Question about Canon Pixma MP500 All-In-One InkJet Printer
Cannon MP500 Error Code 5010
My girlfriend has the printer as described above, I took the covers off both ends to make sure the obstruction or whatever it was, was cleared. I hooked it back up to the computer, while the computer was turned on. I still get an error message 5010, can you tell me what I need to do to get it working again?
  • Terry
    Terry Jan 27, 2018
    Hi dewebbe, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Does the information below help:
    https://www.justanswer.com/printers/5l1l...
    You are not obligated to chat with the service shown at the web page link, this is intended to advise that they offer paid service, and also give the free Canon support phone number.
5 Suggested Answers
SOURCE: Cannon PIXMA MP520 Problem: Error code
I had this problem with the ink carriage jammed at the left hand side of the printer. I operated the lever in a hole on the top left hand side and eased the carriage along to the middle and pushed it back onto it's runners. All OK now.
Posted on Jun 29, 2008
SOURCE: error code 5010
I got the error code 5010 today (scanner lock switch). I called Canon. The printer's electrical circuitry (brain) needs to be refreshed. This is similar to wireless routers and other devices. They directed me as follows: 1. power OFF the printer 2. Unplug the printer's power cord from the electrical source. 3. Wait AT LEAST 1 minute - no less than 1 minute. 4. After 1 minute, plug-in the printer to the electrical source. Turn on the printer - wait for it to warm up as usual and it should be ok. Mine worked perfectly after the above steps. - Hope this helps.
Posted on Jan 07, 2009
halbrook
  • 560 Answers
There's no specific info on a 5010 error even on Canon website, but ANY error in between 5000-9999 needs Canon's attention, so if it's under warranty, get a replacement.
Posted on Apr 29, 2009
komguy
  • 2306 Answers
SOURCE: printer will not print, error code 5010 is
5010 is a scanner error, either worn out scan lamp or sensors. Canon only replaces the entire scan assembly, if you like I can get part number and price.
Posted on Jun 23, 2009
I have a cannon pixma mp 500 printer and I and getting a error code 5010 how can I fix this issue? Thank You
unfortuantely according to canon website, if turning it off/on doesn't clear the error then it will require a "repair service". Doesn't acutally say what the problem is I'm afraid.
good luck
Don
Sep 01, 2011 | Canon Pixma MP500 All-In-One InkJet...
Multifuncional mp140, result error 4,2 and then error 5010 solution?
canon mp140 i get a error code 5010 any suggestions on how to fix this?
Apr 25, 2011 | Canon Pixma MP500 All-In-One InkJet...
Getting a error 5010 on my printer. It has been working fine until today.
soft-manufaktura.ru/manual/hp/mp500sm.pdf
Hi please find above a service manual, this will assist you to troubleshoot and repair your issue.
error 5010 The scanner has not retracted to the normal starting point. This often means a faulty sensor, or faulty main board. use the service manual to troubleshoot and repair.
This seems to be a fairly common problem.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp500
Above is your support link, use this as well...
Dec 14, 2010 | Canon Pixma MP500 All-In-One InkJet...
Error code 5010
This error is related to your cartridge carriage (the white sliding mechanism which holds the cartridges). This happens when it can't move properly and freely. You'll need to open up the front portion of the printer to get into this. Try somehow and apply some grease on the slider so that it'll lubricate it and check whether it helps or not.
(You may also require to open the top cover which holds the front cover and remove the screws which hold the sliding mechanism). If you do it very carefully and applying the grease properly, this will fix the problem.
Good luck.
Thanks for using FixYa.
Jun 23, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Error code 5010
Canon only lists three 4-digit error codes for the MP500: 1700, 1851, and 1856. After much research and finding many other MP500 owners getting this same strange code, I have come to conclude that it's the code of DEATH. Sometimes you may get strange codes if using compatible ink cartridges. Unless you can get the printer to reset and clear, the only other thing to try is to go back to the Canon driver download page and reload the correct driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=11995
Apr 25, 2010 | Canon Pixma MP500 All-In-One InkJet...
ERROR CODE 5010
Hi Friend,
kindly follows the below 2 steps
1.Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
2.The MP510 may require repair
Unfortunately, the issue you describe seems to indicate that your product requires repair service. Canon has excellent service options and we are eager to provide any assistance you may need.
Regards,
Ayyasam
Jun 01, 2009 | Canon Office Equipment & Supplies
Service error 5010
that is a scanner error code , prob not worth fixing cost you more to have it fixed than the printer is worth
May 20, 2009 | Canon Office Equipment & Supplies
Error code 5010 for cannon mp460 printer
Hello, The error 5010 refers to a scanner issue, make sure all the connectors are seated and all flat cables running to the scanner unit are firmly seated, turn printer back on and the error should clear. I hope this helps.
Nov 10, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Error code 5010
Feb 17, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
189 people viewed this question
old marine
old marine
