in the boiler then remove the left side panel and check the reset switch and press it in, then turn on machine to see if it heats up. If you do not have a reset switch on the machine then check the element and pressure stat to make sure they are working properly, do a resistance test.
May 28, 2011 | Astoria Argenta SAE-2 Espresso Machine
1 of the valves are leakink on the boiler im lead to belive its the pressure 1 not the temp 1 as the water is cold we told the plumber he replaced 1 of the valves unsure which 1
hi i need to know what boiler, all pressure valve work on temp, and what is the boiler do i.e........ does the pressure rise when the heating is on, does the pressure goes up in the red around 3bar???
Feb 16, 2011 | Plumbing
Hi, im having problems with my hydroline b24 boiler, it will fire up but only for a short time then it stops and a fault light come on (flame or gas failure) i dont think its the gas pressure as the burner...
Switch off the boiler at the mains, remove the front panel and 'lower' the display unit/pcb. Locate the (blue) sensor in the condensate trap (rear left hand corner of the boiler). Remove the sensor and dry the area around the probes which are on the end of the sensor which enters the trap. Restart the boiler - if it runs correctly you have a problem with your condensate overflow (as did I). Good luck.
Dec 19, 2009 | Water Heaters
Boiler bar gauge has no pressure
please check to see if its not sticking refill with water
May 04, 2009 | ECM Giotto Espresso Machine
Bosch Worcester boiler, central heating not working
boiler may need more pressure in system pressurise to middle of green between 0.5 bar and 1.0 bar
Feb 22, 2009 | Bosch Logixx WFT 2806 Front Load...
Combi Boiler pressure gauge reading 0, and radiator half on!
The first thing you need to do is to put some more water into your heating system. This is usually done by allowing water from your (pressurised) domestic cold water supply to flow into the system: On older boilers, this is done with a connection (often made with a removable hose) on the pipework just outside the boiler. Newer boilers may have a built-in connection with some sort of removable link (sometimes looks like a plastic key).
Once you've got the boiler up to working pressure (typically about 1 bar - 15 psi), you should be able to bleed your upstairs radiator properly.
This may be all it takes, though the pressure excursions you're getting when you run the hot tap suggest there may be another problem. See what happens to the pressure as the boiler heats up and cools down. There really ought to be very little pressure difference between the two conditions. If you see significant changes, this usually means that the "pressure vessel" (or in hydraulic terms, system accumulaor) has lost its air charge.
The pressure vessel is a metal container inside the boiler, usually painted in red enamel. Somewhere near the top, you will find a schrader valve (like the one on a car tyre), and you can use this along with a tyre pump to replenish the air in the top of the vessel. This will reduce your pressure transients for a while, but you need to keep an eye on it. If the problem returns, you probably need to replace the pressure vessel (or clag another one into the plumbing alongside the boiler).
A.
Feb 03, 2009 | ACCO Brands Water Heaters
Hi, I have a honeywell combination boiler. It stopped working and there is a red triangle flashing and the little window says EA. The round pressure window shows that the pressure (I think it is pressure)...
i am not familliar with that boiler but most will not run if the pressure is too low try refilling the boiler from the fill loop if there are no signs of water leaks
Jan 07, 2009 | Heating & Cooling
Re-pressure Vaillant Turbomax Plus boiler
two pipes coming into boiler on right hand side have brass block valves with a small round recess. These two valves are linked with a stainless fill hose.
Inside the recess on each valve is a small slot, there is a "key" with the boiler but prob lost with the manual. The advantage of the key is its sized so you wont be poking it in the wrong place!
Using a screwdriver turn both slots throug 90 degrees, you will hear water running through. Sometimes one valve is left open so try a combination until the watert runs.
Keep an eye on the pressure gauge and dont let it get too high, if you have no idea of setting pressure head for about 1bar.
Apr 04, 2008 | KDS Valiant 6380iPTD-01 Notebook
Tools & Hardware - Others Logo
47 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
