Question about Sharp Viewcam VL-Z1H Mini DV Digital Camcorder
Vl-z1h ejects cassete when trying to load error code e007 comes up also the word DEW appears on screen. Have had this problem before Sharp have repaired it twice its come back .Have kept it dry tried other cassetes to no avail.
  • 169 Answers
SOURCE: sharp viewcam vl z1
there are mechanical problem of your camera...may be one of the motor is stuck up...check the drum motor if free wheeling..is it the common problem of that model
Posted on Aug 25, 2007
  • 14 Answers
SOURCE: Canon ZR60 Mini DV Digital, remove the cassete message
This is a tape transport problem and is expensive to fix. Unless you know a cheap tech, it's time for a new one. Be patient loading and unloading tapes. This is usually what causes this problem. The Yellow warning sticker is REALLY important. Another important item is to always use the same brand of tape because switching tapes causes a gummy build-up the makes tapes get caught in the machine.
Videoteacher
Posted on Jan 08, 2008
SOURCE: dew lamp lights up and camera shuts down
http://ataplow.googlepages.com/sharp-dew-problem
Posted on Dec 10, 2008
SOURCE: The Casset is rejecting back
I got the solution from your net only.Thanks it is wotking presently.you have to do simply take out the cassete and keepp the cassete door open.And then take both the battery out i,e one main battery and another small battery and leave camera in this psoition for two hrs and tehn place back battery in its position and then load cassete .It will work.I have tested it.Thanks a lot.
BK PRASAD
Posted on May 12, 2009
  • 269 Answers
SOURCE: My sharp viewcam Model # VL-E30U has a snowy
Sounds like dirty video heads.
Try running an appropriate head cleaning tape. After two or three attempts if there is no improvement it's time to see a tech.
Al
Posted on Feb 11, 2011
Testimonial: "the best web site on yje internet. You are great"
I have a sharp vl-z300 camcorder which is displaying an e007 error can you help
The 007 error is associated with dew sense and is a fairly routine repair.
PC board traces open at System Control IC, and will need to be hard-wired. I would suspect that any reputable electronics service facility should be able to perform this repair.
To find a Sharp authorized center in your area, contact Sharp support at sharpusa.com/CustomerSupport.
Hope this helps (remember to rate this free answer and leave a testimonial).
Sep 27, 2011 | Sharp VL-Z300U Mini DV Digital Camcorder
My digital camera wont work and it keep saying DEW. what does that mean? it is a sharp vl-z5 digital camera
I HAVE A VIEWCAM VL-Z7, I STARTED TO CHARGE MY BATERRY TO THIS JUNKY UNIVERSAL CHARGER AND FOR SOME REASON IT TURNED ON BUT 1 MINUTE LATER IT TURNED OFF AND NEVER TURNED ON AGAIN
Dec 11, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Tape won't load + dew fault intermittent
Modification has to be performed by sharp authorized cervice.
Oct 24, 2009 | Sharp Viewcam VL-Z1H Mini DV Digital...
Sharp VL-Z1 will not load the cassette...
Modification is available to fix this problem, contact sharp repair facility.
Oct 18, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
I have a Sharp ViewcamZ VL-Z900. DEW error
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
Sep 18, 2009 | Cameras
Dew lamp lights up and camera shuts down
Nov 17, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
Dew liht comes on and camcorder shuts off
I had the same problem with a VL-Z3U, there was no home fix, the dew sensor needed replacing costing $130 CAD
Jun 18, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
E007 and DEW indicator
Few restarts fixed this for me but I know this is going to come back again soon.
Mar 30, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp VL-Z1 Mini DV
posted on Aug 20, 2007 Hello and please any body shed some light as to why would the cassete holder door will not close. It was ok, and suddenly I got the ?ject tape"warning. I took the cassete out but I saw there was some loose tape. After that it does not close. Thanks everyone.c
Jan 18, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp Viewcam VL-Z1H Mini DV Digital Camcorder Logo
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
