Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
I need a new power cable - HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
    President:
  • 2,306 Answers
Go to www.partsurfer.hp.com and put in your model number. You'll get a part number so you can order from them or search on google for a better price.
Posted on Nov 18, 2009
How do I change the throttle cable on a Mantis Tiller SV6 engine?
It depends on the replacement cable. If you see the plastic parts on the new cable, then you don't need to retain them from the old cable. If the new cable does not have the plastic parts, you will have to swap in your old plastic parts onto the new cable.
I hope this helps,
--Robert
Oct 28, 2014 | Mantis Garden
Install a new harddrivw on the optiplex gx620
Two wire are needed to attach a new hard drive.
Please refer to the links below ,to see how the attaching cables looks.
This cable is connects Hard drive to Motherboard
SATA Data Cable
This cable connects Hard drive to Power Supplier
SATA Power Cable
Jun 07, 2012 | Dell OptiPlex GX620 PC Desktop
Install sata disk
From what I was able to find it looks like the board is set for IDE Interface connections for the hard drives. But you can make it accept SATA Drives by adapters that plug into the Power Supply cables that go into the hard drive.
I'll show some links below that will show you the adapters you will need.
The link below shows the Cable that would plug into one of the power supply cables and go into the SATA Drive to give it SATA Interface.
http://www.ebay.com/itm/New-4-PIN-IDE-Molex-To-2-X-15-Pin-SATA-Power-Adapter-cable-Fast-From-USA-/270963453066?pt=US_Drive_Cables_dapters&hash=item3f16ae2c8a
The link below shows you the cable you need that will supply the Power to the Sata Drive. It too plugs into one of the cables that come out of the Power Supply and goes into the Sata Drive.
http://www.ebay.com/itm/New-4-PIN-IDE-To-Serial-SATA-Power-Cable-adapter-/270693224712?pt=US_Drive_Cables_dapters&hash=item3f0692d108
May 10, 2012 | Dell 3E851 Motherboard
My PC power supply crashed, burnt resistors, Powerman IW-P250A3-1 20 pin plug to motherboard, bought new power source, but the old power source had a white cable to the 20 pin plug which was -5vdc 0.3amp....
For your system to boot up properly, you need an identical power supply for your system. Most likely the reason why your system won't boot up right now is because you purchased a different power supply and it is lacking something(which is the other pin).
Regards
Sep 14, 2011 | Computers & Internet
I need a power cord for a Tournament Master HR Bottom Line fish locator. Where can I find this cord?
Do you still need the power cable? I have a new unopened power cable.
Dave
Feb 10, 2011 | Boating
Power comes from light to switch.want to wire in another switch (same box) to operate another separate light
OK .. for this to work, you would need to confirm that the power cable is also in this wall box. So in that wall box you need the existing power cable, the existing light cable, and a new light cable. All the cables being 2 wire with ground. Then just jumper the black power wire top the new switch, and connect the new light , black wire to the switch, the whites will all be together ..
If there is only one cable in this wall box , then the power is run to some other box and you need a neutral for the new light. That may mean rewiring the power tyop get it to the wall box, or rewing the new light to get power from it.
Please Vote !!
Mar 22, 2010 | Cooper Wiring Devices ACE6001V-K "ACE"...
I NEED A NEW POWER CABLE
Please note if you cable is faulty. Meaning not powering your unit up KODAK will exchange the cable free of charge if the frame is covered under warranty.
If not you will need to purchace a new cable: Either online or by calling the service centre:
contact KODAK in order to arrange a repair or order a new cable. Remember your cable is covered under the same warranty as your frame, so remember your serial number when calling:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 14, 2010 | Kodak EasyShare EX1011 Digital Picture...
Broken the mains power cableand dont know were to get a new one
Help is at hand. but you do need basic electrical skills for the first solution and handy soldering skills for the 2nd.
sol1
If you cable is fraid then cut the cable and fit an inline connector. If your not sure here is a link.
http://www.4barmey.co.uk/cgi-bin/product.pl?PID=1078065&item=783496&section=67924&path=67885,185197,67893:185866,67924
Sol2
Total replacement of power cable and plug. you will need to buy new flex and plug. normally two core flexible (multicore not solid core) cable.
Open up the rear case to the tv and keep all screws. DO NOT touch the end of the tv tube as high voltage lingers a while after unplugging. You are looking / tracking the power cable where it fits to the tv motherboard.
Take a standard solder iron and remove each cable in turn. noting the colour and positions. Prepare your new cable feeding it into the casing and motherboard to suit. Apply flus and solder to secure each new cable in place. Hold cable while it sets and cools. CHECK there is no solder connecting these cables together for obvious reason these DO NOT connect together.
Replace casing and all screws in reverse order.
You should have a good to go new cable and a tv working fine.
AndystUK
Aug 31, 2009 | Crown Televison & Video
New PSU
Hello Kathyhudson,
All the cables are connected, the PCI express (6) pin cable is only needed if you have a PCI video card.
A four pin connector is for the motherboard if it requires it.
Post back with any new questions, or additional info for further help. Thank you for choosing Fixya!
Apr 02, 2009 | Dynex 400-Watt ATX CPU Power Supply
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
29 people viewed this question
Seeker5211
Seeker5211
