Question about Marantz ZS5300 6-Channel Amplifier
Volume How would i go about fixing the volume control?
  • Marantz Master
  • 5,487 Answers
Depends what's up with it!
For example if it has been broken then it will have be replaced.
If it is crackling or cutting out when you move it up or down, then some dirt or wear of the contacts is causing the problem. This can be cured sometimes with a spray of Servisol Switch Cleaner (Video 40 is the best) often used to clean VHS video heads. Spray it directly into the tracks of the control, for best results and move the volume control around (no power).
You can get it from several places such as Maplin (UK) or Radio Shack (USA). Even seen it on Amazon.
Posted on Nov 24, 2009
Volume control not working how to fix it, can it work wothout volume control?
Short the volume contole pins to get full volume
Put a fixed resistor in its place
Find a similar volume control with correct resistance (in Ohms)
Visit an electronics supplier in your area to get the right part.
For Example
1M 24mm Potentiometer Linear Single Gang Potentiometers Resistors Passive...
Sep 19, 2015 | Audio Players & Recorders
Damage volume controle creative inspire P5800 how i turn on speakr without volume control ? Help me please!!! Thanks my mail afspires@gmail.com
u cant control the volume whitout the volume control, u have to fix that one or get another like that.by the way what is the problem with him?
May 04, 2012 | Creative Labs Inspire P5800 Computer...
My nokia 5310 fell down and volume control is not working.. i am not able to adjust the volume.. how can i make the volume control work.. or how can i increase or decrease the volume without using volume...
hi
either your volume button get damaged or the software gets corrupted in your phone.. change the volume button and format the phone.this willl fix your phone..
thank you
Dec 24, 2010 | Nokia 5310 Cellular Phone
Speaker volume like small baby
To fix the volume control re-install the drivers of the laptop and in the right lower corner you will see a speaker like symbol where you can control the volume. Increse the volume from there.
Thanks
Jimmy
Apr 29, 2010 | Samsung NC10-14G Notebook
May volume keys on my keyboard are not responding. My speaker/headset volume is inaudible. whenever I press the volume keys on my keyboard, nothing happens. the same as when i click the volume symbol on...
They are actually two separate issues:
I will assume that you have funtioning speakers or headset.
1) first fix your main audio problem by re-installing your sound card driver that would normally come with your PC/Laptop or (external) Sound Card. This should fix the issue with your software volume control
2) second fix your Keyboard volume control: if after fixing your audio system driver previously, this is still not working, then you will need to re-install your Keyboard 'soft' key driver that control the extended function of your specific keyboard: the driver may also be included as part of your PCLaptop but may also have come with a 'third party' non-orininal keyboard.
Hope it helps & good luck!
Dec 25, 2009 | Computers & Internet
Volume controls do not work on remote, batteries have been chang
is that from remote no volume try tv volume if ok
your remote volume buttons are wornout push
button harder ??ok no i can fix remotes
need help call 0403960527
Feb 16, 2009 | Samsung TV Remote Control
When using the amp, it alternates between loud and not working when adjusting the volume. How do we fix this?
you might have a "dirty" volume control - with the power off, try twisting the volume control full to the left, full to the right, repeat several times - if this improves the situation then a quick shot of contact cleaner spray into the volume control might fix it for good.
This advice should work for potentiometer-type controls which consist of a metal wiper moving over an arc of carbon-coated material - dirt builds up under the wiper, preventing good contact.
Newer controls using an optical encoder will not be fixed by this method. If your amp volume normally adjusts in "steps" that you can hear, as opposed to continuously and smoothly as you rotate(d) the knob, then you have an encoder control.
Dec 28, 2008 | Audio Players & Recorders
The rotary volume knob on my DEH 9400MP head unit has stopped working. this also happened to my friend's. the steering wheel remote still works. is this common? can it be fixed please?
Although I can't check this fix works for 1 month, a really simple explanation and fix was offered.
The rotary knob/control has 2 contacts, which when the knob is rotated c/w or anti-c/w it generates a pulse. The diagnosis is that as the remote still works, the PCB & volume circuit is fine. What is likely is that the 2 contacts/switches have become dirty or clogged.
SUGGESTED FIX: Take head unit faceplate apart to access PCB & rear of rotary control (4 screws). Spray WD40 into rear of volume control and rotate liberally to clean contacts. Dry of with lint free cloth, tissue or air dry.
I am confident this will work and the volume control will function again.
Sep 27, 2008 | Pioneer Car Audio & Video
Averatec 3200 Volume Problem
Windows has a volume control built in, look at: control panel, sound and audio devices, volume control slider and check box for "place volume icon in task bar.
Feb 16, 2008 | Computers & Internet
Volume control doesn't work on the enternal speaker
On some sets that have audio output jacks, the level of the audio output on the RCA jacks is fixed, and it does not change with the TV's volume control. On some sets, such as Sony, you can choose fixed or variable output. I have also seen some sets that have both fixed and variable RCA jacks on the back. With variable audio out, the audio level at the audio output jacks follows the TV's volume control. If you go into the TV's menu and navigate to the audio page, look for fixed or variable output options. If you have the owner's manual, read the section on audio output. If variable output is not an option on your model, then the level is constant and the volume will have to be adjusted with the stereo's volume control.
Aug 25, 2007 | Toshiba 27DF46 27" TV
Marantz ZS5300 6-Channel Amplifier Logo
71 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
