Question about Brother MFC 240C All-In-One InkJet Printer
I just bought a Brother LC51BK cartridge. Do I remove the white pin before installing?
    President:
  • 2,306 Answers
You only remove the orange cap that twists and pulls off, don't remove the pin...
Posted on Nov 18, 2009
How can I fix my ink problem?
It is possible the ink carriage and print head are very dirty and needs servicing.
Aug 25, 2014 | Brother LC51BK Print cartridge, Inkjet...
The black ink cartridge LC51BK for brother mfc-240c is not printing
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Dec 31, 2012 | Office Equipment & Supplies
My brother printer has an error unable to clean 50
XXXXX XXXXX look on the printer, do you have these keys:
Menu/Set, Black Start, or Function?
Brother Printer Support
Sep 28, 2012 | Brother LC51BK Print cartridge, Inkjet...
Brother Printer 2150N - toner light has come on & toner is OK
Bought a 2150 in 2007. In 2008 toner light came on. Bought a new toner cartridge and installed. Light would not go off. Called Brother. They had us do the following:
1) Turn power off
2) Open front cover
3) Press white button (left side) 2 times and hold
4) Turn power on
5) Press white button 6 times and hold. All 3 lights should come on.
6) Close cover
7) Press blue button 3 times. Should print demo page.
We took the new cartridge out and saved it. The original is still working fine.
Feb 24, 2010 | Brother HL-2150N Laser Printer
Brother Printer - Keep complaining about No Ink
Hello.
From Brother support:
"The message #NO CARTRIDGE# may appear if one or more of the
cartridges are not properly installed or an ink cartridge is
defective,such as air bubbles, or empty. Verify all the cartridges are
installed correctly and they are not empty or defective by following
the steps listed below:
NOTE: Cartridges that have already been installed are no longer
vacuum-sealed; it is very important that the cartridge remains upright.
If the cartridge is removed and placed on its side, air may be
introduced into the ink supply tubes, requiring repeated cleaning
before print quality is restored.
a. Lift the top cover to the open position until it locks securely
into place.
b. Then, remove all ink cartridges by pulling the white plastic hook
toward you and pulling the cartridges up and out of the machine.
c. Because all the ink cartridges have been removed, the LCD will
prompt you to install each color cartridge.
d. Important!! Reinstall the ink cartridge(s) in the order of the LCD
is instructing you too. Press down FIRMLY on the top of the cartridge
until it is fully seated. Push the white plastic hook towards the
cartridge to verify it is fully latched over the top edge of the
cartridge.
e. Close the top cover. The LCD will ask you if you have changed the
cartridge to new. Press 1 for yes and 2 for no. Press 1 for yes for
each color. The LCD will alternately show CLEANING and PLEASE WAIT. When the Brother machine completes the cleaning cycle, the LCD returns to Standby mode.
Hope this helps.
Dec 10, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printed page do not match screen colors on a MFC-3360c brother all-in-one printer
Clean print head it may work properly. else
find out which color not working. replace the color ink cartridge
LC51BK Black color
LC51C Cyan
LC51M Megenta
LC51Y Yellow
Aug 25, 2009 | Office Equipment & Supplies
I have a Brother 885cw and the black print is coming out very light. All other colours are fine. I have fried cleaning the black numerous times with no luck.
It is very likely that the black injet cartridge needs to be replaced. The typical cartridge will last through 500 copies (1 ****) and if this is the 1st cartridge that came with the machine, their capacity is about 1/2 that. The black ink cartridge you will need is #LC51BK and can be rchased online or all major office supply stores.
Aug 12, 2009 | Office Equipment & Supplies
Not recognizing cartridge
myprinter tells me"noblack ink," they are both b it is brand new cartridge why?this is the second black ink cartridge i have bought it says the same thing.i always buy "BROTHER"
Oct 27, 2008 | Brother MFC 420CN All-In-One InkJet...
How to refill Brother printer cartridge for model MFC 240C Cartridge # LC51BK
hi , Do this Pop-off the color top, removed the clear rubber ball ring/valve. Now you can usual refill kit to poor in the appropriate in color. After filling the ink,replace the above two in reverse order and taped down with clear type. Replaced the cartridge and the appropriate slot... and your good to go! be carefull, sometimes they do leak....
Jul 27, 2008 | Office Equipment & Supplies
Brother mfc 7820n toner cartridge issue
Look at the left side of the cartridge next to the blue release button. There should be a white tab in an arc slot. If the white tab is anywhere but all the way to the right, it does not recognize the cartridge. Try truning the drum and pushing the white tab down to the right, it shoudl reset it and find the cartridge.
Jan 15, 2008 | Brother MFC-7820N Laser Printer
Brother MFC 240C All-In-One InkJet Printer Logo
95 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
