When i wash blankets there is too much water that is literally soaking
  • 10,865 Answers
Hello. If your washer handles regular clothes with no problem it could be that the shear weight of the blankets is too much for your machine. I recommend taking these heavy items to the laundromat and saving your washing machine for lighter loads.
Posted on Nov 18, 2009
My Defy Automaid does not release the water
Fluff from the blanket has more then likely blocked up the water pump, will have to be cleaned.
Oct 20, 2014 | Washing Machines
Maytag bravos quiet series 300.. I washed a blanket and it literally disintegrated into millions of pieces. How I clean it out from the inside basket. I cleaned it out of the tub but I'm sure there are...
I would fill the tub with water,like i'm going to wash a load,but don't put in any clothes .Run the complete wash cycle and see if the water all drains out.
Jun 05, 2014 | Washing Machines
Sunbeam electric blanket repair waynesboro ms
wash the blanket then throw it in the bin
water and electrical components do not mix
electrical blankets are just a resistor element in ceramic covering and if you put that in a washing machine that is the end of the insulation
Mar 18, 2017 | Sunbeam California King Arlington Heated...
Agator not spinning
There is no belt on that unit. It is a direct drive machine. When the unit goes into the wash cycle, does the motor run but it does not agitate?
Nov 28, 2012 | Maytag MVWC400XW Centennial 27" Top-Load...
May i wash blankets in th washing machine
Wahing blankets in the washer depends on the washer and it depends on th blanket. If its a thin blank or small quilt than usually yes. If you have a comforter than I recommend taking to laundry mat. Top load washer is designed for between 18-28lbs of laundry. It may not feel that heavy but soak it with water than feel how heavy. If its a direct drive washer and you put too much weight in it the couple will break. If its belt driven you can break the belt or wear out the moter. If its a front load washer they are designed to hold more but The motor can only handle so much weight or it burns out. The belt could also break if its too much weight. The simplest way of determining it is if the blanket does not soak up alot of water ( thin blanket ) than its ok If blanket soaks up alot of water (comforter) take to laundry mat. I hope this helped. Anymore questions please comment me back.
Jul 30, 2011 | Kitchen Ranges
Lion Brank Nature's Choice Organic cotton sheds like crazy. What do I do? Made a beautiful baby blanket and afraid to give to the mommy, baby will end up with a mouthful of cotton.
You may want to soak the (finish product) of the blanket in a warm soapy water (bar/bath soap is prefer). Let it stay for about 20 minutes or so. Do not wring or dry it in the machine. Use a fresh towel. Lay the towel on flat surface. Put the wet blanket on top of towel. Roll the towel together with the blanket and add a little pressure to the roll to get the excess water out of the blanket. If still need it take another fresh towel and do it the same way. Then, lay flat to dry. Warm water and soap usually will make the fiber to be less sheds. Good luck!
Aug 02, 2010 | Lion Cotton Yarn
It will not agitate or spin.
needs new bushes to electric motor common fault when the bushes wear down it cuts power to machine this will stop washer from washing and spinning
Jan 11, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
"suds" error in kenmore elite HE3 front loader washer
Try a vinegar rinse or there are also defoaming products available.
Jan 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Front load washer won't drain
Possibly a blocked pump. Sounds about right if it has only happened after that item was washed.
Oct 30, 2008 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
