Question about HP Photosmart C7250 All-In-One Thermal Printer
Had black ink cartridge filled, but now the
C7250 printer Had black ink cartridge filled, but now the printer won't recognize the cartridge, and keeps telling me it's empty.
    Genius:
  • 1,011 Answers
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Nov 18, 2009
I have a Lexmark Pinnacle Pro 901 printer and its set up to print using black ink only, but it keeps telling to replace color cartridges and it won't let me print at all, how do I print using blac
The printer would need all cartridges to have sufficient ink levels to continue printing - that's to prevent damaging the printhead. Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
To save on your ink investment, try printing in draft mode and by making sure that your printing preferences is set to print using black ink only.
Oct 25, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
I just installed two ink cartridges in my HP Photosmart 7250 and every time I try to print it says the yellow cartridge is empty and it will only print in black, not color, but when I select black only it...
I just had the same problem on my printer and found that resetting the printer solved the problem.
  1. To reset this printer, make sure the printer is on. Unplug the printer without turning the printer off.
  2. Wait 60 seconds.
  3. Hold down the # and 6 button while plugging the printer back in. Keep holding the # and 6 down while the printer turns on. After a bit, on mine there was a picture of the power symbol that appeared on the printer display.
  4. When the power symbol appears on the printer display, take your fingers off the # and 6 button.
  5. Push the power button to turn the printer off. Push the power button again to turn the printer back on. The printer will take some time to go through some preparation. When the preparation is complete, the printer will recognize that the cartridges are full.
I am an HP employee. I do not represent HP on this site.
Oct 25, 2010 | HP Photosmart C7250 All-In-One Thermal...
Printer keeps telling me that the yellow cart is empty and I have put a new one in
Are you positive it says the yellow cart is empty? Because that brother printer is designed to say that a cartridge is empty whenever ANY of the color cartridges are empty. Usually it doesn't tell you which one is really empty either. So even if you replaced the yellow cartridge and say, the black cartridge is empty, it still won't let you print until you replace that empty black cartridge, nor will you know which of the cartridges is empty unless you pull them out of the printer and manually check the ink levels.
Its pretty much a guessing game with those old brother ink printers.
Hope this helps :)
May 03, 2010 | Brother MFC-5440CN All-In-One InkJet...
Won`t recognize new ink cartridges. Still insists black is empty, other colors low, although all have been replaced. Any way to reset or override? Thanks
Hi there
There are only a few steps you need to do to reset a Brother printer ink cartridge and once you do it, you will be up and printing in no time. There are actually two things that a Brother printer uses to detect ink and you can manipulate one or the other.
Instructions
Things You'll Need: · Black electrical tape, masking tape or duct tape
1. Step 1
Identify the printer If your printer uses memory, you can tell which printer you have by looking at where the cartridge goes in, if you see two "eyes" and a part of the cartridge goes in between them, follow Step 3. Otherwise, continue with Step 2.
2. Step 2
Clear the memory by taking the cartridge out and unplugging the unit for 30 seconds. Then, plug it back in and put back in the cartridge. You may need to do this five times, as the memory holds the last five cartridges.
3. Step 3
If the Brother printer has "eyes" where the cartridge goes, you will need to block in between them with a piece of tape so that it thinks the cartridge is always full. Simply put a piece of tape on the piece of the cartridge that goes in between the eyes to block the path of the infrared beam
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 03, 2010 | Brother MFC-230c Printer
Can you refill the black ink cartridge on the c7250? If so, how.
Thermal printer? Normally a thermal printer doesn't have cartridges.
Anyway, my opinion is you should not refill ink cartridges. I have a basement full of printers with dead print heads due to third party ink being used or third party cartridges being used in a wide assortment of printers including a HP Photosmart.
Don't run the risk to save a couple bucks, please.
Thanks for you interest in FixYa.com
Jan 27, 2010 | HP Photosmart C7250 All-In-One Thermal...
How I can reset my canon mp270,lamp B is lighting all the time. I have filled black ink and know my printer dont recognizes cartridge. My computer shows that it is empty.
Nov 14, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Lexmark E120 black cartridge
In their determination to keep you purchasing their ink whether you like it or not, Lexmark has circuitry built into their ink cartridges that based on measured use tell the printer when the cartridge theoretically should be empty, whether it is or not.
In the case of the black cartridge they are somewhat more lenient than in the case of the color cartridge. Eventually, when the circuitry tells the printer that the black cartridge should be empty it will continue to be refillable, and work, but will present the owner with annoying messages ranging from "you're using an unauthentic cartridge" to other things. The best thing to do in this case is to check the box that pops up telling it not to continue giving you the annoying messages. This works, but eventually may start again, after which you again check the box telling it to stop. It's quite livable though.
In the case of the color cartridge the built in circuitry will eventually tell the printer that the cartridge is empty, even if it's not because you have properly refilled it, and it simply will not function any longer. You've just wasted your ink. Natually they don't want to see you destroy your printer, which costs less than purchasing only two of their 2400% profit ink cartridges. Good luck.
Jun 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
HP Photosmart C7250 All-In-One Thermal Printer Logo
231 people viewed this question
Seeker5211
Seeker5211
