Question about Acer Ferrari 3200 Notebook
The DVD drive plays audio files but not video
  • retehina May 11, 2010
    General Problem
    » Hp Laptop's Solution » Compaq Laptop's Solution » Acer Laptop's Solution » Dell Laptop's Solution » Toshiba Laptop's Solution » Asus Laptop's Solution
    » Gateway Laptop's Solution » IBM Laptop's Solution
    Driver Download
    » Hp Driver's Download » Compaq Driver's Download » Acer Driver's Download » Dell Driver's Download » Toshiba Driver's Download » Asus Driver's Download » Gateway Driver's Download » IBM Driver's Download
    terebin5
What video files will this head unit play?
Yeah, it has to do with the codecs that you have in your player.
There are so many ways to encode video material and if your player is lacking the appropriate software they will not play back. The media players on computers are far more adept at playing videos - VLC will play back just about anything. but with TV's it is a crapshoot - DVD players are generally better then the tv's but still there is some material that even they will not play back unless it is in the right format for them.
MP4 is a video file. MP3 is audio. When setting your player make sure you tell it that it is a video file and not audio. If I mess up the two on my dvd player I will have a problem - I have to properly identify my source as either video or audio.
Sep 05, 2015 | Soundstream VIR-7355N Car Video Player
Music and video files from usb won't play on dvd
hi, the file format that you download in your usb drive is not compatible in the format in your dvd player. look for the file format that have been in your dvd then you can convert the video or audio in your usb to make it compatible in the dvd player. there are converter which you can download.
Jun 09, 2012 | Televison & Video
I have a yamaha dvd-c750. I have just created a slideshow using iphoto on a Mac, burnt to a TDK DVD +R. Inserted into the DVD drive. Machine tries to load it. Gives a message "unknown disc"? ...
DVD players can be picky with the type of file format that they use. According to an amazon.com review of this player, it does read DVD+RW/+Rs & DVD-RW/Rs so the problem probably resides in your file format.
The problem is probably the fact that the DVD Player does not recognize the file format of your Mac slide show. The computer recognizes this format, as it plays the slide show. The DVD player recognizes JPG file formats, which is the standard format of a picture.
If a DVD is made with JPG Files, not your slide show files, it will display thumbnails of each picture, allowing the choice of what picture to view.
If the slide show is a must, try to save it to a video file format, such as a *.mpg or *.avi which are common video file formats. These files would be movies of the slide show that you have made.
Mar 16, 2011 | Audio Players & Recorders
I bought a DVD and does not work. I need a free codec for HP 550
First make sure that your new DVD Drive is functional and it can read data from the disks. You can play DVDs only if the DVD drive is working properly. However, Codec are required to play some file format. You can download the latest version of Media Player Classic (K-Lite Codec) FOR FREE
It will install all the required CODEC and you can play all audio - video files.
Hope it helps! Good Luck!
CreativeTECH
Mar 03, 2011 | HP Computers & Internet
I can see the movie playing but I cant hear anything. What can I do? When I click on my dvd drive from the "My Computer" folder, it has an audio and video folder that comes up. There are various files...
The audio_ts folder doesn't have any files, that is not causing the problem. Does the sound work for other things on the computer? Open the volume mixer by double-clicking the speaker icon in the system tray. Then check that the volume is not muted for the CD/DVD drive, or turned down too far.
Oct 24, 2010 | LG 16X Internal DVD-ROM, E-IDE / ATAPI/...
Can i play Xvid files on my 622 dvd player? if not which kind of video files does it play?
Im assuming your talking about the Philips DVD 622. You cannot play any video files unless they are burned to a CD or DVD in the standard DVD format. It can play certain audio formats but cannot play different video formats.
Jul 24, 2009 | Philips Televison & Video
My LG DV492H will not play DIVX files. Will play audio files vie the usb input but not video files. Believe it may be a setting but have tried various options with no luck. Please advise on what settings...
I have he same problem, as well as my friend. If you insert a DVD video disk, start up the DVD player. It then starts to play the DVD. Stop it and insert the USB drive. Use title to browse to your movies. It then plays them. Tried this on 2 dv492h players and it works
Jul 11, 2009 | Televison & Video
Converting Movies To Play On My Home Dvd Player
Convert video to .avi or DVD (Audio TS- Video VS) format.
Many common dvd players can play .avi files
(.avi files are very compact).
All dvd players play TS/VS format.
AVS4U is a reasonably priced (approx $50)downloadable suite of programs that can perform all the conversion tasks you need for audio & video.
Dvd not playing dvds
Basic Information:
i) try to choose  right burner for eg: Nero CD/DVD Burner
ii) try to choose the right format,
     for eg: MP3/MP4/ Audio Songs will come under Audio format
               in such case select "Audio CD/DVD format" in Nero CD/DVD Burner
     for eg: .DAT/MPEG/MP4/Video will come under Video format
                in such case select "Video CD/DVD format" in Nero CD/DVD Burner
     for eg: "DATA CD format" is only storing some data on CD/DVD iresspective whether it is                            Videofile or Audio file,
                these "DATA CD formated" CD/DVD when played in DVD Player will play only Audio files
                but no Video Files
Dec 26, 2008 | Televison & Video
My dvd drive is not video files but it is reading data files
What OS are you using?
In windows go to the Control Panel+ Performance Maintance+System(system properties) + Hardware+ Device Manager from the list select disk drive and select the one that you are trying to access and on the general tab make sure that the drive is enabled.
NEXT In my computer right click on the drive and properties make sure auto play is selected for music. And then also if you have more than one CD/DVD drive you it can possible that the drive is set not to play video and music. The too you will find in the properties menu.
Thank You good luck
Aug 27, 2008 | NEC ND-3500A DVD±RW Dual Layer Burner
Acer Ferrari 3200 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
