Question about Samsung RS2630SH Side by Side Refrigerator
Wont fit through the front door
How to remove the door handles
  • Anonymous Mar 18, 2014
    doors have to be removed to fit in doorway
    Problem Solver:
  • 7 Answers
Take plastic covers off top hinge remove 3 screws pick door up off bottom hinge do not remove bottom hinge,both doors remove the same left side u have to disconnect the water line.
Posted on Jan 10, 2008
Remove interior door panel 2002 Chevy tracker
No you don't need any special tool . Find all screws on out side of door trim panel and the window handle , the mirror cover plate , then just pull on edge of the panel .
Gently pry the front side door trim panel (3) from the front side door by disengaging the plastic retainers which secure the panel.
Position the door trim panel (3) away from the door in order to gain access to the front side window switch electrical connector, if equipped.
Disconnect the window switch electrical connector, if equipped.
Remove the door trim panel (3) from the vehicle.
Remove the front side window switch from the door trim panel (3) by releasing the 4 plastic retaining tabs, as needed.
Use a cloth in order to pull off the snap ring which secures the front side door window regulator handle (1), if equipped.
Remove the window regulator handle (1), if equipped.
Remove the front side master window switch, if equipped. Refer to Power Accessory Switch Panel Replacement .
Remove the front side door inside handle (1). Refer to Front Side Door Inside Handle Replacement .
Remove the outside rearview mirror opening cover (2).
Remove the screw which secures the front side door pull handle (4).
Removal Procedure
Remove the screw which secures the front side door inside handle (1).
Slide the inside handle (1) forward in order to release the retaining tabs which secure the handle to the door.
Open the front side door inside handle rod retainer and remove the front side door inside handle rod from the inside handle (1).
Remove the inside handle (1) from the vehicle.
Check out youtube video showing how to do it !
How To Remove Install Front Door Panel Suzuki XL 7
Jun 10, 2017 | Cars & Trucks
I have a side by side samsung fridge freezer and it wont fit through my front door can you remove the door handles?
See if the end caps will pry off of the handles and see if there is a screw holding it on. You need to post your model number for more specific info.
Feb 14, 2011 | Samsung 24.8 Cu. Ft. Side-by-Side...
I want to fix handles on the doors. Can I remove the finger holds at the sides of the doors to access inside of the door fronts?
You have not mentioned the model but you will have to open the inside lining of the tray holders , to remove to get access to the handle fitting screws, which can be removed to fix the new one.
Sep 29, 2010 | Refrigerators
Left front door will handle from a 2006 jetta fit a 2008 jett
No it will not....covers that fit OVER the handle will fit but not the actual handle.
Feb 06, 2010 | 2008 Volkswagen Jetta
Ikea Whirlpool integrated dishwasher door front
how do i take door off to fix handle back on dishwasher
Jan 03, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
Door wont open
Managed to pull back casing on door to reveal the handle and pin holding it together. Once i had pulled pin up slightly the door opened to reveal the door handle catch had broken. Engineer has fitted a new handle and everything is fine.
Jul 22, 2009 | Whirlpool LHW0050PQ Front Load Washer
Fallen driver's side window
probably need a new window regulator. ebay. 93 to 98 should fit.
Section 01-05: Trim, Interior 1998 Villager Workshop Manual
REMOVAL AND INSTALLATION Trim Panel(s), Door Front
Removal
  1. Disconnect the battery ground cable (14301) if equipped with power locks or power windows.
  1. swv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care when removing the front door inside handle escutcheon (22620). Failure to do so can result in damage to the component.
    Carefully pry off the front door inside handle escutcheon by inserting a standard 1/4 inch screwdriver between the top rear portion of the front door inside handle escutcheon and the front door trim panel (23942) .
  1. If equipped with manual windows, slip a clean shop rag between the window regulator handle (23342) and the front door trim panel .
  1. Pull the shop rag back and forth to release the window regulator handle clip.
  1. Remove the three cover caps and front door trim panel screws.
  1. Remove the one front door trim panel capped screws from the door pull handle.
  1. If equipped with power windows, remove the door pull handle. Disconnect the electrical connectors.
  1. Slide a flat-bladed tool behind each of the retainers and twist the tool to disengage the front door trim panel from the front door (20124) .
  1. Remove the front door trim panel.
Installation
To install, reverse the removal procedure.
Window Regulator, Power Front Door
Removal
  1. Disconnect the battery ground cable (14301) .
  1. Remove the front door window glass (21410) . Refer to the front door window glass removal procedure in this section.
  1. Remove the two front door brace bolts and the front door brace.
  1. Disconnect the front window regulator electric drive electrical connector.
  1. Remove the four front door window glass regulator track bolts.
  1. Remove the three front window regulator electric drive bolts.
  1. Remove the front door window glass regulator track and the front window regulator electric drive (23394) as an assembly through the opening in the front door (20124) .
Installation
  1. Install the front door window glass regulator track and the front window regulator electric drive as an assembly through the opening in the front door .
  1. Install the three front window regulator electric drive bolts. Tighten the front window regulator electric drive bolts securely.
  1. Install the four front door window glass regulator track bolts. Tighten the front door window glass regulator track bolts securely.
Apr 29, 2009 | 1998 Mercury Villager
Removing Door Trim
hi-- the inner door handle is tricky! it is held in by clips that SLIDE BACKWARDS!! apply a little inward pressure then slide the handle assembly back!!-- then you will have to remove the metal rod from the handle----------putting it back is the reverse.----cheers
Apr 18, 2009 | Hyundai Excel Cars & Trucks
How do I remove and replace the door handle on a '01/51 VW Golf ?
you need to remove the blank where the lock barrell would be fitted if it was drivers side.to do this remove the black plastic bung that is located on the edge of the door ,then pull the handle as if you were opening the door and hold it in that position,then insert a 20 torx screwdriver in the exposed hole from pulling the bung out and unscrew untill you start to feel resistance ,the screw will not come out you are just slackening it.then you will be able to release handle and pull out blank or barrell if you have one fitted.then flick the cable out the handle ,you can then pull handle towards the back edge of the door and un hook it from door.holding the handle while you are unscrewing the screw is important if you dont the retainer can fall of and end up in the door........not good....
Feb 10, 2009 | 2001 Volkswagen Golf
Samsung RS2630SH Side by Side Refrigerator Logo
650 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
