Microsoft Office Professional 2007 Full Version for PC Logo
Posted on Nov 18, 2009
Labels are not set up with correct dimensions
Anonymous
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Nov 19, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
2009
Points
18
Go to Mailings > labels > Options > Select Printer Info > Label Vendor > Product Number
Zebra LP 2844 printing off center
If your Zebra LP 2844 printer is experiencing shifting or off-center printing, there are a few possible causes and troubleshooting steps you can try:
  1. Check print settings: Ensure that the print settings on your computer or label design software are correctly configured for the label size and layout you are using. Make sure the label dimensions and print margins are set accurately.
  2. Calibrate the printer: Perform a calibration on the printer to ensure it is properly aligned. To calibrate the Zebra LP 2844, follow these steps: a. Turn off the printer. b. Hold down the feed button. c. While holding the feed button, turn on the printer. d. Release the feed button once the green status light begins to flash. e. The printer will feed labels and automatically adjust the label alignment. f. Once the printer stops feeding labels, the calibration is complete.
  3. Adjust label position sensors: The LP 2844 has label position sensors that detect the start of each label. If these sensors are misaligned or dirty, it can cause shifting or off-center printing. Clean the sensors using a lint-free cloth and ensure they are properly aligned.
  4. Check label alignment: Ensure that the labels are loaded correctly and aligned properly in the printer. Make sure they are inserted straight and centered in the label guides.
  5. Inspect the print head: Check the print head for any debris, adhesive residue, or damage. Clean the print head with isopropyl alcohol and a cotton swab if necessary. A dirty or damaged print head can affect print quality and alignment.
  6. Update or reinstall printer drivers: Ensure that you have the latest printer drivers installed on your computer. If the drivers are outdated or corrupted, it can cause printing issues. Visit the Zebra website and download the appropriate drivers for your LP 2844 model.
  7. Test with different labels or ribbons: If the problem persists, try using different labels or ribbons. Sometimes, the issue could be related to the specific media being used.
1helpful
L7157 HP Laser Jet P2055
Unfortunately, this is a common problem. I suspect you're using MS Word to make the labels. Word takes the font and the dimensions of the labels and is supposed to transfer the correct sizes of everything to your printer. All to often it doesn't do this correctly.
One thing to try is a couple different fonts to see what happens. (use plain paper to experiment, it's cheaper.)
The other way is to set up a regular page in MS Word with 3 columns and fill the page with copies of your information. The trick is to adjust the font size on the empty lines between your information.
address line 1
line 2
line 3
[font size adjusted empty line]
address line 1
line 2
line 3
We have just gone live on sage 1000 and are trying to print labels designed in sage paperless to send to our Datamax m-4206. Labels print but we cannot get the information to line up on the labels. Is...
This can be caused by either the software, or the printer's electronic or mechanical settings. Software will usually override the printer settings for print speed, temperature, label dimensions, etc. In order to fully diagnose, I would need to know if the print is too high, too low, too far left or right, or skipping a label, etc.
Please teach me how to use my HPF4185 to print envelopes. Thanks.
Hi
Use the product software, also known as the printer driver, to change the print settings for your envelope size and type. Then, use the Envelopes and Labels tool in Microsoft Word to select your envelope size.
Step one: Adjust the print settings
-In Microsoft Word, click File , and then click Print .
-Make sure that your product is in the Name drop-down list box, and then click Properties .
-Click the Features tab, or the Paper/Quality tab.
-Select an envelope size from the Size drop-down list.
-If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
-Select Custom from the drop-down list.
-In the Custom Paper Size dialog box, type a name for the new custom size.
-In the Width and Height boxes, type the dimensions.
-Select the unit of measurement, and then click Save .
-Click OK to close the Custom Paper Size dialog box, and then click OK again to close the Properties dialog box.
NOTE: You must exit the Properties dialog box to apply your changes.
Open the Properties dialog box again, and select the new custom size from the Size drop-down list.
-Select the paper type.
-In the Paper Type or Type is drop down list, click More .
-Click the desired paper type, and then click OK .
-Select the paper source from the Paper Source drop-down list.
-Change any other settings, and then click OK to close the Properties dialog box.
Step two: Set the correct envelope size
-Set the correct envelope size in the Envelopes and Labels dialog box before printing envelopes.
-In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
-In the Envelopes and Labels dialog box, click the Envelopes tab.
-Click Options .
-From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
-Click OK , and then click Close to close the Envelopes and Labels dialog box.
-Click File , and then click Print to print the envelope.
NOTE: When you finish printing the envelopes, return the paper size and the paper type settings to the defaults.
Regards
Riztech
Changes from 1 to 3 pages for Excel Print Area
verify the page dimension in your driver together with the header and footer dimensions
Labelsi
you need to go into page setup and enter the dimensions of the labels; there maybe a drop down menu with the correct size. This is within word.
Lables do not work
Dear Carol this sounds like a page setup problem more than MS word version problem. You might like to re adjust the page size, dimensions and text to rectify this problem. You can also try emulate same dimensions from your older verion of MS word into new one. There are alot of things that are not compatible with new MS word like file extension .docx cannot be opened in previous versions.
You can also use image editing softwares like photoshop and corel draw for making labels, way better than MS word.
If this was helpful kindly press solved.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
