Question about Panasonic Televison & Video
PT51HX41E WILL NOT DO NOTHING WHEN TURNED ON, POWER TO UNIT
    President:
  • 788 Answers
Your symptom sounds like a damaged convergence IC.
You should be able to get a local service center to repair this at
your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and
heat sink compound you can repair it yourself.
When you remove the old IC's, please be sure to remove all of the old
heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center
circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews
Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their
phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the
phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a
good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this
information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Posted on Dec 03, 2009
My panasonic pt51hx41e convergence will not line up
Clean the projection lenses with qtips and alcohol. Then try to use the convergence function. My blu was messed up on one side of the screen until I cleaned mine.
Mar 09, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Need to know what convergence chips are in Panasonic PT51HX41E
your model has two STK392-110 CONvergence Cs, you will also most likely need at least a few of the 2.2 ohm 2watt convergence resistors. I am posting a link to the actualrepair kit for your model which contains both Convergence ICs and all 6 of the convergence resistors and they send instructions with pictures that show how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
May 28, 2009 | Televison & Video
No power to control unit
Basically your service did not add anything I had not tried already. I had to send the product back.
I would like a refund.
Apr 10, 2008 | Audio Players & Recorders
Where to buy feed resistors?
Acme enterprises in Florida, inexpensive and very reputable...
http://www.acme-sales.net/index.shtml
or by phone at: 1-800-575-9833
Bill
Nov 27, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT51HX41E Resistor values
you probly wont have to replace any resistors ,use STK392-180s.
Aug 27, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Convergence for HD channels only
Hello, please check the IC7102 (24LC64). This is eeprom that contains the convergence data. Please ask the Panasonic dealer if they can supply a replacement IC with the data for your HD. If you need more info please advice. Arpi
Jun 08, 2007 | Panasonic PT-51HX41 51" Rear Projection...
PT51HX41E PANASONIC
I know it has been about a year since you posted but I was wondering what you did about your Panasonic? I to have one that has turned white....I think it is a lemon ..my son also had the sam eproblem with his....we paid over 2,000 for this piece of JUNK...Thanks....diggey2@yahoo.com
Nov 19, 2006 | Panasonic PT-51HX41 51" Rear Projection...
Televison & Video Logo
76 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
