Question about Toshiba 32AF43 32" TV
Slight starbursting on each side of screen.
Whenever I am watching dvds with the anamorphic squeeze, I notice what looks to be some slight starbursting on both sides of the screen. This only happens when I'm watching anamorphic enhanced dvds. Any help would be appreciated.
    Sergeant:
    Champion:
  • 375 Answers
Adjust the horizontal size to hide the lines
Posted on Mar 28, 2008
What oil do I use on a 08 buick lucerne cxl
OIL TYPE
1.GM6094M Your vehicle's engine requires oil meeting GM Standard GM6094M.
2.SAE 5W-30 is best for your vehicle. These numbers on an oil container show its viscosity, or thickness. Do not use other viscosity oils such as SAE 20W-50. Oils meeting these requirements should also have the starburst symbol on the container. This symbol indicates that the oil has been certified by the American Petroleum Institute (API). You should look for this information on the oil container, and use only those oils that are identified as meeting GM Standard GM6094M and have the starburst symbol on the front of the oil container.
NOTICE: Use only engine oil identified as meeting GM Standard GM6094M and showing the American Petroleum Institute Certified For Gasoline Engines starburst symbol. Failure to use the recommended oil can result in engine damage not covered by your warranty.
GM Goodwrench oil meets all the requirements for your vehicle.
If you are in an area of extreme cold, where the temperature falls below -20°F (-29°C), it is recommended that you use either an SAE 5W-30 synthetic oil or an SAE 0W-30 oil. Both will provide easier cold starting and better protection for your engine at extremely low temperatures.
ENGINE OIL ADDITIVES
Do not add anything to your oil. The recommended oils with the starburst symbol that meet GM Standard GM6094M are all you will need for good performance and engine protection.
Jul 03, 2015 | Buick Cars & Trucks
I dropped my 42 in dynex 1080 p but it didn't hit
It usually means the screen unit or panel is damaged--they are very fragile and even a slight blow can destroy them---Panel alone if bad costs much more than another set--seen one where a two year old just slapped the screen (not very hard either) and destroyed it Panel.
I will attach a few photos---no two look alike except if a starburst or odd pattern does not move---Panel.
Apr 13, 2012 | Televison & Video
My xbox 360 wont read the disc?
the laser lens needs clean, or adjusting which would require you to open up console and disk drive. there are 2 tiny screws on the lens which adjust for watching dvds and games the right hand side screws needs to be turned ever so slightly. or you may need a new laser lens all together. look at youtube for some help.
Nov 03, 2011 | Microsoft Xbox 360 Console
I have an LG 42lh30 I bought less than a month ago from frys. When I opened the box it did seem slightly used maybe it was returned and refurbished or something. I have an xbox and I use a philips 1080p...
Is it a Duplicate Question....Wonder why?
Same reply :0
This is an internal Fault. Diagnosis is required to make sure whether it is Failed T Con Board or Light Engine. I do not think that it would really help by changing the TV settings. This was a Common Problem with Old LCD's where you got Blurry Spots specially while Playing Real Fast Movies or Games. On Few Occasions, it as Corrupted Firmware.
As i cannot see the Video or Screen from here, more likely what i could guess it is an Internal Fault as you have tried using HDMI, Use different Setting Combination's and you got the same Picture Quality with DVD as well.
So, what i could suggest, get back to the Seller and Lodge an Official Complain and get it Replaced. There is no point in Opening and TV and Inspecting it and Replacing Components when it was less than a month ago.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 30, 2010 | Televison & Video
I cant watch dvds on it what wire do hook up to what.
Take the green parking light wire and put it to 1 side of a toggle switch, ground the other side of the toggle switch. Put dvd in wait for warning screen, flip toggle swithc off, then on. You should be all set.
Jul 17, 2009 | Pioneer AVH-P5700DVD Car DVD Player
Water in the Driver side 2003 VW Jetta
hey there, had the same problem and found it to be caused but the drain for the sunroof. open the drivers door, look above the hinge and you will find a rubber bit sticking out from the car side. squeeze it and watch the water pour out. just received a recall notice from VW. now that the carpets are ruined, both sides!
hope this helps.
Jun 21, 2009 | 2003 Volkswagen Jetta TDI
HD channles
Hi Scan 1080: Enables you to receive the 1080i, 720p, 480p and 480i digital TV formats. By using the VIDEO 5/6 IN jacks, you can connect a DTV (digital television) receiver to view DTV programs. q DRC Multi-Function: Unlike conventional line doublers, the DRC feature doubles vertical and horizontal lines, resulting in four times the density for quality sources such as DVD, Satellite and Digital camcorder. q CineMotion: Using the 2-3 Pull-Down technology, the CineMotion feature allows you to obtain a smooth picture movement when playing back movies or other video sources on film. q Twin View: Using Multi-Image Driver (MID-X), Twin View allows you to watch two programs side by side with the ability to zoom in one picture and listen to selected window. You can watch pictures from two different sources (1080i, 720p, 480p or 480i) simultaneously. q 16:9 Enhancement: Vertical Compression technology that maximizes picture resolution on “anamorphic” or “enhanced for wide screen” sources, including selected DVDs. q Steady Sound: Equalizes volume levels so there is consistent output between programs and commercials. q Parental Control: V-Chip technology allows parents to block unsuitable programming for younger viewers. q Component Video Inputs: Offers the best video quality for DVD (480p, 480i) and Digital Set-top box (1080i, 720p, 480p, 480i) connections. q S-VIDEO Inputs: Provides a high-quality image for connected equipment. q Favorite Channel Preview: Preview up to eight favorite channels
Jun 02, 2008 | Sony KP-61HS20 TV
Picture slants right to left
Hope you have fixed this problem by now, if that tv is unserviced, I mean if nobody has ever opened it, it could be a problem with the positioning of your tv, just tilt the tv in different positions and find out the position in which it will show the right fit. If it is serviced, especially yoke is changed, this is rare, it could be because the position of yoke is not aligned properly.
Dec 16, 2006 | Philips 27PT5445 27" TV
I have a blinking star/starburst animated graphic in the top left hand
it's an alarm Iget that a lot. tap on it. it opens an alarm. Then you can clear it. It's a feature!
Sep 11, 2005 | Palm Tungsten E Handheld
Toshiba 32AF43 32" TV Logo
54 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
