Question about Motorola Mobility RAZR V3m Cellular Phone
My SanDisk memory card doesn't want to format what do i do?
Do i have to program this memory card 4gb
All you need to do is format the card and copy files to it. Windows typical filesystems
  • FAT
  • FAT16
  • FAT32
  • NTFS
Linux typical filesystems
  • ext2
  • ext3
  • ext4
Apple typical filesystems
  • HFS+
Windows really only see's it's own
Linux can see all of them
Apple can see all of them
So formatting in FAT32 or NTFS would be seen by any operating system
Jan 26, 2013 | SanDisk 2GB microSD Memory Card
Where on my dell inspiron/1200 do i insert sandisk
Do you mean an 8GB SanDisk USB flash drive (thumb drive) or memory card (SD card or another type) or another SanDisk product?
If you have a flash drive, plug it into one of the 3 USB ports on the back of the laptop. If you have other devices plugged in, you may need a USB hub to add ports. (Note: hubs can fail; try a direct connection if the unit doesn't communicate.)
If you are using a memory card, you need to add a memory card reader. USB card readers are available from many shops; they will be cheaper from some online vendors compared to the big box electronics stores. Get one that supports the format of your memory card. There may be PC card slot card readers but I'm not aware of any specific models. The Inspiron/1200 supports Type I or Type II CardBus devices; 16-bit PCMCIA cards are also supported.
If you have a different item, please add a comment giving more informatiion on which SanDisk product you are connecting to the computer. I hope this helps.
Oct 16, 2012 | SanDisk Televison & Video
I using MMC card in my mobile. when it is opened, it doesn't work. it wants to be formated. but doesn't format. so please help me.
Format it on a PC and then use it on your phone...
Get EASEUS Partition Manager. It's totally FREE and an awesome Program for formatting and manipulating hard drives. It's very easy to use.
You can get it here: www.partition-tool.com/
Jul 10, 2012 | SanDisk 2GB microSD Memory Card
I forget password of sandisk 2gb micro sd memory card
you can unlock your sd card by formatting*.
formatting memory card will delete all datas
formatting method*
use a softtwaer phone for formatting.. (example nokia 6120c, 5800etc )
insert your sd card into the softwaer phone.. select SETTINGS > DATA MGR > MEMORY > OPTIONS > FORMAT MEMORY CARD
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
My memory card display 1mb and formaing the card please help me
Hi, connect your SD with a PC and run a virus scan with an updated anti-virus.
If it doesn't work,try formatting it.
good luck!
Sep 11, 2011 | SanDisk 2GB microSD Memory Card
Problem in memory card is occurred in my Mobile. I tried to connect it with computer via card reader. When Click on Removable Disk, there is an error "Access Denied". Please help me in solving...
all you have to do is just connect with PC via Card reader, and then just format it.. if it formats successfully then i will work, and if its doesn't then the memory card is corrupted..
Jun 21, 2011 | SanDisk 2GB microSD Memory Card
Cell phone says that the memory card is not supported do i need to format it first
You haven't listed the model of your phone so I am going to take a shot in the dark here. Most phones will format the card on their own so it could be that the phone in question doesn't support SDHC, you might try an older MicroSD (not SDHC) card and see if it works.
May 30, 2011 | SanDisk 8GB microSDHC Memory Card with...
How to format SanDisk memory card 2 GB, I need password, but I don't know whats password. Card is in my nokia phone. I can't format it on computer to. Is there any solution for this?
Sep 24, 2010 | SanDisk 2GB microSD Memory Card
Motorola Mobility RAZR V3m Cellular Phone Logo
55 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
