Question about Acer Aspire L100 PC Desktop
Hello again....i've just discovered within the setup and PC health status that there seems to be a problem with the 12v supply. There are 3 different Voltage meters: 1) 12V 2) 5V 3) 3.3V Alongside these is the actual reading supplied and the 5V and 3.3V show a correct reading, however the 12V supply only shows 0.06V. If fear that this is why the fan isn't working. any ideas???.....HELP
  • sguler Nov 26, 2009
    thanks for all the info people.
    update time.
    tested the power adapter and it is generating 19V.
    tested the hard drive in another computer and this is working fine.
    i think that there is 3 transformers on the motherboard which convert to the various voltages and i think the 12volt thingy is not working correctly. i've looked on the board and there is 3 little ceramic things with different amount of coils wrapped around....im not expert but imagine the more coils wrapped around means less voltage??
    any ideas on what i can do next??
  • Acer Master
  • 5,660 Answers
Having never repaired, or seen an Acer Aspire L100 desktop, I went to Acer Support, and reviews on the internet. (I do repair computers, however, not just Googling info off of the internet here)
Seems the Acer Aspire L100, uses an external power brick for a power supply. Also looks like they're harder to find than hen's teeth!
It does seem judging by your findings, that your problem is the power supply.
A computer power supply put's out three main voltages, (Such as you have seen)
A.3.3 Volts
B.5 Volts
C.12 Volts
You obviously have a weak 12 volt power rail.
At this point I would take the power brick to a repair shop. I'll bet it's bad Electrolytic Capacitors, but this is just IMHO.
Also read where there are problems with overheating issues. Most post that the front door should be kept open, when using the computer. Better make sure the inside of the computer is clean, as well.
(Computer off, and unplugged from power. Use a can or two, of compressed air for computers.
Pay special attention to the heatsink under the processor fan, and the processor fan.
Do NOT keep constant air pressure on the fan. It is only designed to spin so fast. Spinning it faster than it was designed for, can lead to premature failure of the fan's bearings! {If you hear the fan go 'Zing' get the air pressure away from it!}
BEFORE you reach inside the computer, unplug the power from it. TOUCH the metal frame of the computer case, to relieve your body of static electricity. Static will fry out those delicate computer hardware components. You may not see it, or feel it!
Zap! There goes your computer!
Try to gently move the fan blades by tipping them. Looseness in this area means the fan bearings are shot. Replace fan)
Posted on Nov 19, 2009
  • joecoolvette
    joecoolvette Nov 26, 2009
    This has photos of an Acer Aspire L100 motherboard,
    http://www.ascendtech.us/itemdesc.asp?ic...
    (Scroll down)
    Now, looking at the motherboard. Look at the area behind where you plug Speakers/Microphone in.
    [Orange, Light Green, and Blue ports. DVI monitor connection is below]
    Are you speaking of the choke coil behind it? The round doughnut looking abject with thick copper wire wound around it?
    There is another one behind the blue VGA port.
    If so, I would disregard these for the moment. I would like you to take a look at the Electrolytic Capacitors instead. More specifically the one's surrounding the processor socket.
    Why?
    Because they are Voltage Regulators for the processor.
    This link gives you more in-depth information, about visual failure signs of Electrolytic Capacitors,
    http://www.capacitorlab.com/visible-fail...
    Reason I harp about bad 'Caps' so much?
    http://en.wikipedia.org/wiki/Capacitor_P...
  • 47 Answers
Sounds like the power supply is Bad . you can have it tested or get your own tester and test it very simple tool to use.
Posted on Nov 18, 2009
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
pcbheaven.com/wikipages/How_PC_Fans_Work/
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT
www.informit.com > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
pinouts.ru/Power/atx_v2_pinout.shtml
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
Dec 16, 2015 | Cars & Trucks
I set up my RX-V365 recently, and the center speaker doesnt seem to work. i use it for listening to music, the sound should come out right?
Sound from a speaker, nah, that's an optional feature (kidding).
If you dig into the manual annd go through the setup using the test tones you can prove/disprove the viability of all the speakers and channels. THAT is required before we try to listen to 'music' (assumed 2-channel) on multiple speakers.
