Question about Kenmore Oasis HE 27082 Top Load Washer
The auto temp is out of control. The temp. is changing and beeping. The Estimated Time Remaining keep on changing and beeping.
  • 15,935 Answers
This symptom indicates a stuck key on the user interface control board.
Replacing this control board would most likely fix this type of problem.
The part number for the user interface for this model is 8564374.
You can order this part from SearsPartsDirect.com, RepairClinic.com, PartSelect.com etc.
The procedure for replacing this control board is shown in the images below.
Before buying any parts I suggest you access the interface ribbon and disconnect it and then connect it back and see if there is any improvement.
You might also remove the interface from the console and check the console for any stuck buttons.
Remember to unplug the washer first.
http://media.fotki.com/1_p,wkgbsdrbswtkdqwxgtqsskgwtqkq,vi/ksgtwdgrtxkrrffsdss/1/1303472/5961857/image29464img-or.jpg
http://media.fotki.com/1_p,sqrbbsbrrbwrbdtxgtqsskgwtqkq,vi/kbqtdwdswxkbswddwbg/1/1303472/5961857/image23056img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!
Posted on Sep 16, 2010
Door ajar alarm keep beeping every 5 minutes and door is shut
was the replaced control panel a used unit
are the door hinges and seals ok
still maybe a faulty door sensor
Jun 17, 2016 | Refrigerators
Tip
Dryer Dry Time Appears to Jump or Stall During Auto Dry Cycles
The operation of dryers during the Auto Dry Cycles is based on the moisture content of the clothes as they cycle over the moisture sensor. At the start of the cycle, the default estimated time is displayed depending on the cycle selected. The moisture sensor feeds information to the control based on the "wetness' of the clothes during the first 5 minutes of the cycle. The control then calculates and display a new estimated time making the time appear to "jump".
Recalculation happens again based on the reduction in the "wetness" of the clothes when the Estimated Time Remaining is between 15 to 5 minutes. The control will extend the cycle and display the Estimated Time Remaining unchanged if it "sees" no significant reduction in the wetness level of the clothes. The dryer will run longer than initially projected and give the appearance that the displayed time has "stalled".
Clean the sensor bars for any films or dirt build up to make sure it sends accurate information to the control. Level the dryer front to back and side to side to ensure the clothing will tumble properly and making good and proper contact with the moisture sensor bars. Check the dryer vent duct for any restriction to ensure a good air flow as the operation of the Auto Dry Cycles is based primarily on the air flow condition.
It is highly recommended to clean the lint filter before every load and make sure the dryer is grounded at the wall plug.
on May 17, 2010 | Whirlpool WED9200SQ Electric Dryer
What does LF mean?
It is a long fill error. It flashes when the machine control board detected no change in the water level or the water level is not reached in a certain period of time during the fill cycle. Water is probably not entering the tub due to the water inlet valve not functioning or water enters the tub but not properly due to clogged fill hose screens.
Press the Pause/Cancel button to clear the error on the display. Remove the fill hoses from the water inlet valve assembly at the back of the machine and check the screens. Clean the screens and replace it if necessary. Make sure that the water supply valve is open and water is present.
Put the machine in standby mode (only the Clothes Clean indicator is on) and activate the Manual Diagnostic Test Mode to check the operation of the water inlet valve.
  1. Select any one button except Power, Stop, and Stop.
  2. Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds
  3. Press the same button when all indicators on the console are illuminated and "88" is displayed on the Estimated Time Remaining display. A single beep sounds and display shows the two digit console ID number for 3 seconds. The displayed ID number will change to "00" and the Add a Garment indicator will flash.
  4. Select Whitest Whites cycle.
  5. Press Start>Wash/Rinse Temp. The water inlet valve should turn on and fill the tub according to the Wash/Rinse Temp selection.
  6. Press Start to turn off the valve.
  7. Press Stop or Power button to exit diagnostic test mode.
Feb 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
How do you turn off the oil change light after the oil has been changed?
GM Oil Life System This system calculates the estimated percentage of the engine oil�s remaining useful life and alerts you through the DIC when it�s time to change the oil by displaying CHANGE OIL. Please remember to always reset the oil life system after an oil change.
Reset the oil life system Press and hold the control stem for more than two seconds while OIL LIFE is displayed. When completed, the system will reset and a beep will sound.
Good Luck and Remember.
Change Your Mind, Not Your Oil.
Use the First In Synthetic Motor Oil's.
See My Bio For Information & Contact Details.
Nice, but doesn't work for my 2006 Silverado. My manual says:
1. Turn ignition key to RUN with engine off.
2. Fully press and release the accelerator pedal 3 times within 5 seconds.
If the OIL LIFE RESET message flashes for 10 seconds, the system is resetting.
3. Turn the key to LOCK.
Aug 14, 2009 | 2006 GMC Canyon
Auto Temp Control
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jul 15, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Water level buttons keep cycle through continuously and the estimated time changes with the soil level.
hi thanks for the question. the actions of this washer that you are describing is normal these washers are a real pain in the you know what but it is normal welcome to the way they are building them to-day
Sep 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Estimated time 2minutes blinking with an "F" what does this mean?
Are you certain its not blinking F 02 I have a similar problem and the only way I can get it to finish is to hit pause and let it sit overnight befor hitting start again, I cleaned out all the huses and the pump filter which were a mess wet lint and change respectivly, This helped (now I get one load done before it stops)
Mar 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Have to dry close twice on automatic, or once on timed. Random triple beeps.
Sounds like the drum belt has broken. It's connected around the drum and motor pulley. Without the belt turning the drum it will be near to impossible to dry the clothes, Hope this helps, Sea Breeze
Oct 28, 2007 | Whirlpool GEW9250 Electric Dryer
Kenmore Oasis HE 27082 Top Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
