Question about RCA P46924 46" Rear Projection Television
There is chasis near the bulbs, it looks similar to a distributor cap on a vehicle. It is leaking what seems like a greasy substance. The problem is the TV doesn't seem to be getting power to the bulbs or maybe the bulbs are bolwn. I cam hear the tv power up, but nothing happens
  • RCA Master
  • 8,457 Answers
Ur tv leaking coolant,best take to the shop,must clean the PCB,also replacement coolant.
Posted on Nov 18, 2009
I have ice forming on copper line near compressor and there is a oily greasy substance on the compressor. What might be the problem?
the greasy dust is from a gas leak in the system and the oil is coming out with the gas
the ice forming on the pipe is the internal evaporation of the liquid gas
I suggest that a technician be called to repair the system
Oct 14, 2016 | Refrigerators
820 microfarad 200 volt capacitors
Most likely it's normal. When caps go bad, they usually bulge and leak. Larger caps are often glued in place to reduce strain on circuit board and connections.
Apr 10, 2014 | Mitsubishi WD-60638 DLP TV
My 2006 gmc sierra 4.3 is hard to start. replaced the distributor cap and rotor button,coil,plugs and wires. got it going this morning by putting a hair dryer near the distributor cap for 10 mins. what...
2006 ? distributor cap ? you sure about the year here ,Sorry but iam a europeon mechanic whos never seen this car but i dont see dizzy caps on vehicles from about 2000 onwards
Jan 03, 2013 | GMC Sierra Cars & Trucks
Empty the dryer does not squeak but add clothes to it starts up, Frigidaire LEQ6000ES2
Hello David Strobel - Do you notice the black substance after you take the clothing out of the washer or is it after it has been in the dryer?
Dec 09, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Super...
My Regal breadmaker has begun to release a black greasy substance into my bread dough. Do I need to replace the pan?
The black substance is lubrication oil. The oil lubricates the bearing and shaft that the paddle spins on. Usually this bearing is sealed, but black greasy substance means that the seal is broken and is leaking. Just a matter of time until it fails all together. Time to replace.
Hank
Nov 05, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Where the distributor cap is there is what looks
The oil pressure sensor is near the oil filter behind the distributor. I don't know if that is the sensor you're looking at. It usually gets damaged during an oil change when the filter is changed. The filter wrench slips and hits the sensor.
Oct 30, 2009 | 1994 Jeep Grand Cherokee
Does my belt need replaced?
If it is greasy and not oily, the belt will need to be replaced, there is slight possibility that the bearing seal under drum is leaking oil,
Jul 09, 2009 | Washing Machines
A 1994 Ford Probe with 2.0L DOHC radiator never stays filled but I see no leak and no tailpipe smoke. Could the catalytic converter cover up the problem? It also overheats. I experienced something similar...
The coolant is going somewhere maybe an internal leak look at the dip stick to see if any white substance is present also unscrew oil filler cap and look on the back side if any white substance is present you have internal coolant leak.
Jul 02, 2009 | 1990 Ford Probe
RCA P46924 46" Rear Projection Television Logo
80 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
