Question about ViewSonic VP230mb 23.1" LCD Monitor
Viewsonic VP230mb Screen resolution is poor one side of the monitor has great picture the other side has a greying color. When the computer is powered down and the monitor is on the full screen is bla
Screen resolution the screen resolution is poor one side of the monitor has great picture the other side has a greying color. When the computer is powered down and the monitor is on the full screen is black on one side and a grey black on the other., there is a distinct transition between color changes. Is this fixable with a bulb replacement or is the LCD screen going. please advise.
bammbammfran
  • 159 Answers
SOURCE: Viewsonic VX910 powers on, screen displays for 1 second then turns off
Blinking on and off is not always a capacitor issue, it is usually caused by faulty transistors at the high output transformers that light the backlights. Crappy board design ! But fixable in most cases.
Posted on Aug 10, 2008
  • 22 Answers
SOURCE: ViewSonic VX2235wm monitor looses power ...
The first thing to try is to make sure the power cable is tight. I know it sounds too easy but with the movement causing the power outage it sounds that or a broken power cable. Check the cable to make sure it is tight and it that isn't it, change the power cable. If neither of these work you probable have a loose connection between the cable plug and the power supply on the unit which will require soldering and professional help to fix.
Good Luck,
Rob Mixon
Posted on Sep 03, 2009
budmrtn
  • 11361 Answers
SOURCE: Viewsonic VA912b. Monitor will only turn on for a
Bad caps in the power supply, common problems. See examples here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20V912B/
Posted on Jan 07, 2010
budmrtn
  • 11361 Answers
SOURCE: my ViewSonic VG1930WM (Black) LCD Monitor wont turn on
You need to open it up and the first place to look will be the power supply, look for bad caps with bulging top, post back what you find so we can guide you further. See example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Mar 01, 2010
pravinbhavsa
  • 348 Answers
SOURCE: viewsonic VA902b too bright. menu control greyed out
open the monitor draw the screw and there is a big black part called E.H.T.to which has preset to rotate it with screwdriver in on condition of monitor untill sufficient brightness will come
Posted on Mar 09, 2010
We understand that your problem is: Hi I have a ViewSonic Viewpanel Vp230mb and I am having this issue as to when I turn it on it will only stay on for a couple of days at a time and then will just shut...
90% failure in LCD monitors are due to bad DC filter caps in the power supply as you can see in my albums.
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 12, 2010 | ViewSonic VP230mb 23.1" LCD Monitor
On half the screen the colors are faded. when a video is watched on the faded half the colors are really bad
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 26, 2010 | ViewSonic VP230mb 23.1" LCD Monitor
My viewsonic has poor image display what can be done.
Change screen resolution and color settings from the 'display settings' area within the operating system.
Dec 05, 2009 | ViewSonic VG700b 17" LCD Monitor
No power
tried another power cable and plugged the monitor directly to other wall outlets. If that does nothing then go to http://www.viewsonic.com/support/customer-service/ and set up to ge the monitor serviced.
Oct 27, 2009 | ViewSonic VP230mb 23.1" LCD Monitor
My screen size will not go back to original size to large to wide
If you are referring to the screensize of your browser you can adjust this by pressing ctrl on the keyboard and using the wheel in your mouse. If this is about how your desktop is displayed you will need to right click on the desktop > screen resolution and adjust the dimensions.
https://support.mozilla.org/en-US/questions/987323
How to adjust Chrome default zoom settings
Jul 12, 2017 | ViewSonic VP230mb 23.1" LCD Monitor
Vp230mb power supply
Follow the ribbon cable from the pwr supply down to the motherboard. Near where it connects there are two "U" shaped wire loop test points. One is positive, one negative, 12V at 7.5amps.
Solder onto these. There is one other "S" wire which is for voltage sense. Don't know what to do with that one.
Inspite of all the wires in the ribbon, half are + and half are minus 12V, but it really needs the 7.5Amps.
Oct 11, 2008 | ViewSonic VP230mb 23.1" LCD Monitor
Viewsonic on a mac runnib osx 10.3.9
I suspect the screan isnot compatable to the other cpu.change the rete and re boot uour compueter.remember to never fix something that is not broke.
Mar 07, 2008 | ViewSonic VP230mb 23.1" LCD Monitor
No power did not work out of the box
I'm looking to get a power supply for a VP230mb lcd.
I'm in chicago and would like to install it myself.
Unless someone can recommned a reasonable local repair shop
Dec 20, 2007 | ViewSonic VP230mb 23.1" LCD Monitor
ViewSonic VP230mb 23.1" LCD Monitor Logo
42 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
