Question about York Yankees Bedding MLB Comforter
Where is the furnace filter located on the York P3CGD12N08001B
  • 22 Answers
Residential furnaces have exterior filter boots supplied by installer, commercial york units have filter access doors. If this is a roof top unit your filters would be in the door to the left of the blower compartment.
Posted on Jan 21, 2010
Can't find the filter
should be on return air side of evaporator.
Dec 06, 2013 | Coleman York Luxaire Furnace Control Board...
York diamond 80 manual
where is the air filter located on a York diamond 80?
May 03, 2013 | Dayton Gas Furnace Heater
York furnace trippin roll out switches
Is your filter plugged? If so, change it out. is the bottom door on the furnace? Is the draft motor running at normal speed?
Jan 05, 2013 | York Furnace Draft Inducer Blower Fasco #...
How do i change air filter in older york steller furnace
take off the front door if it is a upflow it will be located on the bottm inside of the furnace if downflow it would be in the top
Mar 03, 2011 | Heating & Cooling
Gas furnace
Hi check out the pressure switch clean the air filter and check out the fan control see if this is clean
Feb 16, 2010 | York Furnace Draft Inducer Blower Fasco #...
Furnace will run, put out heat, turn off and doesnt start again.
What is model # & serial # of this furnace, it may have a diagnosis led indicator light located on the control board, behind bottom door of furnace which will blink and tell you a fault code. Also check furnace filter, make sure its clean, check through out the house to see if all registers are open and not blocked by any objects, make sure cold air return grill is not blocked, the unit could be over heating and shutting off on high limit, good luck.
Feb 15, 2010 | York Furnace Draft Inducer Blower Fasco #...
York 92 % eff. furnace shuts down on # 3 error (pressure switch)
i have fixed almost every one of pc9 -----we have installed in our company,code three{flashes} at first new presure switches installed, same thing,york knows about this,induction motor bearings,could be bad.our local york dist, has boards,inducer, ***.motor, dual press.switch,free.as is known as the only way to fix.after all else is ruled out.one local competator called us if we wanted to join class action suit . good luck.furnaces work good at first, season or two then bam
Nov 28, 2009 | York Furnace Draft Inducer Blower Fasco #...
Loud noise when furnace starts but furnace won't come on.
Your fan delay relay has failed and must be replaced.
Jan 16, 2009 | York Yankees Bedding MLB Comforter
York Yankees Bedding MLB Comforter Logo
721 people viewed this question
Top York Sport & Outdoor - Others Experts
Paul Carew
Shehu Pro
Shehu Pro
ray gallant
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
