Question about AOpen Computers & Internet
I want to disable user log in on an older computer atx micro atx cpu 133MHz what jumpers will disable the user log in?? after boot it want the user and password and this machine was bought without documentation at a goodwill store. it has the windows 2000 professional nt installed. the make is A open AX 34
  • walkertexr Nov 18, 2009
    I can get into the setup part upon boot, when the boot is finished windows starts. then the user log in is there and I can not log in to open up window os normally; being an older machine is only goes to last good configuration, in the boot sequence it is set to c, scsi, a. when i tried to clear the cmos it just won't boot. i tried the jumpers next to the pci connector with no avail.
  • qwertyomen
    qwertyomen May 11, 2010
    What kind of user login? is it a bios login, or an OS login?
  • 728 Answers
Hi walkertexr
You can clear the cmos, which will reset the password on the motherboard, by the following:
  1. Turn off the system and unplug the AC power.
  2. Remove the ATX Power Cable from the Connectore PWR2
  3. Locate the JP14 and short Pins 2-3 for a few seconds
  4. Return JP14 to it's normal setting by shorting pins 1-2.
  5. Connect the ATX Power Cable back to connector PWR2
  6. Plug in the ATX Power Cable back to the System,
That should do it. Here's a really bad picture but it should give you an idea of where the jumper is.
Good Luck,
Mark
Posted on Nov 20, 2009
NVIDIA GEForce 8400 GS drivers wont recognize video card win7 ultimate 64bit
The usual problem is forgetting to disable VGA.
Make sure the JPG1 jumper is set to 2-3.
This jumper is below the PCI-X slot closest to the CPU.
Jan 18, 2014 | SuperMicro X7SBE - motherboard - ATX -...
Micro star mian board passward on bios ms-6724
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 02, 2011 | Intel MicroStar MS-6724 Socket 478 P4...
How to adjust jumper settings of ecs mainboard mcp61m-m3
onbly jumpers on that board should be for bios cmos clear. the cpu setting snd such are to be adjusted inside the bios setup utility.
Mar 09, 2011 | EliteGroup ECS MCP61MM3 (V10) AM3 NVIDIA...
Computer freezes upon startup. Can rarely get it to fully boot up.
I had a similar problem with mine, I had a secondary hard drive that went bad causing my computer to drag & take 4 ever 2 start up, I disabled the 2nd drive & eventually replaced it 2 fix my problem, U might try 2 disable it 4 a test.
Dec 26, 2010 | MSI H55M-P33 LGA 1156 Intel H55 Micro ATX...
Chasis intruded ,after changing cmos battery also the sameproblem
Either jumper the chassis intrusion header on the motherboard with a striaght jumper(like you'd find on a hard drive), or, easier, somewhere in the bios setup you can set Chassis Intrusion detection or reporting to disable.
Sep 08, 2010 | ASUS P5GC-MX/1333 - Motherboard - micro...
What is max new cpu speed to change for old cpu ? k7sv266ad
The KT266A is a VIA motherboard chipset,
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
The motherboard chipset for your motherboard, consists of a Northbridge, and Southbridge chip.
The Northbridge is a VIA 8366A
The Southbridge is a VIA VT8235
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
[Note*
CPU = Central Processing Unit. Another term used is Microprocessor, or Processor for short ]
The Northbridge chip handles the faster capabilities of a computer.
Handles the Processor, Ram Memory, and HIGH-speed graphics.
[A graphics card installed into a PCI expansion slot is Not high-speed graphics.
Integrated Graphics is Not high-speed graphics.
AGP and PCI Express are high-speed graphics.
If you have an AGP graphics expansion slot, it is handled by the Northbridge chip.
If you have a PCI Express expansion slot, it is handled by the Northbridge chip ]
The Southbridge chip handles the slower capabilities of a computer. This is shown in the diagram.
The VIA KT266A's Northbridge chip, (VT 8366A) supports AMD processors with UP TO a 266MHz Front Side Bus.
(266MHz FSB)
In the chart you see under the FSB heading -> 100 - 133MHz
100MHz to 133Mhz.
AMD processors are 'Double-Pumped'.
Therefore 133MHz becomes 266MHz.
233Mhz with the jumpers at their present positions?
Weird!
Looking at the motherboard, as it is mounted in the computer case; Processor to the Top, Ram Memory slots to the Right,
5 White PCI slots to the Bottom;
The J4 jumper is above the CMOS battery.
The CPU Frequency Select jumper.
(The J1 jumper is right next to the CMOS battery. To the left. That is the Clear CMOS jumper)
The jumper has 3 pins. Number 1 pin is on the LEFT.
From Left to Right; Pins 1, 2, and 3.
With a jumper block,
http://en.wikipedia.org/wiki/File:Jumperblock-shunts.jpg
,on Pins 1 and 2, you have a 100MHz FSB.
With a jumper block on Pins 2 and 3, you have a 133MHz Front Side Bus.
Processor you pick have a broken pin?
You can use AMD Athlon processors with up to a 133Mhz FSB, or AMD Duron processors with up to a 133MHz FSB.
