Question about ViewSonic VP230mb 23.1" LCD Monitor
Screen resolution the screen resolution is poor one side of the monitor has great picture the other side has a greying color. When the computer is powered down and the monitor is on the full screen is black on one side and a grey black on the other., there is a distinct transition between color changes. Is this fixable with a bulb replacement or is the LCD screen going. please advise.
  • 45 Answers
SOURCE: Monitor Menu Settings
there is in the menu that calls for " RECALL ", press this to go to original setting, and change setting again to your choice, individually.
Posted on Oct 01, 2008
SOURCE: ViewSonic VA912b (Back light with blank dark screen)!
Wow, many people are having this situation. Mine died out about 2-3 months ago. Same problem. need help :[
Posted on Oct 14, 2008
  • 225 Answers
SOURCE: Black screen, power button flicks
The monitor should come when the power button is pressed once - period. If not, and it continues to happen when connected to another PC, then the hardware is having trouble powering up the panel / ccds and it should be replaced/serviced according to the terms of the warranty. I suggest to bring it to an authorized service center for proper diagnosis & fix the problem. regards
Posted on May 23, 2009
  • 519 Answers
SOURCE: ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Posted on Jun 12, 2009
  • 3278 Answers
SOURCE: 1440x900 Monitor seems to think it is a 1680x1050 screen @ >19"?
Try reinstalling the video driver (Control Panel - System - Device Drivers - Video ... ) Good luck
Posted on Jun 13, 2009
Can anyone identify this PC Wallpaper
that's probably that your wallpaper isn't fit with your monitor resolution,for example,if your wallpaper size is 1280x1024 but your screen resolution (size) is 1024x768,it doesn't fit your screen and the wallpaper will only show half or even less
to check your current resolution,click
Start->Control Panel->click Appearance and Personalization->Click "adjust screen resolution" on the Display categories
you can see your current resolution and also you can set your resolution
To check the picture resolution,right click on the picture,select properties,click the Summary tab,and it doesn't show the resolution, click Advanced on the Summary tab
But I suggest you to download the wallpaper with a fit size instead of changing the screen resolution,because too high resolution will make your screen goes black
geez,i'm so sorry for my poor english
please rate this solution if it's work and let me know if you still has a problem.and thanks for using Fixya!
Aug 28, 2012 | Toshiba Computers & Internet
AMD sempron 2600+ I have grey vertical lines on monitor have had no problems for 6 mths . i spoke to the person who set up my pc for me. they said that my graphics card is better than my monitor and...
Can you try to connect the Monitor to another computer and connect a different monitor to your computer - this might be a way to understand if the problem is in the "Monitor side" or the "Computer side - graphic card - driver". Another option is to lower the resolution and see if the problem still exists: Try to change the screen resolution to 600x800 in
->Settings->Control Panel->Display on the "Settings Tab" (the right most tab)
Apr 28, 2011 | Computers & Internet
My monitor will is all grainy I have connected it to a Sony Vaio (4 months old) downloaded latest drivers etc but still [poor quality -
I think it is your screen resolution it needs to be increased, go through my published guide entitled How to set your Desktop Screen Resolution?
Increased resolution and colour quality will give you an excellent picture.
Jan 30, 2011 | Acer S201HL Monitor
My monitor's screen resolution and color depth are at a very very low resolution and I am unable to increase/improve this. Consequently, everything is fuzzy and colors are impossible to view. My monitor is...
please try doing a factory reset of the monitor.
please press the menu button on the monitor itself. you can easily locate the buttons below or on the right hand side of the screen on the monitor panel.
select the factory reset /recall options with the help of the arrow/+ - buttons.
this would reset your monitor color settings to default.
Jan 22, 2010 | CTX Computers & Internet
My monitor will not maintain a picture. The monitor comes on fine and the picture is normal and clear for two seconds then appears to go dark, however i can still see a ghost imade of the content on the...
This is the back light. If you are lucky the solder or a cable has let loose on the bottom of the screen inside the case and you can redo them. This of course voids any warranty. If you are unlucky you are looking at a screen replacement.
Dec 31, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
I see two screens on my desktop.
You are using a screen resolution that is not supported by your monitor. Start the computer in safe mode and open display properties. What ever resolution and color depth is (usually 640x480 and 16 colors), click OK button. Restart the computer. Go to display properties and increase the color depth to the maximum value. Set the resolution to 800x600. Restart the machine. Do you see double screens? No? Great! Now try increasing the resolution to the next level. (1024x768). When you click 'apply' you will be give 15 seconds to say it is OK. So if you see double screens, do not click anything. Display will revert to 800x600 resolution (and you will see only a single screen!)
Sep 21, 2008 | ASTVision 5B 15 in.CRT Conventional...
the vga mode not suppopt is on and not working
May 07, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
Poor image quality
hotoPC 650 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. Additionally, if your pictures are taken in 1154 x 864 mode, try increasing your video resolution above 640 x 480. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
ViewSonic VP230mb 23.1" LCD Monitor Logo
61 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
