Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
FRONT DOOR OF DISHWASHER
THE DOOR OF DISHWASHER WILL NOT STAY CLOSED ( OR IN THE UP POSITION) UNLESS WE PUT IT THE LOCK POSITION. THIS IS A NEW PROBLEM. BEFORE IT HAD NO TROBLE STAYING UP
  • 1 more comment
  • Owner2008 Oct 04, 2008
    I have a brand new frigidaire FDB2810LDC1, ( came with the house) which doesn't seem to have springs in the door. How do I take the kick panel off?
  • w3as Jan 01, 2009
    I have the same problem. It just started last night.
  • Anonymous Mar 25, 2014
    Beko Dishwasher din 5832 door locker is in close position. I cant unlock it or close door.
    President:
  • 1,314 Answers
Take off the bottom kick plate and look in there to see if the springs to the door hinges on either side are broken or come unhooked and let me know
Posted on Jan 10, 2008
Why will the door not stay closed ?
it could be the latch frame and casing but if no one has recently put a crowbar in to door lock to force your door open - i would say its an eletrical fault check the sensor on the door frame and on the door and make sure they line up while the door is closed and if thats the case i would say you have a fault with the hall sensor or ghosts haha just kidding
May 27, 2014 | Bosch SHE3AR55UC Builtin Dishwasher
Door lock
Pull the door latch towards the front of the dishwasher until it clicks in the open position.
Mar 30, 2014 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Kitchen Aid KUDD03DT top drawer won't stay closed
The lock lever on the unit --- that is shaped like a U --- if you have it ---may be bent a little. You can move it to the correct position - usually down a little --and your door will stay closed
Mar 04, 2014 | KitchenAid 24" Double-Drawer Dishwasher...
Samsung dishwasher door lock stuck in closed position
take small flat head screwdriver and on the door were the latch is push the screwdriver in about an inchpull on the open handle at the same time ps unplug it first.
Jun 22, 2012 | Samsung 24"" Dishwasher
I can no longer latch my dishwasher i can get it open but not closed now to wash with. should I buy a new latch which is easy to install and take out or can i macguiver it?
the latch can get stuck in the closed position when door is open,...... to fix it....undo the screws on door.............seperate front from back.....the latch can then be "opened "...........put door back together n job done............
cheers
Mar 22, 2011 | Dishwashers
Door will not stay closed unless latched. spring
Adlust the level on the fridge so that the hinged side is slightly higheer than latch side. They reley on gravity to stay closed.
Dec 24, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Cant get back door to stay closed . The lock is stuck in locked position I think and the door is open. When I go to close it, it is'nt staying closed. Had to duck tape it to stay closed. LOL! I keep...
It sounds to me ( correct me if I'm wrong ) like the door latch on the side vertical edge of the door is in the LOCKED POSITION. In order to unlock it perform the following. First electrically with the LOCK button UNLOCK the locks. Now with one hand hold the OUTSIDE DOOR HANDLE IN THE OPEN POSITION, while at the same time FLIPPING OPEN THE LATCH. All Done . Now you can close the door. Hope this helps
Jun 27, 2009 | 1997 Chevrolet Lumina
Door will not close properly
You need to buy a new door lock from Hotpoint  £14.99 in UK
Apr 04, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Bottom Draw Wont Close
Check the sides of the drawer on the dishwasher and make sure that the sliders that the drawer rides on are not locked in place you will notice on the front of the slider near the door panel there are plastic clip like press in tabs that hold the drawer securely in the tracks try to put your hand up under the door and move the track if the track moves in the slider you will need to hold the door secuely with one hand while sliding the track to the most open position on the slider track. if the sliders are not locked in you will be able to pull the slider forward and the slider should clip into place.Repeat this for both sides and the door should operate like new once again.
Jan 08, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Door won't latch
replace the door latch part number 8193830 it will fixya
Sep 23, 2007 | KitchenAid 24 in. KUDS01FLSS Built-In...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
103 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