Sound Field programs (page 25) can be applied to just about any source. Experiment, even within a given recording. You'll be amazed how different digital processes can make even familiar recordings new and more interesting. I've discovered instruments and sounds in old recording I never noticed before.
Jun 22, 2011 | Yamaha Rx-v365 A/V Home Theater Receiver
Hi hope someone can help with my power problem. Motherboard is L7VMM3, so far tried 2 different power supplies, 2 different power leads, 2 different on/off switches, 2 different RAM modules, and 2...
After reading your description and the tests you've done, the problem may be coming from the board itself.
If possible test another board with your power supplies and others...... If other board works just fine, the problem is with your current motherboard.
To be sure about it, you may test the board with another power supply/RAM, etc....
If problem persists, the best option is to replace the board.
May 10, 2011 | Computers & Internet
Hi, I hope you can help as Acer can't!! I have an Acer Veriton M221 about 15 months old and recently on boot up I get error message Case Opened press F1 to continue or Del to enter Bios. I have not...
Have you tried this:
1) Reboot your computer and Enter Setup.
2) Click on the tab labeled PC Health Status.
3) Find the feature labeled Chassis Intrusion Detect, and change the status to RESET
4) Press the Esc key to access the main menu and then use the arrow keys to choose Save & Exit from the menu.
Do NOT use the F10 key. If you use F10 key to Save & Exit, it does not properly reset this feature!!!!
If you wish to set the Chassis Intrusion Detect feature so it never generates a warning message at boot, follow these instructions
A) Reboot your computer a 2nd time and Enter Setup.
B) Click on the tab labeled PC Health Status again..
C) Find the feature labeled Chassis Intrusion Detect, and this time change the status to DISABLED
D) Press the Esc key to access the main menu and then use the arrow keys to choose Save & Exit from the menu.
Jan 29, 2011 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
Shadow printing in hp laserjet 2600n
Hello jagdishgolas!
Theres a few things you need to do first to determine what its causing the problem
Here are some steps you can follow:
1) Print a Supply status report (Main Menu > Reports > Supply status)
If you still see the shadowing is on this page we can tell that the problem is not on the computer
Check toner level on this supply status, if its showing lower than 10 % i would recommend to replace the cartridge
2) Run 3or 4 Calibrations in a row (Main Menu > System Setup > Print Quality > Calibrate Now)
3) Run 2 cleaning modes ( Main Menu >Services > Cleaning Mode)
4) Access the secondary service by hitting the checkmark and the cancel button at the same time, then hit the checkmark again
Under the secondary service look for "Clean Belt" anr run it twice
Try printing again
Heres a link where you can find an Authorized repair center near to your location :
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
Jun 21, 2010 | HP Color LaserJet 2600n Printer
Pin Name Color Description
Yes this is a good list of the voltages to be expected from a newer power supply on just the main header
Apr 01, 2009 | HP Compaq dc7100 PC Desktop
RAID rebuild problem
Your NUMBER 1 ENEMY when doing multiple drives in a single case is HEAT!!!! Make 100% sure those drives are COOL!!! if not you will continue to have issues.
Dec 10, 2008 | Biostar P4M800-M7A Motherboard
Boot up error showing "chassis has been opened"
Here is the solution. I had the same problem.
Chassis Warning
"Warning your chassis has been opened. Press F1 to continue. Press Del to enter setup menu."
Resolution
Enter Bios
Goto Intergrated Peripherals
Goto Onboard I/O setup
Find "Chassis Opened warning"
Set to “Disable”
Press F10 to save and exit changes
That all there is too it.
Nov 30, 2008 | Computers & Internet
EMachine T2824 does not turn on. Power cord/power supply seems O.K.
There are just too many eMachine models to be familiar with every one, however, as a preliminary inspection, remove the side panel, and turn the computer on to see if you see a green "Health" light. This will give you an initial clue as to how to pursue the problem. eMachines have historically had power supply problems. If you do not see a green health light on the motherboard, then your power supply is defective. A power supply supplies various voltages + - 5V, + - 12V ,etc. A power supply can be easily tested by a local shop with the proper test equipment. You might start there if you are a DIY! Short of that, you can purchase a power supply for under $65.00.
Nov 20, 2008 | E-Machines (T2824) PC Desktop
Acer Aspire L100 PC Desktop Logo
300 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
