Question about Ricoh Office Equipment & Supplies
We have an error code SC546 any idea what that means. It just showed up.
  • michelec251 Nov 19, 2009
    Ricoh Aficio 1022..sorry for the confusion, we were in a panic since it stopped working.
  • Chris May 11, 2010
    Would need to know the brand and model of the machine before such a code could be deciphered. At first glance, it appears to be a Ricoh or Savin brand, but don't know for sure...
    New Friend:
  • 22 Answers
This is a fuser code; it can be reset on newer models by pressing...
clear modes(yellow key)
1, 0, 7
clear stop (hold down until screen changes)
select copier sp
turn machine off with red rocker switch(likely on left side of machine)
wait 10 seconds and turn back on
If the code comes back, there is likely something malfunctioning on the machine, and it will require service. If not, this should get you by for awhile.
Posted on Nov 19, 2009
  • 192 Answers
Yeah, what he said... Here is the info from the service manual:
SC546: Unstable fusing temperature
The fusing temperature varies 50°C or more within 1 second twice
continuously.
Possible Causes:
• Thermistor defective
• Poor connection of the fusing unit
• Power supply unit defective
I'd go with the idea that the thermistors (2 of them) probably have a significant build-up of toner, and should be cleaned or replaced.
Check your copy counter and see how many copies/prints it has:
Press User Tools/Counter button in upper left of the control panel, then select the touch-screen button 'Counter' in the lower right of the screen. The fusing unit is supposed to be serviced about every 120,000 copies/prints.
Generally an error like this will go away, initially, after performing the reset function the other poster listed, but odds are it will return soon, and the problem will only get worse.
Posted on Nov 20, 2009
3 Suggested Answers
goodgold
  • 389 Answers
SOURCE: I have a Ricoh Aficio 150 PCL and I have an error
SC546Fusing ready temperature malfunction
Look sanity of the block of the fastening, fuser
Check join , замерьте resistance termo lamp, termistor and termo fuse.
Posted on Sep 28, 2009
  • 11 Answers
SOURCE: I have a Lanier 5635 and its not working. The
546 A Unstable fusing temperature The fusing temperature varies 50°C or more within 1 second twice continuously. • Thermistor defective(temp. senzors in the fixing unit) • Poor connection of the fusing unit • Power supply unit defective
Posted on Jul 12, 2010
What is the code SC546 mean?
search error code . Brother MFC-8860DN Printer
Jul 10, 2014 | Brother MFC-8860DN Printer
Error code sc546
546 is an unstable fusing temperature:
-Fusing thermistor defective
-Power supply board defective
-Defective connection of fusing unit
Feb 27, 2014 | Ricoh Aficio 1035 Copier
Error code sc546
sc546 is a fuser ready temp problem.
it requires a reset procedure: enter SP mode.touch Copy SP..touch SP DIRECT then press 7807# on the keypad then execute...turn power off and then back on
Jan 29, 2014 | Ricoh Aficio 1027 All-In-One Laser Printer
How do I clear error sc546 on a Ricoh Aficio 2035
replace thermostat in heating section or u yuor tirmistor is directly touching the heat roller
Feb 13, 2012 | Ricoh Aficio 2022 Black and White Copier
I have a Lanier 5635 and its not working. The error code is SC546. Ant ideas whats going on.
Jun 23, 2010 | Gestetner DSm515pfd Digital Copier -...
I have Gestetner DSM622 SP, Iam getting Errer code SC546, can someone explain me thanks
sc546 is a fuser temperature detect error. One or both of the thermistors most likely need to be cleaned or replaced, but you will have to go into service mode to reset the code once you do that. You should contact your local service technician or Gestetner dealer, as they can easily fix that problem.
May 13, 2010 | Gestetner DSm622sp Digital Imaging System
RICOH 2045E COPIER WHAT DOES ERROR CODE SD546 MEAN?
Hello!
Follow the next steps carefully and the error code SC546 will disappear.
Press the following keys by this order:
1. press the (yellow key) [Clear]
2. press then the numbers on the numbers key by order (1)-(0)-(7)
3. press the red key (cancel) [C] and hold it pressed for about 5 seconds.
4. on the screen will appear another menu different from the one
you are
familiarized it will write up in the left corner [service menu],
(if the service menu do not appear repeat the procedure again).
After this menu will appear turn off the machine from the red switch which is located somewhere in the middle of the machine and just by the left corner (the turn off switch-plug) wait for 10 seconds and turn back on the machine by the same switch-plug.
After this the error code SC546 should be disappear.
Please Answer does this was helpful for i to know does the problem has disappear or i should post some other information.
Regards
Jan 12, 2010 | Ricoh Aficio 450 Copier
I have a Ricoh Aficio 150 PCL and I have an error code SC546. What does this mean?
Sep 28, 2009 | Office Equipment & Supplies
418 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