[Actually 200MHz FSB, and 266MHz FSB. Remember what I stated about Double-Pumped ]
Example,
http://www.weirdstuff.com/cgi-bin/item/13160
Here is a link to a free User Manual, for the Syntax SV266A motherboard,
http://www.scribd.com/doc/41762039/Manual-Sv266a
(Just keep scrolling down)
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 24, 2010 | Syntax SV266A SKA KT266A Motherboard
I added a Pentium P4 2.66Ghz cpu 533FSB, Bios appears and says the due to new cpu installed system has started at 64Mhz please select correct Frequency. I select 2667 Ghz and 133Mhz saved and restarted....
Turn the computer off.
Turn the computer on.
Wait a minute or two -- it may "time-out" and reset it to the "slowest" speed.
If that fails, look closely at the motherboard,
or read the manual for the motherboard, to find a "clear BIOS" jumper.
Turn the computer off. Move the jumper from "1-2" to "2-3".
Wait a few seconds. Move the jumper back to "1-2".
Turn the computer on, with the "default" settings.
Oct 28, 2009 | ASUS P4S533-MX Motherboard
2600+ with ASUS MB A7V266-E/AA
Here is the CPU Support list from Asus Support, for the Asus A7V266-E,
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=A7V266-E/AA&product=1&os=17
Scroll down the list. 34th one down, that is listed.
1.Did you get the Athlon XP 2600+ that has a 266MegaHertz, (MHz), Front Side Bus? (FSB)
The AXDA2600DKV3C?
There is an Athlon XP 2600+ that has a 266MHz FSB, and one that has an FSB of 333MHz. <-This one Won't work.
Model number ->AXDA2600DKV3D will Not work.
Both are Thoroughbred A/B Core models.
The AXDA2600DKV3C has a 12.5x multiplier.
Your 1900+ has a 12x multiplier. (AXDA1900DUT3C) They both have an FSB of 133MHz. (Shown as 266MHz because AMD processors are 'Double-Pumped')
A.The AXDC2600DKV3C will not work. It has a 16x multiplier. (Thorton Core)
B.The AXDC2600DKV3D will not work. It has a 333MHz FSB. (Thorton Core)
C.The AXDA2600DKV4C will not work. It has a 15x mulitplier. (Barton Core)
D.The AXDA2600DKV4D will not work. It has a 333MHz FSB. (Barton Core)
E.The AXDA2600DKV4E will not work. It has a 400MHz FSB. (Barton Core)
2.Are the jumper blocks -> CPU RATIO, and SYSCLK, still set in the Jumper Free Mode?
By the factory default settings these jumper blocks, (DIP switches), should already be set to Jumper Free Mode.
The white DIP switches should be in the OFF position. (The white switches will be DOWN, towards the numbers on the jumper block CPU RATIO. They will be UP, away from the numbers, on the jumper block SYSCLK))
The CPU RATIO jumper block is right above the processor. It is a blue rectangular block.
The SYSCLK jumper block is down the motherboard, right below the AGP graphics card expansion slot. (And above the first PCI expansion slot)
If those two jumper blocks are not set to Jumper Free Mode, set the DIP switches in the jumper blocks to this setting.
Now go into BIOS Setup. In the main menu use the Right Side Arrow key on your keyboard, and highlight Advanced.
If -> CPU Speed is set to Auto, you won't have access to set your CPU parameters. If it is set to Manual, you will see them. If it's set to Manual, write down the headings, (CPU:System Frequency Multiple, System/PCI Frequency (MHz), and so on) Write down the numbers to the right of these headings. If something goes wrong, you can go back into BIOS Setup, and change them back.
1.CPU:System Frequency Multiple should be
12.5X
2.System/PCI Frequency (MHz) should be
133/33
3.System/DRAM Frequency Ratio should be
(Auto)
4.CPU Vcore should be (1.750)
5.CPU Level 1 cache, and Level 2 cache should be (Enabled)
6.CPU Level 2 cache ECC Check should be (Disabled)
7.BIOS Update should be (Enabled)
8.PS/2 Mouse Function Control (Auto)
9.USB Legacy Support (Auto)
10.OS/2 Onboard Memory >64M (Disabled)
Leave the rest alone.
The AXDA2600DKV3C uses 1.65 volts, has a 12.5 clock multiplier, and a 266MHz FSB. (You will see 133MHz, and set all your settings to 133MHz. AMD processors are 'Double-Pumped'. Intel processors are 'Quad-Pumped')
Aug 10, 2009 | ASUS A7V266-E (A7V266-E AA/PA/WOR)...
No Boot , new P5QL-EM mother board
Check the heat sink ontop of your cpu sounds like bad connection and it will cause it to do as you describe
Aug 04, 2009 | ASUS P5QL-EM - Motherboard - micro ATX -...
List of cpu support for pga 370 motherbord
The 810E Micro-ATX can only support the following processors
Intel Pentium 3 / Celeron
Jan 31, 2009 | Intel FC-PGA2 Tualatin Adapter for Socket...
Computers & Internet Logo
273 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Matthew Spark
Matthew Spark
David
David
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
