Question about Denon Audio Players & Recorders
My AVR488 Denon receiver power button would flash red when turned on. Followed the the owners manual troubleshooting guide but did not fixed the problem. Is there a DIY fix for resetting the protection circuit?
  • vbm9342 Nov 18, 2009
    Did that, the power button would turn green momentarily then starts flashing red again. Any other suggestion would be greatly appreciated.
SOURCE: can't get receiver out of "protect"
My Receiver is on standby mode, no display & does not switch on suggest soloution Pramod R. Pandey 302, Gloma Apatment, At. Mount Mary Steps, St. John Baptist Road, Bandra (W), Mumbai 400050 ? India Tel: 91-22-26412151 Mob: 91-9869256420 pp070862@yahoo.co.in Date: 08-09-2007 To, The Manager, Technical Support, Marantz Europe B.v P.O.Box 8744, 5605 L S Eindhoven, Netherlands. Sub: MARANTZ SR 4600, S.No. MZ000551008756 Dear Sir, This is to inform you that I am a Merchant Ship Mercantile marine officer & our ship had been to the port Antwerp some where in December 2006 & I Purchased The above AV receiver from Nani Ki Dukan that is the duty free shop in Antwerp. The above Receiver is in the Standby mode & does not switch on only the power LED lights up, but the system does not turn on, I consulted your authorized service centre in Mumbai i.e. Rivera International where they told me that since the set is not bought in India they cannot help me, but after persuading them they checked my system & informed me that an IC named NJU3430F is bad & needs replacement, I told them to go ahead but they do not have stock & they cannot procure one for me, in this regard can I please request you to kindly dispatch me the said IC NJU3430F & possible service manual to get it fixed in India. I will pay you for the courier & spare part charges by wire or by DD which ever way you advise as without this spare part the receiver is just a show piece. F.Y.I. I wrote to InstoComp, Inc. dba IC Power Exchange steve@icelect.com Tel: 813-672-8300 Fax: 813-672-8335 http://www.icelect.com & this was there reply. Quote ? *** Part NOT Available *** Although we have over ? 812,173 ? different devices in-stock we can ship today, I regret to inform you we do NOT have this device in-stock or availability (at this time). We are always acquiring new inventory, should this part become available in the near future we will contact you. Thank you for this opportunity to quote, I hope to hear back from you soon.? Unquote. I hope at least you will help me & do the needful to get this AV receiver fixed up at the earliest. Thanking you, I Remain, Yours truly, Pramod CC: Marantz America, Inc. 1100 Maplewood Drive, Itasca, IL 60143, U.S.A
Posted on Sep 12, 2007
  • 4234 Answers
SOURCE: Onkyo TX-NR905 Protection Circuit Activated
The problem is not with the inputs. This unit is in protect because a problem has been detected in the output section. Try disconnecting the speaker wires and turning it on. If the unit remains on, there is a short in one of the speaker wires. If the unit still shuts down, there is an internal problem that will require repair. It sounds like this is a new piece. If so, it should be covered under warranty.
Keep us posted,
Dan
Posted on Jul 28, 2008
  • 163 Answers
SOURCE: When I turn on my receiver, it automatically turns off and the power button flashes red. Prior to shut down, the receiver display notes "Tuner Ext. In" What's the problem? It has worked p
Protection circuit turns off the unit because of critical conditions- wrong power supply voltages or one of the power amplifier channels is bad. First, visual inspect the power amp board near the heat sink for burned resistors, test outputs for a short. If there are no problem you may try to turn the unit on and you have several second before it shuts down to check power supply voltages and power amp output voltages and bias, then ... Long story you'd better take it to a repair shop or repair at ebcelectronics.com
Posted on May 09, 2009
ginko
  • 19396 Answers
SOURCE: Protect keeps flashing
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Posted on May 29, 2009
  • 87 Answers
SOURCE: I have a Denon 1708 receiver. When I push the
Your result indicates the unit is not passing its power up self test. The first thing to try would be to remove all connections to the unit and try to power up. If it still mis-behaves, the unit has an internal problem best left to pros unless you're pretty good digging through circuitry. If it comes up stable, then reconnect things one at a time until the issue occurs again. Detach the offending connection and look for issues in the cables or the connected unit.
Posted on Oct 23, 2010
Denon troubleshooting
my denon s900w is blinking on and off. what do to fix the problem
Jan 03, 2014 | Televison & Video
Zone 2 on my Denon AVR 1804 only works with an analog input. Apparently it was designed that way. WHY?
Because in order to use a digital input, the unit would have to completely power on. Zone 2 is designed so that it can be used with the main power off.
Sep 27, 2013 | Denon AVR-1804 Receiver
The green light flashes when power is turned on and then flashes red and turns off. Can this be reset ?
what do i do when my DENON AVR-1506 turns on then flashes red and turns off?
Mar 08, 2011 | Denon AVR-1506 Receiver
I have a Denon 1708 receiver. When I push the "on" button, either on the unit itself or using the remote, the light flashes green for a few seconds, then flashes red. When it turns red, all of the info...
Oct 23, 2010 | Denon AVR-1708 Receiver
Power button turns green, flashes and then turns red and flashes.
While working it stops and flashes red approximately 2 seconds interval
Causes
Protection circuit is activated depending on the temperature of the surroundings
Remedy
Switch off the power supply and power on after the temperature have reduced.
While working it stops and flashes red approximately 0.5 seconds interval
Causes
1.Using speakers having less impedance than the specified.
2.If speaker core wire touch each other Protection circuit is activated
Even applying power red flashes 0.5 seconds interval
Cause
Amplifier circuit has failed
Remedy
Switch off the power and contact denon service centre
Thank You
Sep 07, 2010 | Denon AVR-789 Receiver
Denon avr -1709 how do i get it reset to factory specs
SWITCH OFF THE UNIT..PUSH AND HOLD DOWN BOTH SPEAKER A AND SPEAKER B BUTTON WHILE HOLDING DOWN BUTTONS TURN ON MAIN POWER THE DISPLAY WILL FLASH WAIT FOR 3 FLASHES THEN RELEASE. THIS WILL RETURN EVERYTHING BACK TO RFACTORY DEFAULT
Mar 21, 2010 | Denon AVR-1708 Receiver
May 09, 2009 | Denon AVR 2808Ci Receiver
Power wont stay on
Hope your under warranty mate and if so hope its not in Australia as they cannot fix this problem. My denon was allegedly fixed twice but has now failed a third time (just out of warranty) and denon have turned their back on me.
SHAME ON YOU DENON.
Jul 08, 2008 | Denon AVR-2105 Receiver
My denon reciever display wont't work
I read something the other day in the user manual about re-setting the microprocessors if the display doesn't display properly. Turn the amp off.  Hold down the input mode & analog buttons while turning power on. The whole display should flash on & off at 1 sec intervals, then release the two buttons. This resets the microprocessors & supposedly fixes display problems.
Jun 23, 2008 | Denon AVR-2805 Receiver
Remote lock on
This worked for me, but I'm sure tired of constantly searching for ways to fix the problems I encounter with my Denon DRA-397. When it works, it's great, but I don't have a degree in electrical engineering. Why can't they produce a user friendly trouble shooting guide?
Dec 14, 2007 | Denon DRA-397
655 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
