Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
My usb wont be recongised by my computer - SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
    Sergeant:
  • 185 Answers
Start>right click mycomputer>manage> device manager> find your usb device and update driverr manually
Posted on Nov 18, 2009
  • 466 Answers
Just to be sure, verify that it can be read in another computer.
If not, the U3 unit is probably faulty. It may be possible to recover it by reformatting and/or uninstalling the LaunchPad platform with the appropriate utilities.
http://u3.com/support/default.aspx
If the unit does work with another computer, you might have a problem with either the USB port or the USB drivers (those of the USB subsystem, not those of the Cruzer -- unless you're using Windows 98/ME, the Cruzer per se needs no driver whatsoever).
    Novelist:
  • 138 Answers
Try putting the USB device in a different USB port. If you are using a USB hub, move the device to a port that is on the computer.
If this does not work, reboot the comptuer and verify the USB Hubs within the Operating System is working...
Start - Run - compmgmt.msc (this starts Computer Management)
From Computer Management window - click on Device Manager on the left side. Look at the right side and verify the "Universal Serial Bus controllers" are working and there are no yellow question marks.
My pc says it does not recongise one usb cable and so is not printing
can not alin printer heads.coputer does not recogise usb cable connection
Feb 14, 2010 | HP Office Equipment & Supplies
DV output
You can't convert a FireWire cable to a USB cable with just an adapter, or even with software.
Jun 13, 2008 | Canon MV630i Mini DV Digital Camcorder
Usb not recongised
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
The motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in. (VOILA)
Nov 28, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
The SanDisk Cruzer 16GB USB Flash Drive is not working at all
clarification!!! clarification..!
..how u putt password? what did u use?
..is it accesible? can u see somthing wen u plug it?
does ur pc recongise it?
...cant tell u noth man...u need to answer all these questions....cos right now ur the only 1 that can think bout a solution...gd luck
Jul 14, 2009 | SanDisk Computers & Internet
Computer no recongising dvdrom
go to manufactory website and download the right driver for your pc.
Jan 14, 2009 | Dell Inspiron 6000 Notebook
My hard drive is not working
check it on some different system if the problem persists then its the problem of your drive, if its under warranty claim it
Oct 28, 2008 | Verbatim VER95327 USB Hard Drive
My 2g iphone isnt being recongised by my laptop it says USB not recognised. The cable works with other Ipods and I can only charge the phone via electricity when its turned off. Pls help
to isolate if there's something wrong with the laptop, try to plug in other usb devices on all of the usb ports. if other devices works, then you need to reinstall Itunes on your computer and get the latest version. and of course, Iphones only work on USB 2.0 ports.
Sep 17, 2008 | Lands Phones
IPod not getting switched on and not recongised by system
This could be due to a broken usb cable.... if not that,give it a 24 hour charge!
thanks for your question,
have a nice day
Sep 14, 2008 | Apple iPod MA446LL/A MP3 Player
Hd3
1. install the drivers from cd which came along with the player
2. check the USB adapter cable
3. Check the message dialong whenever you connect your USB cable to ur computer on the taskbar.
4.if you get message " one of the usb device connected cannot be recongised" then the problem with the Player adapter controller
5.your computer USB may be malfuntioning
6. check for the drivers installed. if not install drivers from the installation diskette
thank you
Nov 09, 2007 | Sony Network Walkman NW-A1200 MP3 Player
POWER
thank you
Nov 07, 2007 | Sony Network Walkman NW-A1200 MP3 Player
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
153 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
