Question about Fellowes PS70-2CD Shredder
Need to replace the 7 gallon basket. It has become to brittle to use anymore. Any suggestions? Many thanks.
  • 3,594 Answers
Contact Fellows @ 800-955-3344
DickyO
Posted on Nov 18, 2009
Testimonial: "Thank you for your promptness. Item is available for $16.95 + shipping. Total is less than $25.00."
Valve repair kit for Schroedahl leak-off valve
Usually, the rubber gasket parts had become brittle. Just replace these parts and the entire component is now "refurbished" and good to go for another 5 years.
Nov 12, 2013 | Valve Repair Kit
Tip
THANK YOU !!!!! and thanks to my 15 yr mechanically inclined son...he did do...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F02” error code.
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. Check the drain hose to make sure it is not kinked or clogged.
  2. Check the electrical connections to the pump and ensure the pump is running.
  3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
on Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Is it better to replace a timing belt by mileage on it or time
As a rule mileage is the better gauge, but if the vehicle has sat unused for months at a time, then It is best to change it. If the car sits for long times, the rubber dries out and becomes "molded" to the position it is sitting in, becoming brittle and prone to breaking.
Sep 19, 2011 | Toyota Camry Cars & Trucks
Have no chlorine output! Have put in 4 bags of salt, have also cleaned skimmer box basket, pump basket & cartridge filters. Have noticed that pressure is down to 30kpa when is usually 50kpa. Do I need...
Hi again ... Thanks for the Chat yesterday. Have you considered this article: http://www.directpoolsupplies.com.au/webcontent34.htm (click specifically on maintenance of your salt cell) There are lots of good tips here for the pool owner.
I see that this manufacturer wants 4000 ppm salt (4%) minimum to 7000 ppm salt (7%) maximum which is above the standard here in North America. You are in Australia? According to the manufacturer, your cell may be at the end of its life.
Sudden low filter pressure could be a broken lateral in a sand filter (you would probably have sand in the pool) or a hole in a paper filter (no indicator other than low pressure).
Here are some useful numbers for your 4 X 12 X 30 foot pool:
1440 cubic feet or 40.776259104 cu meters
1 cubic foot = 7.5 gallons or
1 cubic foot = 0.0283168466 cubic meters.
1 cubic meter = 264.172052 US gallons.
1 cubic meter = 1000 liters ( you probably know this stuff though)
I calculate your pool to be about 10800 gallons. The actual gallons per foot is really 7.48 (10771.2 in your pool) but we use 7.5 gallons per foot.
One inch in your pool is 225 gallons or 851.71765 L. This will give you some idea about what chemicals you may have to add with one inch of make up water.
If you were in NJ, and a commercial pool, you would have to have a a 8 hour turn over rate with a filter = 60 square feet and your flow rate would be about 22.5 gallons per minute.
Please keep your water balanced with the proper amount of Calcium (about 350 ppm) your pH at 7.4 - 7.6 your TA around 100 (80 min and 120 max) and your salt per manufacturer recommendation, in this case about 5000 ppm. Cyanuric acid around 80 ("Sun screen" for chlorine) and of course Cl around 3 to 4.
I hope you have found this information helpful. Enjoy your pool, while we shiver here in the North East.
Jan 28, 2011 | Zodiac Duo Clear System Chlorine...
No pot or instructions, how much water do you put in the coffee pot?Need a replacement pot for vp17 series. thank you
You should be able to pick up a replacement/new pot at your nearest Restaurant Supply store. Make sure you get a 64 oz./ 1/2 gallon pot.
Before plugging in your brewer, unscrew the sprayhead located just above where the filter basket sits and replace the basket, pour 3 pots of cold water through the opening on the top if the brewer is empty. This brewer has a reservoir that holds about 2 1/2 pots of water at brewing temperature when heated. Make sure you put an empty pot under the filter basket after pouring in the water. Water will flow from the brew basket when the reservoir has reached its capacity. Once water flows you can then plug in and energize your brewer and replace the sprayhead. It will take about 15 to 20 minutes for the brewer to reach brew temp, you will hear the heating stop. Put an empty filter and a dose of coffee (I recommend starting with a heaping measuring cup of drip ground coffee) into the filter basket, lightly shake it level, replace the basket and pour through 1 full pot of COLD water in the top. For best results pour the brewed coffee into a pre-heated thermal server if you plan on holding the coffee for more than 10 minutes or so.
Enjoy!
Jan 04, 2011 | Bunn VP17-1 Coffee Maker
Maytag fridge no water to icemaker any suggestions
Pour about 2/3 cup of water into ice maker . If it freezes and dumps , replace the water valve . If it does not dump , replace the icemaker . Also make sure the coils are clean beneath refrig , and the clear fill tube , which fills the icemaker , is clear of ice (not frozen up ).
Sep 12, 2009 | Maytag MSD2756G Side by Side Refrigerator
ICE MAKER FREEEZES
my suggestion is unplug frige. for a couple of days! yes you will have to vacate everything. let all ice melt.. have mops and buckets ready for a poss. flood due to so much ice buildup. see if you can disconnect any hoses after thaw and blow in them. make sure fridge is disconnected!. look for any cracked plastic since these can become brittle in time and use 100 percent silicone to seal.
hope for the best!
Mar 18, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
All the shelves have become brittle.
The bottom door bin for your Samsung is part number DA63-01263C. The next shelf up, called the middle guard, is part number DA63-01262A. The "facings" for the bottom two freezer drawers (also called freezer tray covers) are parts DA63-01653A and DA63-01652A. You may order these parts online at http://www.partstore.com/
Mar 05, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Fellowes PS70-2CD Shredder Logo
161 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
