Question about Sharp AL 1631 Copier
There is a red arrow light flashing at the upper feeder area. What does that mean?
  • Sharp Expert
  • 257 Answers
There is a paper misfeed so check for a jammed paper inside the copier.
Posted on Nov 20, 2009
Printer was working the stopped with red light flashing. I have disconnected power waited 1 minute then reconnected to reboot printer but light is still flashing.
Usually a red light means that there is an error. Normally it means that there is a paper jam somewhere in the process. It might even be as small as a torn edge that is setting off the sensor. Make sure that there is paper in the tray, none stuck in the feeder or anywhere else, and that the toner/ink is properly set.
Apr 01, 2011 | Office Equipment & Supplies
The red light with the arrow pointing down keep flashing and it won't print. It the print the first page just fine. What does it mean when the red light is flashing?
Its either a paper jam error or your printer is out of paper,open your printers back cover and check properly to see where the paper jam is located.
Jun 29, 2010 | HP Deskjet 5940 Photo InkJet Printer
When should I replace the toner cartridge? I found that red light is flashing( the lower light, totally there are 2 lights: upper one is green now). I don't understand what does it mean.
It mean when your toner is near empty,then red light flashing.tow light is fixed or red mean toner cartridge is empty.must be replace toner cartridge.You buy a new cartridge and put in your printer then printer is OK.
you can also get better idea please read printer user guide.
Mar 04, 2010 | Samsung ML-2240 Laser Printer
What does the flashing red hand in the upper right
The flashing red light is warning you that the shutter speed will be too long for handholding the camera. Put the camera on a tripod or other stable surface, and/or use the flash.
Nov 08, 2009 | Nikon COOLPIX S9 Digital Camera
Red Flashing Icon
The icons from the left: 1. Power indocator 2. Hard Disk indicator --> it is a tube icon, not battery, but means hard drive. 3. Power Source indicator 4. Bluetooth indicator
The third from left means the power source indicator. Normally it is light green. If there is battery problem (can not charge or battery overload) it flashes amber/orange. If flashes red, it indicates that the battery power is low. You need to change the battery or connect the AC adapter.
Regards,
Dapid Candra
Dec 02, 2008 | Dell Latitude D505 Notebook
Document feeder does not work
cleaned some sensors under the feeder, if possible, clean it with blower to solve the problem.
Aug 04, 2008 | Canon NP 6050 Copier
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
A red image pops up when I take a pic
I chose the DMC-TZ3A since I didn't know what the letter was at the end of the model number for your particular camera. If this is the camera
Here is a link to the manual
If not
Here is link to the Lumix series cameras
Pg 25 indicates that flashing red in the upper right corner is the battery needing to be recharged. If the battery was recently recharge and its turning red on the screen, it could be that the battery isn't holding a charge and may need to be replaced.
I didn't see any other error messages on the screen indicating that icon unless b,c, or d models have a different error message in that area of the screen.
Jul 11, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Flash issues
It means that the battery is charging the flash! Wait a while and it should stop. Then take your photo.
Do make sure your battery is fully charged.
Apr 05, 2008 | Olympus FE-220 Digital Camera
Sharp AL 1631 Copier Logo
69 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
